Compilation problem when using openmpi-1.3.3
Christoper Daley cdaley at flash.uchicago.edu
Tue Nov 24 11:45:43 CST 2009
Hi Kui,
I applied the patch, and now get a different compilation error:
mpinetcdf.c: In function ‘ncmpii_postprocess’:
mpinetcdf.c:8249: error: incompatible type for argument 1 of
‘ncmpii_postread’
mpinetcdf.c:8143: note: expected ‘nc_type’ but argument is of type
‘MPI_Datatype’
mpinetcdf.c: In function ‘ncmpi_iget_var1’:
mpinetcdf.c:8794: error: incompatible types when assigning to type
‘MPI_Datatype’ from type ‘nc_type’
mpinetcdf.c: In function ‘ncmpi_iget_var’:
mpinetcdf.c:9078: error: incompatible types when assigning to type
mpinetcdf.c: In function ‘ncmpi_iget_vara’:
mpinetcdf.c:9372: error: incompatible types when assigning to type
mpinetcdf.c: In function ‘ncmpi_iget_vars’:
mpinetcdf.c:9661: error: incompatible types when assigning to type
Chris
Kui Gao wrote:
> Hi Chris,
> 	Thank you very much for your report. It is a bug.
> 	"nc_type vartype" should be replaced by "MPI_Datatype vartype" at
> L66 in src/lib/pnetcdf.h .
> 	The patch file is attached.
> 	Thanks,
> Kui.
> -----Original Message-----
> From: parallel-netcdf-bounces at lists.mcs.anl.gov
> [mailto:parallel-netcdf-bounces at lists.mcs.anl.gov] On Behalf Of Rob Ross
> Sent: Tuesday, November 24, 2009 8:37 AM
> To: Christoper Daley
> Cc: parallel-netcdf at lists.mcs.anl.gov
> Subject: Re: Compilation problem when using openmpi-1.3.3
> Yeah you're right that does look like a bug. Thanks! -- Rob
> On Nov 24, 2009, at 12:16 AM, Christoper Daley wrote:
>> Hi all,
>> I'm unable to compile parallel-netcdf-1.1.0 with openmpi-1.3.3
>> compiler
>> wrapper script (using gcc 4.4.2). I get the following compilation
>> error:
>> mpinetcdf.c:13216: error: incompatible types when assigning to type
>> 'nc_type' from type 'MPI_Datatype'
>> (*request)->vartype = datatype;
>> This looks like a bug to me as vartype is an enum field in the
>> NCMPI_Req data structure.
>> I am able to compile parallel-netcdf-1.1.0 with mpich2-1.1.1p1
>> compiler wrapper script. I think this is because MPI_Datatype is
>> a typedef for an integer in mpich, and so can be freely
>> mixed with enum types. This is not the case in openmpi where
>> MPI_Datatype is a typedef for a pointer to struct.
>> Thanks for any help,
>> Chris
