problem with put_att (maximum number of attributes)
Alex Hoffmann ah519 at cam.ac.uk
Fri Feb 20 13:24:41 CST 2009
Thank you for the clarifications.
I included the mpi setup and netCDF output test code and the
corresponding Makefile as attachments.  Maybe it can be of use as a
simple example.
I am currently running my code with the bugs in the output file fixed,
and it seems to be working just fine.
Thanks again,
Lex
Wei-keng Liao wrote:
> Hi, Lex, Please read below.
> On Feb 20, 2009, at 5:13 AM, Alex Hoffmann wrote:
>> Many thanks, Wei-keng, the issue seems to have been tracked down...
>> For reasons that are still not completely clear to me, using trim() for
>> trimming the coordinate variable names and units (lines 480/81, 485/86)
>> seemed to leave a strange character (such as y diacritic or Y accent)
>> trailing on e.g. the units (such as degrees_east).  Though this did not
>> affect the run on its own, any subsequent attribute definition made the
>> code crash.  I fixed this by removing the trim().
> If you called trim() on a string argument in a function, the tailing
> character '\0' will not be passed to the function. So if the string length
> argument has a larger value, the function will include undefined tailing
> characters as part of the string. Glad to know you solve the problem.
>> If I may, I'd like to clarify one further issue with PnetCDF.
>> I initially implemented the code (also a small test program) in
>> collective data mode.  This did not work (the different
>> processes/Cartesian sub domains) did not write their data into the
>> netCDF file.  I then changed the data write statements into independent
>> data mode, with which it worked immediately.  Am I right to use
>> independent data mode for this purpose?
> I am not sure what you meant here.
> Can you post your small test program to the list?
> Wei-keng
>> Thank you very much for your support.
>> Cheers
>> Lex
>>> Hi, Lex,
>>> If this error message "NC definations on multiprocesses conflict"
>>> is the only one you got before every crash, it is most likely the
>>> attribute values are not the same across all processes.
>>> Please check that first, so you can rule out that possibility.
>>> Also, can you check the attributes in the output file for the case
>>> that ran successfully? (using ncmpidump -c filename) This is just
>>> to see if the attributes are the ones you expected. Also, please
>>> make sure the number of attributes created is less than 4K global
>>> or per variable, as Rob indicated.
>>> Wei-keng
>>> On Feb 19, 2009, at 5:53 PM, Alex Hoffmann wrote:
>>>> Dear Wei-keng,
>>>> I understand that the attribute define arguments must be the same
>>>> across
>>>> all processes.   I am also almost certain that the arguments you cited
>>>> are identical across processes but I will perform a check.
>>>> Be this as it may, I get the same arrow message if I uncomment one of
>>>> the text attributes specifying the unit or one of the real attributes
>>>> specifying the fill value, for instance.  There is no possibility that
>>>> these are different across processes as they are introduced straight
>>>> into the function call.  Any check I performed seemed to indicate that
>>>> the problem arises from the number of arguments I defined, and not from
>>>> the arguments themselves, since they work all fine individually.
>>>> I was actually thinking to write the attributes ad-hoc once the dataset
>>>> is defined using regular netCDF functions.  This however seemed to be a
>>>> little elegant solution defeating the purpose of using PnetCDF.
>>>> Thanks,
>>>> Lex
>>>> Wei-keng Liao a écrit :
>>>>> Hi, Lex,
>>>>> PnetCDF requires the attribute define arguments be the same across
>>>>> all processes. This is why you got the error message for defining
>>>>> attribute "history" in line 400, if its value "conflicts" among
>>>>> processes.
>>>>> I think you have got this.
>>>>> I checked your codes. Starting from line 562, you have a few text
>>>>> attributes
>>>>> from des_tgas_picture(i), des_trac_picture(i), des_tpas_picture(i),
>>>>> and des.
>>>>> Similar for out_type == 2. Are you sure their values are all the same
>>>>> across
>>>>> all the processes? May be you can use MPI_Bcast to check if anyone has
>>>>> different value.
>>>>> Wei-keng
>>>>> On Feb 19, 2009, at 11:14 AM, Alex Hoffmann wrote:
>>>>>> Dear Rob
>>>>>> Thanks a lot for your answer.
