Error in building
Kui Gao
kgao0827 at gmail.com
Tue Sep 6 17:32:14 CDT 2011
Hi Alex,
The process is as follows usually.
Step 1: Get the pnetCDF source code
Step 2: aclocal && autoconf && autoheader
Step 3: ./configure --prefix=your_prefix_install_path --enble-fortran --enable-mpi-io-test --with-mpi=your_mpi_path(/usr/local/bin) CC=/usr/local/bin/gcc CXX=/usr/local/bin/g++ FC=/usr/local/bin/gfortran F90=/usr/local/bin/gfortran MPICC=/usr/local/bin/mpicc MPICXX=/usr/local/bin/mpicxx MPIF77=/usr/local/bin/mpif77 MPIF90=/usr/local/bin/mpif90
Please change "gcc", "g++" ... to your complier if possible.
step 4: make
step 5: make install
please try it again.
Kui.
On Sep 6, 2011, at 5:14 PM, Alessandro Marinoni wrote:
> Hi
> I'm trying to compile pnetcdf-1.2 with mpich2 but I get the following error:
> checking sizeof MPI_Offset... ./configure: line 11628: -c: command not found
> configure: error: Unable to compile or link the test program
> Does anybody know how to solve it, or, at least, how to force configure to go to the end?
> Thanks in advance
> Alex
More information about the parallel-netcdf
