v1.1.1... again
Rob Latham
robl at mcs.anl.gov
Wed Apr 21 09:19:56 CDT 2010
On Wed, Apr 21, 2010 at 07:32:36AM -0500, Gerry Creager wrote:
> I'm trying to compile v 1.1.1 on a CentOS cluster, with a newly
> added gluster file system. We're running OpenMPI 1.4.1 and PGI 10.3.
> Here's what I've done, so far:
> module load pgi/10
> module load openmpi/1.4.1/pgi/10.3/64
> export cc=mpicc
> export CC=mpiCC
it looks like you are using a C++ compiler to build C tests. I'm a
little surprised that does not work, but we also never test things
that way.
> export FC=mpif90
> export F77=mpif90
> export F90=mpif90
> export CFLAGS="-O2"
> export FFLAGS="-O2 -Msignextend"
> export CPPFLAGS="-DpgiFortran"
While you need -DpgiFortran for serial netcdf, you don't need that for
parallel-netcdf
> ./configure --prefix=/apps/pNetCDF/pgi-10-64 \
> --with-mpi=/apps/openmpi-1.4.1-pgi/ --enable-fortran
Since you specified --with-mpi, you do not need to specify all the
environment variables. No harm in doing both, but as you can see it
allows you to specify weird combinations.
> The fatal error is:
> checking if Fortran "byte" is C "signed char"... configure: error:
> Could not compile conftest.c
> configure:11493: checking if Fortran "byte" is C "signed char"
> configure:11503: mpiCC -c -DpgiFortran -O2 conftest.c
> "conftest.c", line 1: error: incomplete type is not allowed
> void sub_(values)
> "conftest.c", line 1: error: identifier "values" is undefined
> void sub_(values)
> "conftest.c", line 2: error: expected a ";"
> signed char values[4];
> "conftest.c", line 3: error: expected a declaration
> 4 errors detected in the compilation of "conftest.c".
Let me know if the suggestions above make these errors go away.
==rob
Rob Latham
Mathematics and Computer Science Division
Argonne National Lab, IL USA
More information about the parallel-netcdf