>>>>>> Isolating the PnetCDF output module from the code as a stand-alone
>>>>>> would
>>>>>> require a substantial effort, and I do not encounter this error
>>>>>> in  my
>>>>>> small test programs.  I attached the output module for reference.
>>>>>> The attribute section that causes trouble is between lines 369-405
>>>>>> (global) and 468-613 (variables).  I am aware that the attribute
>>>>>> history
>>>>>> (line 400) may be problematic as every process may have a slightly
>>>>>> different value (for the time element taken from the fortran function
>>>>>> date_and_time).  Yet this is not the only issue.
>>>>>> If I prematurely exit at line 492, uncommenting any further attribute
>>>>>> definition between 468 and 489 causes a crash with the multiprocesses
>>>>>> conflict.
>>>>>> Note also that the attribute definitions between 558 and 613 only
>>>>>> produce no crash currently because of the print statements on
>>>>>> lines 560
>>>>>> and 591, which made me think that maybe there is an optimization
>>>>>> problem.  What is strange is that if these are not included, the
>>>>>> crash
>>>>>> occurs only when I start writing the first file (movie file,
>>>>>> out_type=2), AND if I leave the first block (if out_type==1)
>>>>>> uncommented, although this block is not even entered in that
>>>>>> particular
>>>>>> case, and vice versa.  Hope this is more or less clear...
>>>>>> Cheers,
>>>>>> Lex
>>>>>> Robert Latham wrote:
>>>>>>> On Thu, Feb 19, 2009 at 10:09:37AM +0000, Alex Hoffmann wrote:
>>>>>>>> Hello,
>>>>>>>> I am getting the same error message as had already been inquired
>>>>>>>> on in
>>>>>>>> this list, i.e.:
>>>>>>>> NC definations on multiprocesses conflict.
>>>>>>>> NOTE: Definitions across all process
>>>>>>>> and this seems to be related somehow randomly to the total
>>>>>>>> number of
>>>>>>>> attributes (global or for each variable) that I intend to write
>>>>>>>> during
>>>>>>>> the the definition phase (and, though I am not sure about this, to
>>>>>>>> the
>>>>>>>> number of processes used to run my F90 parallel code).
>>>>>>>> More precisely, if I uncomment one put_att to replace another, the
>>>>>>>> program still runs, if I do not comment out another one, the
>>>>>>>> program
>>>>>>>> crashes with the above error message.
>>>>>>>> Is there any way of identifying where this problem comes from or is
>>>>>>>> there a maximum amount of attributes (though I don't write an
>>>>>>>> excessive
>>>>>>>> amount of them)?  There is no problem running it on one
>>>>>>>> process(or).
>>>>>>> Maybe you can show us with a small test program how you are
>>>>>>> encountering this error?  The maximum number of attributes is 4k
>>>>>>> (the
>>>>>>> constant NC_MAX_ATTRS).
>>>>>>> ==rob
>>>>>> ______________________________________________________________________
>>>>>> Alex HOFFMANN                     PhD Candidate
>>>>>> Centre for Atmospheric Science
>>>>>> Department of Geography           University of Cambridge
>>>>>> Downing Place, Cambridge CB2 3EN, UK
>>>>>> e-mail: ah519 at cam.ac.uk  tel: +44 (0)1223 766581
>>>>>> www.geog.cam.ac.uk/people/hoffmann/
>>>>>> !-*- F90 -*-
>>>>>> module atham_pnetcdf
>>>>>> ! author:  Alex
>>>>>> HOFFMANN                                             !
>>>>>> ! email:
>>>>>> ah519 at cam.ac.uk                                           !
>>>>>> ! date:    February
>>>>>> 2009                                             !
>>>>>> ! version:
>>>>>> v0.1                                                      !
>>>>>> ! collection of routines for ATHAM PnetCDF
>>>>>> output                    !
