filename prefixes
Don Morton Don.Morton at alaska.edu
Wed Aug 11 18:32:57 CDT 2010
I've used pnetcdf with WRF, using the nocolons option.  I'm not sure
specifically what you're asking now, but I can send you my notes if it
helps...
On Wed, Aug 11, 2010 at 3:13 PM, Gerald Creager <gerry.creager at tamu.edu>wrote:
> It's a namelist.input spec: NOCOLONS
> I'm sorting thru some other issues with pnetcdf and WRF right now... I'm
> having to change it so it'll create wrfout_dxx files with the striping info
> correct at file creation. If anyone's had to do this, I'd appreciate a
> clue...
> gerry
> Jim Edwards wrote:
>> Hi Johnny,
>> I think that the real problem may be that WRF uses the colon character in
>> filenames and the filesystem reserves this same character for special use.
>> I think that there is a compile option for wrf not to use colons.
>> Jim
>> On Wed, Aug 11, 2010 at 4:44 PM, Johnny Chang <Johnny.Chang at nasa.gov<mailto:
>> Johnny.Chang at nasa.gov>> wrote:
>>    Hello,
>>    I am helping a user trouble-shoot a runtime error using
>>    parallel-netcdf version 1.1.1 and mvapich2/1.2p1/intel-PIC.
>>    The error message is:
>>     0: MPI_File_open : File does not exist, error stack:
>>    ADIO_RESOLVEFILETYPE_PREFIX(546): Invalid file name
>>    wrfout_d01_2006-07-25_00:00:00
>>     open_hist_w : error opening wrfout_d01_2006-07-25_00:00:00 for
>>    writing. ***
>>    While googling the ADIO_RESOLVEFILETYPE_PREFIX error, we found the
>>    ad_fstype.c code containing:
>>    477     /*
>>    478       ADIO_FileSysType_prefix - determines file system type for
>>    a file using
>>    479       a prefix on the file name.  upper layer should have
>>    already determined
>>    480       that a prefix is present.
>>    481        482     Input Parameters:
>>    483     . filename - path to file, including prefix (xxx:)
>>    484        485     Output Parameters:
>>    486     . fstype - pointer to integer in which to store file system
>>    type (ADIO_XXX)
>>    487     . error_code - pointer to integer in which to store error code
>>    488        489       Returns MPI_SUCCESS in error_code on success.
>>  Filename
>>    not having a prefix
>>    490       is considered an error. Except for on Windows systems
>>    where the default is NTFS.
>>    491        492      */
>>    493     static void ADIO_FileSysType_prefix(char *filename, int
>>    *fstype, int *error_code)
>>    494     {
>>    495         static char myname[] = "ADIO_RESOLVEFILETYPE_PREFIX";
>>    496         *error_code = MPI_SUCCESS;
>>    497        498         if (!strncmp(filename, "pfs:", 4) ||
>> !strncmp(filename,
>>    "PFS:", 4)) {
>>    499             *fstype = ADIO_PFS;
>>    500         }
>>    557     #else
>>    558             *fstype = 0;
>>    559             /* --BEGIN ERROR HANDLING-- */
>>    560             *error_code = MPIO_Err_create_code(MPI_SUCCESS,
>>    MPIR_ERR_RECOVERABLE,
>>    561                                                myname, __LINE__,
>>    MPI_ERR_NO_SUCH_FILE,
>>    562                                                "**filename",
>>    "**filename %s", filename);
>>    563             /* --END ERROR HANDLING-- */
>>    564     #endif
>>    565         }
>>    566     }
>>    which seems to indicate that the MVAPICH2 library is expecting
>>    parallel-netcdf
>>    to pre-pend a prefix on the filename passed to the MVAPICH2 library.
>>    We are running on a Lustre filesystem.  So, we think that the
>>    parallel-netcdf
>>    library should have passed the "lustre:" or "LUSTRE:" prefix along
>>    with the
>>    actual filename.  Are we right in this interpretation of the error?
>>    If so, then perhaps the parallel-netcdf library was not built
>> correctly?
>>    Here is the beginning part of config.log:
>>    This file contains any messages produced by compilers while
>>    running configure, to aid debugging if configure makes a mistake.
>>    It was created by configure, which was
>>    generated by GNU Autoconf 2.61.  Invocation command line was
>>     $ ./configure --prefix=/nasa/parallel-netcdf/1.1.1/mvapich2
>>    --with-mpi=/nasa/mvapich2/1.2p1/intel-PIC
>>    ## Platform. ##
>>    hostname = pbspl1
>>    uname -m = x86_64
>>    uname -r = 2.6.16.60-0.42.5.03schamp-nasa
>>    uname -s = Linux
>>    uname -v = #1 SMP Tue Nov 10 20:46:20 UTC 2009
>>    /usr/bin/uname -p = unknown
>>    /bin/uname -X     = unknown
>>    /bin/arch              = x86_64
>>    /usr/bin/arch -k       = unknown
>>    /usr/convex/getsysinfo = unknown
>>    /usr/bin/hostinfo      = unknown
>>    /bin/machine           = unknown
>>    /usr/bin/oslevel       = unknown
>>    /bin/universe          = unknown
>>    PATH: /nasa/intel/Compiler/11.1/046/bin/intel64
>>    PATH: /nasa/intel/Compiler/11.1/046/mkl/tools/environment
>>    PATH: /nasa/mvapich2/1.2p1/intel-PIC/bin
>>    PATH: /u/jrappley/bin
>>    If the problem is in the parallel-netcdf build, let us know
>>    what is the fix.
>>    Thanks in advance!
>>    Johnny
>>    --     Johnny Chang
>>    650-604-4356
> Gerry Creager -- gerry.creager at tamu.edu
> Texas Mesonet -- AATLT, Texas A&M University
> Cell: 979.229.5301 Office: 979.458.4020 FAX: 979.862.3983
> Office: 1700 Research Parkway Ste 160, TAMU, College Station, TX 77843
Arctic Region Supercomputing Center
http://weather.arsc.edu/
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20100811/bc3f2af8/attachment-0001.htm>
