Compilation problem when using openmpi-1.3.3
Rich Lee
liequan at slac.stanford.edu
Wed Nov 25 17:38:24 CST 2009
I found that the attached patch I created helped me in compiling
parallel-netcdf 1.1.0 with openmpi (version 1.2.7). Note that the patch
should apply to the original parallel-netcdf 1.1.0 distribution. It
contained addition fix (for C++ compiler) I reported early.
Best regards,
Rich Lee
SLAC National Accelerator Lab
On Tue, Nov 24, 2009 at 9:45 AM, Christoper Daley <cdaley at flash.uchicago.edu
> wrote:
> Hi Kui,
> I applied the patch, and now get a different compilation error:
> mpinetcdf.c: In function ‘ncmpii_postprocess’:
> mpinetcdf.c:8249: error: incompatible type for argument 1 of
> ‘ncmpii_postread’
> mpinetcdf.c:8143: note: expected ‘nc_type’ but argument is of type
> ‘MPI_Datatype’
> mpinetcdf.c: In function ‘ncmpi_iget_var1’:
> mpinetcdf.c:8794: error: incompatible types when assigning to type
> ‘MPI_Datatype’ from type ‘nc_type’
> mpinetcdf.c: In function ‘ncmpi_iget_var’:
> mpinetcdf.c:9078: error: incompatible types when assigning to type
> mpinetcdf.c: In function ‘ncmpi_iget_vara’:
> mpinetcdf.c:9372: error: incompatible types when assigning to type
> mpinetcdf.c: In function ‘ncmpi_iget_vars’:
> mpinetcdf.c:9661: error: incompatible types when assigning to type
> Chris
> Kui Gao wrote:
>> Hi Chris,
>> Thank you very much for your report. It is a bug. "nc_type
>> vartype" should be replaced by "MPI_Datatype vartype" at
>> L66 in src/lib/pnetcdf.h . The patch file is attached.
>> Thanks,
>> Kui.
>> -----Original Message-----
>> From: parallel-netcdf-bounces at lists.mcs.anl.gov
>> [mailto:parallel-netcdf-bounces at lists.mcs.anl.gov] On Behalf Of Rob Ross
>> Sent: Tuesday, November 24, 2009 8:37 AM
>> To: Christoper Daley
>> Cc: parallel-netcdf at lists.mcs.anl.gov
>> Subject: Re: Compilation problem when using openmpi-1.3.3
>> Yeah you're right that does look like a bug. Thanks! -- Rob
>> On Nov 24, 2009, at 12:16 AM, Christoper Daley wrote:
>>> Hi all,
>>> I'm unable to compile parallel-netcdf-1.1.0 with openmpi-1.3.3 compiler
>>> wrapper script (using gcc 4.4.2). I get the following compilation error:
>>> mpinetcdf.c:13216: error: incompatible types when assigning to type
>>> 'nc_type' from type 'MPI_Datatype'
>>> (*request)->vartype = datatype;
>>> This looks like a bug to me as vartype is an enum field in the
>>> NCMPI_Req data structure.
>>> I am able to compile parallel-netcdf-1.1.0 with mpich2-1.1.1p1
>>> compiler wrapper script. I think this is because MPI_Datatype is
>>> a typedef for an integer in mpich, and so can be freely
>>> mixed with enum types. This is not the case in openmpi where
>>> MPI_Datatype is a typedef for a pointer to struct.
>>> Thanks for any help,
>>> Chris
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20091125/eb8d570e/attachment.htm>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20091125/eb8d570e/attachment.obj>
More information about the parallel-netcdf
