Problems with PGI and 1.1.1
David Robertson robertson at marine.rutgers.edu
Mon May 17 08:10:53 CDT 2010
I'm having problems with "make testing" (in nc_test) using PGI. I have
tried 3 mpi implementations (MPICH, MPICH2, and Open MPI) and 3 versions
(8.0, 9.0, and 10.1) of the PGI compiler. All of these compile without
errors. However, They all Segfault at different places when I run the
testing suite.
For example, PGI 10.1 with Open MPI segfaults while testing
ncmpi_get_var1_short but 9.0 with Open MPI segfaults while testing
ncmpi_get_var_schar. Both the compiler version and MPI implementation
seem to affect where nc_test fails.
On the same machine I can compile and test with both ifort and gfortran
using either MPICH2 or Open MPI. The combination of ifort and MPICH is
also successful.
Any suggestions would be helpful.
Dave
