Hints on improving performance with WRF and Pnetcdf
Craig Tierney
Craig.Tierney at noaa.gov
Wed Sep 8 10:03:31 CDT 2010
On 9/8/10 8:25 AM, Wei-keng Liao wrote:
> Craig,
> Could you check the stripe count and size of the files created by your run (linked with my ROMIO)?
> Or set the permission for me to have a look on Ranger.
> One question, have you run the same jobs on other machines with different parallel file systems?
> If yes, were the I/O performance much better than on Ranger?
> Wei-keng
I am not running on Ranger (I just have in the past). I am trying to
improve WRF IO performance on a NOAA machine. I am going to do the
things that Rob suggested I try, it will just take a little time to
get it going.
Craig
> On Sep 8, 2010, at 8:36 AM, Craig Tierney wrote:
>> I am not aware of my IO patterns (I know I should, but I am trying to
>> act like a normal user and not dig into these things). I am using WRF, which is passing IO to PNETCDF, and then onto Romio. My concern is how to get WRF and Pnetcdf to do anything useful.
>> Craig
More information about the parallel-netcdf
