Compilation problem when using openmpi-1.3.3
Rob Ross rross at mcs.anl.gov
Tue Nov 24 08:37:25 CST 2009
Yeah you're right that does look like a bug. Thanks! -- Rob
On Nov 24, 2009, at 12:16 AM, Christoper Daley wrote:
> Hi all,
> I'm unable to compile parallel-netcdf-1.1.0 with openmpi-1.3.3
> compiler
> wrapper script (using gcc 4.4.2). I get the following compilation
> error:
> mpinetcdf.c:13216: error: incompatible types when assigning to type
> ‘nc_type’ from type ‘MPI_Datatype’
> (*request)->vartype = datatype;
> This looks like a bug to me as vartype is an enum field in the
> NCMPI_Req data structure.
> I am able to compile parallel-netcdf-1.1.0 with mpich2-1.1.1p1
> compiler wrapper script. I think this is because MPI_Datatype is
> a typedef for an integer in mpich, and so can be freely
> mixed with enum types. This is not the case in openmpi where
> MPI_Datatype is a typedef for a pointer to struct.
> Thanks for any help,
> Chris
