failure to dup communicator in pnetcdf
Rob Latham
robl at mcs.anl.gov
Wed Sep 7 10:50:51 CDT 2011
I noticed last week that parallel-netcdf does not duplicate the
communicator passed to the library as part of ncmpi_open/nfmpi_open and
ncmpi_create/nfmpi_create.
It's been 8 years and no one has complained, and a lot of the heavy
lifting is done in the MPI-IO library (which does duplicate the
communicator). Still, I'm about to commit this patch unless someone
can remind me why we do not need it...
Index: src/lib/mpincio.c
--- src/lib/mpincio.c (revision 923)
+++ src/lib/mpincio.c (working copy)
@@ -136,7 +136,7 @@ ncmpiio_create(MPI_Comm comm,
nciop->mpiomode = MPI_MODE_RDWR;
nciop->mpioflags = 0;
- nciop->comm = comm;
+ MPI_Comm_dup(comm, &(nciop->comm));
ncmpiio_extract_hints(nciop, info);
@@ -147,7 +147,7 @@ ncmpiio_create(MPI_Comm comm,
/* to avoid calling MPI_File_set_size() later, let process 0 check
if the file exists. If not, no need to call MPI_File_set_size */
int rank;
- MPI_Comm_rank(comm, &rank);
+ MPI_Comm_rank(nciop->comm, &rank);
if (rank == 0) { /* check if file exists */
if (access(path, F_OK) == 0) { /* but is this only available in Linux? */
/* file does exist, so delete it */
@@ -164,7 +164,8 @@ ncmpiio_create(MPI_Comm comm,
#endif
- mpireturn = MPI_File_open(comm, (char *)path, mpiomode, info, &nciop->collective_fh);
+ mpireturn = MPI_File_open(nciop->comm, (char *)path, mpiomode,
+ info, &nciop->collective_fh);
if (mpireturn != MPI_SUCCESS) {
int rank;
@@ -215,11 +216,12 @@ ncmpiio_open(MPI_Comm comm,
nciop->mpiomode = mpiomode;
int rank;
@@ -321,6 +323,9 @@ ncmpiio_close(ncio *nciop, int doUnlink) {
MPI_Info_free(&(nciop->mpiinfo));
#endif
+ if (nciop->comm != MPI_COMM_NULL) {
+ MPI_Comm_free(&(nciop->comm));
ncmpiio_free(nciop);
Rob Latham
Mathematics and Computer Science Division
Argonne National Lab, IL USA
More information about the parallel-netcdf
