Hints on improving performance with WRF and Pnetcdf
Wei-keng Liao wkliao at ece.northwestern.edu
Wed Sep 8 09:25:53 CDT 2010
Craig,
Could you check the stripe count and size of the files created by your run (linked with my ROMIO)?
Or set the permission for me to have a look on Ranger.
One question, have you run the same jobs on other machines with different parallel file systems?
If yes, were the I/O performance much better than on Ranger?
Wei-keng
On Sep 8, 2010, at 8:36 AM, Craig Tierney wrote:
> I am not aware of my IO patterns (I know I should, but I am trying to
> act like a normal user and not dig into these things).  I am using WRF, which is passing IO to PNETCDF, and then onto Romio.  My concern is how to get WRF and Pnetcdf to do anything useful.
> Craig
