Tests fail after building parallel netcdf with gcc and openmpi
Greg Schussman
schussman at slac.stanford.edu
Wed Jan 4 19:13:23 CST 2012
Hi.
I'm having trouble getting a working version of parallel netcdf using
gcc and openmpi. I've tried various combinations of:
parallel-netcdf-1.1.1
parallel-netcdf-1.2.0
gcc 4.5.1
gcc 4.6.1
openmpi-1.4.3
openmpi-1.5
I'm building using this bash script:
MPICC=mpicc MPICXX=mpicxx ./configure \
--prefix=$HOME/$NERSC_HOST/Software/parallel-netcdf --disable-fortran
make clean
make
make install
All that completes with no complaints. Then to test, I run:
../parallel-netcdf/bin/ncmpidump test/data/test_double.nc
Which gives:
0: MPI_File_open : MPI_ERR_OTHER: known error not in list
../parallel-netcdf/bin/ncmpidump: test/data/test_double.nc: Can not
open/create file
I have checked that that ncmpidump really is the one created by my
build. I have copied that test_double.nc file to another machine with a
working ncmpidump, and the file is not corrupt.
I've tried running the tests that come with the sources via:
cd test/nc_test/
make testing
Which starts this way:
./nc_test -c
FAILURE at line 661 of util.c: ncmpi_create: Can not
open/create file
FAILURE at line 547 of util.c: ncmpi_def_dim: Not a netCDF id
FAILURE at line 563 of util.c: ncmpi_def_var: Not a netCDF id
FAILURE at line 563 of util.c: ncmpi_def_var: Not a netCDF idrm
-f scratch.nc
./nc_test && ./nc_test -c -2 && ./nc_test
*** Testing ncmpi_strerror ... ok
*** Testing ncmpi_open ... 0: MPI_File_open :
FAILURE at line 97 of test_read.c: ncmpi_open of nonexistent
file should have returned system error 0: MPI_File_open : MPI_ERR_OTHER:
FAILURE at line 107 of test_read.c: ncmpi_open: Can not
open/create file
FAILURE at line 110 of test_read.c: ncmpi_redef of read-only
file should fail 0: MPI_File_open : MPI_ERR_OTHER: known error not in list
FAILURE at line 114 of test_read.c: ncmpi_open: Can not
open/create file 0: MPI_File_open : MPI_ERR_OTHER: known error not in list
FAILURE at line 124 of test_read.c: ncmpi_create: Can not
and ends this way:
FAILURE at line 5995 of test_iput.c: ncmpi_create: Can not
open/create file
### 1 FAILURES TESTING ncmpi_iput_varm_int! ###
*** Testing ncmpi_iput_varm_long ... 0: MPI_File_open :
FAILURE at line 6163 of test_iput.c: ncmpi_create: Can not
open/create file
### 1 FAILURES TESTING ncmpi_iput_varm_long! ###
*** Testing ncmpi_iput_varm_float ... 0: MPI_File_open :
FAILURE at line 6331 of test_iput.c: ncmpi_create: Can not
open/create file
### 1 FAILURES TESTING ncmpi_iput_varm_float! ###
*** Testing ncmpi_iput_varm_double ... 0: MPI_File_open :
FAILURE at line 6499 of test_iput.c: ncmpi_create: Can not
open/create file
### 1 FAILURES TESTING ncmpi_iput_varm_double! ###
NOTE: parallel-netcdf expects to see 2 failures
Total number of failures: 167738
Thanks in advance for any help.
Greg
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20120104/f2d73ea4/attachment.htm>
More information about the parallel-netcdf
