filename prefixes
Gerald Creager
gerry.creager at tamu.edu
Wed Aug 11 18:13:22 CDT 2010
It's a namelist.input spec: NOCOLONS
I'm sorting thru some other issues with pnetcdf and WRF right now... I'm
having to change it so it'll create wrfout_dxx files with the striping
info correct at file creation. If anyone's had to do this, I'd
appreciate a clue...
gerry
Jim Edwards wrote:
> Hi Johnny,
> I think that the real problem may be that WRF uses the colon character
> in filenames and the filesystem reserves this same character for special
> use. I think that there is a compile option for wrf not to use colons.
> Jim
> On Wed, Aug 11, 2010 at 4:44 PM, Johnny Chang <Johnny.Chang at nasa.gov
> <mailto:Johnny.Chang at nasa.gov>> wrote:
> Hello,
> I am helping a user trouble-shoot a runtime error using
> parallel-netcdf version 1.1.1 and mvapich2/1.2p1/intel-PIC.
> The error message is:
> 0: MPI_File_open : File does not exist, error stack:
> ADIO_RESOLVEFILETYPE_PREFIX(546): Invalid file name
> wrfout_d01_2006-07-25_00:00:00
> open_hist_w : error opening wrfout_d01_2006-07-25_00:00:00 for
> writing. ***
> While googling the ADIO_RESOLVEFILETYPE_PREFIX error, we found the
> ad_fstype.c code containing:
> 477 /*
> 478 ADIO_FileSysType_prefix - determines file system type for
> a file using
> 479 a prefix on the file name. upper layer should have
> already determined
> 480 that a prefix is present.
> 481
> 482 Input Parameters:
> 483 . filename - path to file, including prefix (xxx:)
> 484
> 485 Output Parameters:
> 486 . fstype - pointer to integer in which to store file system
> type (ADIO_XXX)
> 487 . error_code - pointer to integer in which to store error code
> 488
> 489 Returns MPI_SUCCESS in error_code on success. Filename
> not having a prefix
> 490 is considered an error. Except for on Windows systems
> where the default is NTFS.
> 491
> 492 */
> 493 static void ADIO_FileSysType_prefix(char *filename, int
> *fstype, int *error_code)
> 494 {
> 495 static char myname[] = "ADIO_RESOLVEFILETYPE_PREFIX";
> 496 *error_code = MPI_SUCCESS;
> 497
> 498 if (!strncmp(filename, "pfs:", 4) || !strncmp(filename,
> "PFS:", 4)) {
> 499 *fstype = ADIO_PFS;
> 500 }
> 557 #else
> 558 *fstype = 0;
> 559 /* --BEGIN ERROR HANDLING-- */
> 560 *error_code = MPIO_Err_create_code(MPI_SUCCESS,
> MPIR_ERR_RECOVERABLE,
> 561 myname, __LINE__,
> MPI_ERR_NO_SUCH_FILE,
> 562 "**filename",
> "**filename %s", filename);
> 563 /* --END ERROR HANDLING-- */
> 564 #endif
> 565 }
> 566 }
> which seems to indicate that the MVAPICH2 library is expecting
> parallel-netcdf
> to pre-pend a prefix on the filename passed to the MVAPICH2 library.
> We are running on a Lustre filesystem. So, we think that the
> parallel-netcdf
> library should have passed the "lustre:" or "LUSTRE:" prefix along
> with the
> actual filename. Are we right in this interpretation of the error?
> If so, then perhaps the parallel-netcdf library was not built correctly?
> Here is the beginning part of config.log:
> This file contains any messages produced by compilers while
> running configure, to aid debugging if configure makes a mistake.
> It was created by configure, which was
> generated by GNU Autoconf 2.61. Invocation command line was
> $ ./configure --prefix=/nasa/parallel-netcdf/1.1.1/mvapich2
> --with-mpi=/nasa/mvapich2/1.2p1/intel-PIC
> ## Platform. ##
> hostname = pbspl1
> uname -m = x86_64
> uname -r = 2.6.16.60-0.42.5.03schamp-nasa
> uname -s = Linux
> uname -v = #1 SMP Tue Nov 10 20:46:20 UTC 2009
> /usr/bin/uname -p = unknown
> /bin/uname -X = unknown
> /bin/arch = x86_64
> /usr/bin/arch -k = unknown
> /usr/convex/getsysinfo = unknown
> /usr/bin/hostinfo = unknown
> /bin/machine = unknown
> /usr/bin/oslevel = unknown
> /bin/universe = unknown
> PATH: /nasa/intel/Compiler/11.1/046/bin/intel64
> PATH: /nasa/intel/Compiler/11.1/046/mkl/tools/environment
> PATH: /nasa/mvapich2/1.2p1/intel-PIC/bin
> PATH: /u/jrappley/bin
> If the problem is in the parallel-netcdf build, let us know
> what is the fix.
> Thanks in advance!
> Johnny
> Johnny Chang
> 650-604-4356
Gerry Creager -- gerry.creager at tamu.edu
Texas Mesonet -- AATLT, Texas A&M University
Cell: 979.229.5301 Office: 979.458.4020 FAX: 979.862.3983
Office: 1700 Research Parkway Ste 160, TAMU, College Station, TX 77843
More information about the parallel-netcdf