>>>>>> ! module is to replace existing atham_netcdf.mod (GL) to write ATHAM
>>>>>> output as netCDF files
>>>>>> ! same as atham_netcdf.mod (AH) but adapted to run with the Parallel
>>>>>> NetCDF API,
>>>>>> !  developed by Northwestern University and Argonne National
>>>>>> Laboratory,
>>>>>> !  which is built on top of MPI-IO (tested with MPICH 2.1)
>>>>>> use precision,    only : kint, kreal, real4, my_real
>>>>>> use atham_module, only : nx, ny, nz, ntx, nty, npx, npy
>>>>>> use atham_module, only : ntgas_picture, ntrac_picture,
>>>>>> ntpas_picture, &
>>>>>>                       ntgas_movie, ntrac_movie, ntpas_movie
>>>>>> implicit none
>>>>>> private
>>>>>> public :: netcdf_data
>>>>>> ! 'pnetcdf.inc' file includes cpp directives that were not understood
>>>>>> at compile-time
>>>>>> ! this is to be changed and hard-wired link to be replaced by the
>>>>>> include 'pnetcdf.inc' command
>>>>>> !include 'pnetcdf.inc'
>>>>>> #include "/usr/local/parallel-netcdf-1.0.1/include/pnetcdf.inc"
>>>>>> include 'mpif.h'
>>>>>> ! ######### tried saving netCDF variable IDs here so that they must
>>>>>> not be retrieved by inquiry
>>>>>> ! ######### if this creates conflict, especially between picture and
>>>>>> movie file, this must be changed
>>>>>>  integer(kint), save                   :: x_dimID, y_dimID,
>>>>>> z_dimID, t_dimID
>>>>>>  integer(kint), save                   :: x_varID, y_varID,
>>>>>> z_varID, t_varID
>>>>>>  integer(kint), save                   :: u_varID, v_varID, w_varID
>>>>>>  integer(kint), save                   :: pnew_varID, tetnew_varID,
>>>>>> tempnew_varID, density_varID
>>>>>>  integer(kint), save                   :: turbhor_varID,
>>>>>> turbver_varID, turblen_varID
>>>>>>  integer(kint), dimension(99), save    :: tgas_varID, trac_varID,
>>>>>> tpas_varID, d_trac_varID
>>>>>>  integer(MPI_OFFSET_KIND), save        :: tcounter
>>>>>>  real(real4), parameter                :: undef = -0.99e33_real4 !
>>>>>> make sure precision of _FillValue and output (NF90_FLOAT) is the same
>>>>>> contains
>>>>>> subroutine netcdf_data(outfile,out_type,timetot)
>>>>>>  ! IF: outfile = picture_file or movie_file (path/filename for
>>>>>> output created in atham_module)
>>>>>>  !     out_type = 1 (picture_file) or 2 (movie_file)
>>>>>>  !     timetot = total simulation time since simulation start
>>>>>>  use atham_module, only : unew, vnew, wnew, pnew, tetnew, tempnew, &
>>>>>>                           density, turbhor, turbver, turblen
>>>>>>  use atham_module, only : tgasnew, tracnew, tpasnew, tracdep
>>>>>>  use atham_module, only : itgas_picture, itrac_picture,
>>>>>> itpas_picture, &
>>>>>>                           itgas_movie, itrac_movie, itpas_movie
>>>>>>  use atham_module, only : mycoor, my_cart, myrank
>>>>>>  character(*),           intent(in   ) :: outfile
>>>>>>  integer(kint),          intent(in   ) :: out_type
>>>>>>  real(kreal),            intent(in   ) :: timetot
>>>>>>  ! local variables                                                  !
>>>>>>  integer(MPI_OFFSET_KIND)              :: nx_mpi,ny_mpi, nz_mpi,
>>>>>> y_cl_mpi
>>>>>>  integer(MPI_OFFSET_KIND)              :: istart,jstart
>>>>>>  integer(kint)                         :: STATUS
>>>>>>  character(len=50)                     :: OP  ! debugging variable
>>>>>> corresponding to the called netCDF OPeration
>>>>>>  integer(kint)                         :: NCID
>>>>>>  integer(kint)                         :: i
>>>>>>  logical                               :: DynMovie_flag,
>>>>>> bounds_control
>>>>>>  integer(kint)                         :: y_st, y_sp, y_cl
>>>>>>  ! replace DynMovie precompiler flag by program flag for more
>>>>>> convenient code structure
>>>>>>  DynMovie_flag = .false.
