Problem on Blue Gene/P
Jim Edwards edwards.jim at gmail.com
Tue Jun 16 07:49:01 CDT 2009
Can we make this controllable at runtime possibly through an environment
variable so that one can toggle between modes without recompiling?
Jim
On Mon, Jun 15, 2009 at 9:53 PM, Wei-keng Liao
<wkliao at ece.northwestern.edu>wrote:
> I agree this suggestion. So, there are three options.
> 1. When pnetcdf is built with debug mode (at configure time), we will
> enable
>   the consistency checking across all processes. In this case, the error
>   is considered fatal. For debugging purpose, this should be fine. Note
> that
>   the consistency checking may become costly, especially when the number of
>   processes is large. We do not expect a production pnetcdf to be built
> with
>   the debug mode.
> 2. When built without debug mode, pnetcdf will only take process 0's inputs
> and
>   ignore all others. Also, consistency checking is disabled.
> 3. A middle ground: enable consistency checking but only process 0's inputs
>   are used to define variables, attributes, etc. if inconsistency is
> detected.
>   The error is not fatal, but only gives a warning message.
> If these are fine to the pnetcdf community, we will start to implement
> them.
> Wei-keng
> On Jun 15, 2009, at 8:21 PM, Yu-hengTseng wrote:
>  Thanks Rob and Wei-keng,
>> It will be a good idea to make this check as a warming only. In most
>> realistic applications (including Community Atmospheric Model, within CCSM
>> development), it's almost impossible to have the same dimension for the same
>> array variable within different processes. Usually, 1 or 2 shift. Cheers,
>> Yu-heng Tseng
>> Department of Atmospheric Sciences
>> National Taiwan University
>> No. 1, Sec. 4, Roosevelt Rd, Taipei 106, Taiwan
>> tel: 886-2-33663918
>> email: yhtseng at as.ntu.edu.tw
>> ----- Original Message -----
>> From: wkliao at ece.northwestern.edu
>> To: wkliao at ece.northwestern.edu;parallel-netcdf<
>> parallel-netcdf at lists.mcs.anl.gov>
>> Sent: 2009-06-16 03:00:01
>> Subject: Re: Problem on Blue Gene/P
>> For example, when defining a new 2D array variable and the number of
>> processes is 2, P0 and P1.
>> The metadata (array dimensions, attributes, etc. in define mode) must
>> be the same between P0
>> and P1. If P0 uses 10x10 dimension values and P1 uses 10x11, then this
>> error message will
>> appear.
>> Wei-keng
>> On Jun 15, 2009, at 12:57 PM, Julien Bodart wrote:
>> > Thanks everybody for your help.
>> > I am afraid I don't get the point "your code is defining netcdf
>> > variables and attributes in
>> > a slightly different way on some MPI processes than others"...
>> > depending on what?
>> > Another test I could try is to unable the check made by ncpmi_enddef
>> > if it is possible, and see which kind of output file I get.
>> > I don't know if it is possible to do it easily without recompiling
>> > the library.
>> > I will try anyway the binary debugging.
>> > 2009/6/15 Rob Latham
>> > On Fri, Jun 12, 2009 at 02:19:33PM +0200, Julien Bodart wrote:
>> > > While it does not create any problems on small cases, bigger cases
>> > stop at
>> > > the ncmpi_enddef call on some files (randomly, even with
>> > synchronisation in
>> > > between), saying that there is a mismatch between dimensions.
>> > After many
>> > > check it does not seems that there is something wrong with the
>> > dimensions. I
>> > > have no idea of how to solve the problem. Did anyone had similar
>> > problem?
>> > > Thanks for your help.
>> > Hi Julien. Wei-keng is right: I know you've checked carefully, but
>> > some part of your code is defining netcdf variables and attributes in
>> > a slightly different way on some MPI processes than others.
>> > The main way people debug this is through binary search: comment out
>> > half of the define-mode portion; if the problem persists, comment out
>> > half of the remainder, else, try with the other half.
>> > You're not the first to encounter this problem.  Maybe this could be a
>> > warning and not an error, and maybe we should just have the define
>> > mode view as rank 0 sees it be the one that wins if there's a
>> > discrepancy.   I don't know how many people (if any) rely on the
>> > current behavior to find problems.
>> > ==rob
>> > Rob Latham
>> > Mathematics and Computer Science Division
>> > Argonne National Lab, IL USA
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20090616/51ef10e8/attachment.htm>
