Problems with PGI and 1.1.1
Gerry Creager gerry.creager at tamu.edu
Mon May 17 08:54:34 CDT 2010
Dave
First, PGI 8 should never have seen the light of day. We back-ported to
7.2 after a month of sys admin testing. ( was better. 10.3 is good, but
now 10.5 is out. Keeping up is a pain.
I'll have to run the test suite again, but on "real" wrf runs, it
appears to behave fine.
Are you sure OpenMPI and the mpich flavors were compiled with -fPIC?
That was a problem I ran into, although it appeared as a compile-time error.
gerry
David Robertson wrote:
> Hi,
> I'm having problems with "make testing" (in nc_test) using PGI. I have
> tried 3 mpi implementations (MPICH, MPICH2, and Open MPI) and 3 versions
> (8.0, 9.0, and 10.1) of the PGI compiler. All of these compile without
> errors. However, They all Segfault at different places when I run the
> testing suite.
> For example, PGI 10.1 with Open MPI segfaults while testing
> ncmpi_get_var1_short but 9.0 with Open MPI segfaults while testing
> ncmpi_get_var_schar. Both the compiler version and MPI implementation
> seem to affect where nc_test fails.
> On the same machine I can compile and test with both ifort and gfortran
> using either MPICH2 or Open MPI. The combination of ifort and MPICH is
> also successful.
> Any suggestions would be helpful.
> Thanks,
> Dave