>>>>>> #ifdef DynMovie
>>>>>>  DynMovie_flag = .true.
>>>>>> #endif
>>>>>>  ! re-assign dimension lengths as an MPI_Offset type (necessary for
>>>>>> the PnetCDF interface)
>>>>>>  ! cut-off subdomain borders
>>>>>>  nx_mpi  = nx-2
>>>>>>  ny_mpi  = ny-2
>>>>>>  nz_mpi  = nz
>>>>>>  ! assign coordinates of first element of each process in the
>>>>>> netCDF file
>>>>>>  istart = mycoor(1)*nx_mpi + 1_MPI_OFFSET_KIND
>>>>>>  jstart = mycoor(2)*ny_mpi + 1_MPI_OFFSET_KIND
>>>>>>  bounds_control = .true. ! debugging flag
>>>>>>  tcounter = tcounter+1_MPI_OFFSET_KIND
>>>>>>  ! === open netCDF dataset: enter data mode ------------------------!
>>>>>>  ! if     dataset does not yet exist (STATUS =  ), create file and
>>>>>> enter data mode
>>>>>>  ! else   continue
>>>>>>  OP = 'open existing netCDF file'
>>>>>>  STATUS = nfmpi_open(my_cart, trim(outfile), NF_WRITE,
>>>>>> MPI_INFO_NULL, NCID)
>>>>>>  if ( STATUS /= nf_noerr ) then
>>>>>>     if (myrank==0) then
>>>>>>        print *, ""
>>>>>>        print *, "P-NetCDF operation: ",trim(OP)
>>>>>>        print *, trim(nfmpi_strerror(STATUS))
>>>>>>        print *, "atham_pnetcdf netcdf_data(): new netCDF file
>>>>>> created: ", outfile
>>>>>>        print *, ""
>>>>>>     end if
>>>>>>     call netcdf_define(outfile,out_type,timetot,NCID)
>>>>>>     tcounter = 1_MPI_OFFSET_KIND ! reset time counter for output if
>>>>>> new file is created
>>>>>>  end if
>>>>>>  ! ---                        write data values --------------------!
>>>>>>  ! unlimited record dimension time (only one process writes the
>>>>>> whole dimension, i.e. accross all processes)
>>>>>>  OP = 'write data values - unlimited dimension t'
>>>>>>  call handle_err(nfmpi_begin_indep_data(NCID))
>>>>>>  if (myrank==0) then
>>>>>>     call handle_err(nfmpi_put_vara_real(NCID, t_varID,
>>>>>> (/tcounter/), (/1_MPI_OFFSET_KIND/), real(timetot,real4)),OP)
>>>>>>  end if
>>>>>>  call handle_err(nfmpi_end_indep_data(NCID))
>>>>>>  ! discriminate between 2D and 3D case for output generation
>>>>>>  if (nty>4) then
>>>>>>     y_st = 2    ! y index start
>>>>>>     y_sp = ny-1 ! y index stop
>>>>>>     y_cl = ny-2 ! y number of columns
>>>>>>  else
>>>>>>     y_st = ny-1 ! 3 in 2D case
>>>>>>     y_sp = ny-1 ! 3 in 2D case
>>>>>>     y_cl = 1
>>>>>>  end if
>>>>>>  y_cl_mpi = y_cl
>>>>>>  ! dynamics data
>>>>>>  OP = 'write data values - data'
>>>>>>  if (out_type == 1 .OR. DynMovie_flag == .true.) then
>>>>>>     call write_data(real(unew,real4),u_varID)
>>>>>>     bounds_control = .false.
