compiling issue with version 1.1.0 and C++ compiler
Rich Lee
liequan at slac.stanford.edu
Thu Nov 5 12:44:11 CST 2009
Dear parallel netcdf team:
There is a problem in pnetcdf.h in the release 1.1.0. -- The "#endif" on the
line 2132 should move to the end of the file for C++ compiler to be happy to
compile pnetcdf.h included files. Also, the line 261 should be removed where
put #include <mpi.h> inside extern "C" {} for C++ compiler. Thanks.
Best regards,
Rich
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20091105/9bcb8e33/attachment.htm>
More information about the parallel-netcdf
