v1.1.1... again
Gerry Creager gerry.creager at tamu.edu
Wed Apr 21 07:32:36 CDT 2010
I'm trying to compile v 1.1.1 on a CentOS cluster, with a newly added
gluster file system. We're running OpenMPI 1.4.1 and PGI 10.3.  Here's
what I've done, so far:
module load pgi/10
module load openmpi/1.4.1/pgi/10.3/64
export cc=mpicc
export CC=mpiCC
export FC=mpif90
export F77=mpif90
export F90=mpif90
export CFLAGS="-O2"
export FFLAGS="-O2 -Msignextend"
export CPPFLAGS="-DpgiFortran"
./configure --prefix=/apps/pNetCDF/pgi-10-64 \
        --with-mpi=/apps/openmpi-1.4.1-pgi/ --enable-fortran
The fatal error is:
checking if Fortran "byte" is C "signed char"... configure: error: Could
not compile conftest.c
Attached is the config.log for reference.  I'm betting it's something
stupidly simple. However, I'm missing it right now.  Any suggestions
appreciated.
Thanks, Gerry
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20100421/32751bc9/attachment-0001.bin>