>>>>>>     call write_data(real(vnew,   real4),v_varID)
>>>>>>     call write_data(real(wnew,   real4),w_varID)
>>>>>>     call write_data(real(pnew,   real4),pnew_varID)
>>>>>>     call write_data(real(tetnew, real4),tetnew_varID)
>>>>>>     call write_data(real(tempnew,real4),tempnew_varID)
>>>>>>     call write_data(real(density,real4),density_varID)
>>>>>>     call write_data(real(turbhor,real4),turbhor_varID)
>>>>>>     call write_data(real(turbver,real4),turbver_varID)
>>>>>>     call write_data(real(turblen,real4),turblen_varID)
>>>>>>  end if
>>>>>>  ! tracer data
>>>>>>  if (out_type == 1) then
>>>>>>     do i=1,ntgas_picture
>>>>>>        call
>>>>>> write_data(real(tgasnew(:,:,:,itgas_picture(i)),real4),tgas_varID(i))
>>>>>>     enddo
>>>>>>     do i=1,ntrac_picture
>>>>>>        call
>>>>>> write_data(real(tracnew(:,:,:,itrac_picture(i)),real4),trac_varID(i))
>>>>>>     enddo
>>>>>>     do i=1,ntpas_picture
>>>>>>        call
>>>>>> write_data(real(tpasnew(:,:,:,itpas_picture(i)),real4),tpas_varID(i))
>>>>>>     enddo
>>>>>> d_trac_varID(i),(/istart,jstart,tcounter/), &
>>>>>>             (/nx_mpi,y_cl_mpi,1_MPI_OFFSET_KIND/),
>>>>>> real(reshape(tracdep(2:nx-1,y_st:y_sp,itrac_picture(i)),shape=(/nx-2,y_cl,1/)),real4)
>>>>>> ),OP)
>>>>>>     enddo
>>>>>>  else if (out_type == 2) then
>>>>>>     do i=1,ntgas_movie
>>>>>>        call
>>>>>> write_data(real(tgasnew(:,:,:,itgas_movie(i)),real4),tgas_varID(i))
>>>>>>     enddo
>>>>>>     do i=1,ntrac_movie
>>>>>>        call
>>>>>> write_data(real(tracnew(:,:,:,itrac_movie(i)),real4),trac_varID(i))
>>>>>>     enddo
>>>>>>     do i=1,ntpas_movie
>>>>>>        call
>>>>>> write_data(real(tpasnew(:,:,:,itpas_movie(i)),real4),tpas_varID(i))
>>>>>>     enddo
>>>>>>  endif
>>>>>>  ! === close netCDF dataset: exit data mode & save -----------------!
>>>>>>  OP = 'close netCDF file'
>>>>>>  call handle_err(nfmpi_close(NCID))
>>>>>>  if (myrank==0) then
>>>>>>     print *, ''
>>>>>>     print *, 'wrote netCDF output to file ', outfile
>>>>>>     print *, ''
>>>>>>  end if
>>>>>>  contains
>>>>>>    subroutine write_data(array_in,varID)
>>>>>>      ! IF: array_in = data array (3D) to be written to netCDF
>>>>>>      !     varID    = data variable netCDF ID
>>>>>>      use atham_module, only : iflgs ! topography mask: topography
>>>>>> (iflgs=0) remains undef
>>>>>>      use atham_module, only  : myrank
>>>>>>      real(real4),dimension(nx,ny,nz), intent (in   )   :: array_in
>>>>>>      integer(kint),                intent(in   )       :: varID
>>>>>>      ! local variables                                              !
>>>>>>      real(real4), dimension(nx,ny,nz)            :: array_masked
>>>>>>      ! dimensions & bounds control
>>>>>>      integer(MPI_OFFSET_KIND)                    :: dimlenx,
>>>>>> dimleny, dimlenz, dimlent
>>>>>>      integer(kint), dimension(NF_max_var_dims)   :: dimIDs
>>>>>>      if (myrank == 0) then
>>>>>>         if (bounds_control) then
>>>>>>            print *, ''
>>>>>>            print *, 'atham var in xyz              ',shape(array_in)
>>>>>>            print *, 'atham var reshaped to xyzt
>>>>>> ',shape(reshape(array_in(2:nx-1,y_st:y_sp,1:nz),shape=(/nx-2,y_cl,nz,1/)))
>>>>>>            call handle_err(nfmpi_inq_vardimid(NCID, u_varID,
>>>>>> dimIDs)) ! taken unew as ref
>>>>>>            call handle_err(nfmpi_inq_dimlen(NCID, dimIDs(1),
>>>>>> dimlenx))
>>>>>>            call handle_err(nfmpi_inq_dimlen(NCID, dimIDs(2),
>>>>>> dimleny))
>>>>>>            call handle_err(nfmpi_inq_dimlen(NCID, dimIDs(3),
>>>>>> dimlenz))
>>>>>>            call handle_err(nfmpi_inq_dimlen(NCID, dimIDs(4),
>>>>>> dimlent))
>>>>>>            print *, 'netCDF var dimensions in xyzt
>>>>>> ',dimlenx,dimleny,dimlenz,dimlent
>>>>>>         end if
>>>>>>      end if
>>>>>>      ! mask topography
>>>>>>      where (iflgs == 1)
>>>>>>         array_masked = array_in
>>>>>>      elsewhere
>>>>>>         array_masked = undef
>>>>>>      endwhere
>>>>>>      ! mask control
>>>>>>      !print *, ''
>>>>>>      !print *, 'topography mask'
>>>>>>      !print *, iflgs(1:5,3,3)
>>>>>>      !print *, iflgs(1:5,3,2)
>>>>>>      !print *, iflgs(1:5,3,1)
>>>>>>      !print *, ''
>>>>>>      !print *, 'masked variable array'
>>>>>>      !print *, array_masked(:,3,3)
>>>>>>      !print *, array_masked(:,3,2)
>>>>>>      !print *, array_masked(:,3,1)
>>>>>>      !print *, ''
>>>>>> varID,(/istart,jstart,1_MPI_OFFSET_KIND,tcounter/), &
>>>>>>           (/nx_mpi,y_cl_mpi,nz_mpi,1_MPI_OFFSET_KIND/),
>>>>>> reshape(array_masked(2:nx-1,y_st:y_sp,1:nz),shape=(/nx-2,y_cl,nz,1/))
>>>>>> ),OP)
>>>>>>    end subroutine write_data
>>>>>> end subroutine netcdf_data
>>>>>> subroutine netcdf_define(outfile,out_type,timetot,ncid_def)
>>>>>>  !     timetot = simulation time since simulation start (from
>>>>>> atham/atham_out)
>>>>>>  !     ncid_def = netCDF ID assigned to file during creation
>>>>>>  use atham_module, only   : var_tgas_picture,
>>>>>> var_tgas_movie,           &
>>>>>>                             des_tgas_picture,
>>>>>> des_tgas_movie,           &
>>>>>>                             var_trac_picture,
>>>>>> var_trac_movie,           &
>>>>>>                             des_trac_picture,
>>>>>> des_trac_movie,           &
>>>>>>                             var_tpas_picture,
>>>>>> var_tpas_movie,           &
>>>>>>                             des_tpas_picture, des_tpas_movie
>>>>>>  use atham_module, only   : iindex, spinup, nrep, periodt
>>>>>>  use atham_module, only   : volcano_setup,
>>>>>> coignimbrite_setup,          &
>>>>>>                             nuclear_setup, convection_setup,
>>>>>> procsconfig_setup
>>>>>>  use atham_module, only   : x, y, z, xg, yg
>>>>>>  use atham_module, only   : grid2geo, sim_d_YYYY, sim_d_MM,
>>>>>> sim_d_DD,   &
>>>>>>                             sim_t_hh, sim_t_mm, sim_t_ss
>>>>>>  use atham_module, only   : my_cart, myrank
>>>>>>  integer(kint),          intent(  out) :: ncid_def
>>>>>>  ! local variables                                                  !
>>>>>>  integer(MPI_OFFSET_KIND)              :: ntx_mpi,nty_mpi,nz_mpi
>>>>>>  integer(kint)                         :: i
>>>>>>  character(len=50)                     :: var, des
>>>>>>  real(kreal)                           :: toffset
>>>>>>  real(real4)                           :: coord_scale,
>>>>>> coord_x_offset, coord_y_offset, coord_t_offset
>>>>>>  character(len=3)                      :: coord_x_name,
>>>>>> coord_y_name, coord_z_name
>>>>>>  character(len=4)                      :: coord_t_name
>>>>>>  character(len=9)                      :: coord_x_lname,
>>>>>> coord_y_lname
>>>>>>  character(len=13)                     :: coord_x_units,
>>>>>> coord_y_units
>>>>>>  character(len=33)                     :: coord_t_units
>>>>>>  character(len=8)                      :: date
>>>>>>  character(len=10)                     :: time
>>>>>>  character(len=19)                     :: simdatetime
>>>>>>  character(len=10)                     :: simdate
>>>>>>  character(len=20)                     :: login
>>>>>>  character(len=63)                     :: hist_string
>>>>>>  integer(kint)                         :: isetup
>>>>>>  character(len=12)                     :: model_setup(6)
>>>>>>  data model_setup /'volcano     ', 'coignimbrite', 'nuclear     ',
>>>>>> 'convection  ', 'procsconfig ','unknown     '/
>>>>>> #ifdef DynMovie
>>>>>> #endif
>>>>>>  ! cut-off domain borders
>>>>>>  ntx_mpi = ntx-2
>>>>>>  nty_mpi = nty-2
>>>>>>  nz_mpi  = nz
>>>>>>  ! convert date and time integers into string 'YYYYMMDD hh:mm:ss'
>>>>>>  write (simdatetime,10)
>>>>>> sim_d_YYYY,sim_d_MM,sim_d_DD,sim_t_hh,sim_t_mm,sim_t_ss
>>>>>> 10 format (I4,'-',I2,'-',I2,1X,I2,':',I2,':',I2)
>>>>>>  simdate = simdatetime(1:10)
>>>>>>  ! switch between cartesian axes/time (default) and geographic
>>>>>> axes/date (linear approx)
>>>>>>  coord_scale    = 1._real4
>>>>>>  coord_x_offset = 0._real4
>>>>>>  coord_x_name   = 'x  '
>>>>>>  coord_x_lname  = 'x_coor   '
>>>>>>  coord_x_units  = 'm            '
>>>>>>  coord_y_offset = 0._real4
>>>>>>  coord_y_name   = 'y  '
>>>>>>  coord_y_lname  = 'y_coor   '
>>>>>>  coord_y_units  = 'm            '
>>>>>>  coord_z_name   = 'z  '
>>>>>>  coord_t_offset = 0._real4
>>>>>>  coord_t_name   = 'time'
>>>>>>  coord_t_units  = 'sec                              '
>>>>>>  if (grid2geo) then
>>>>>>     call
>>>>>> gridconvert(coord_scale,coord_x_offset,coord_x_name,coord_x_lname,coord_x_units,
>>>>>> coord_y_offset,coord_y_name,coord_y_lname,coord_y_units, &
>>>>>> coord_z_name,coord_t_offset,coord_t_name,coord_t_units)
>>>>>>  end if
>>>>>>  ! === create netCDF dataset: enter define mode --------------------!
>>>>>>  OP = 'enter define mode'
>>>>>>  call handle_err(nfmpi_create(my_cart, trim(outfile), 0,
>>>>>> MPI_INFO_NULL,NCID),OP)
>>>>>>  ncid_def = NCID
>>>>>>  ! === create netCDF dataset: assign metadata ----------------------!
>>>>>>  ! ---                        set global attributes ----------------!
>>>>>>  OP = 'set global attributes'
>>>>>>     toffset = timetot - spinup
>>>>>>     call handle_err(nfmpi_put_att_text(NCID, NF_GLOBAL, 'title',
>>>>>> 13_MPI_OFFSET_KIND, 'atham_picture'),OP)
>>>>>>  else
>>>>>>     toffset = timetot - spinup - nrep*periodt
>>>>>> 11_MPI_OFFSET_KIND, 'atham_movie'),OP)
>>>>>>  end if
>>>>>>  call handle_err(nfmpi_put_att_text(NCID, NF_GLOBAL, 'content',
>>>>>> 223_MPI_OFFSET_KIND, &
>>>>>>       'This data corresponds to a simulation run of the
>>>>>> mesoscale-beta/gamma type non-hydrostatic Active Tracer
>>>>>> High-resolution Atmospheric Model ATHAM ' &
>>>>>>       // '(Oberhuber et al., 1998, Herzog, 1998), for a setup as
>>>>>> specified under history'),OP) ! ######### add further description as
>>>>>> necessary
>>>>>>  call handle_err(nfmpi_put_att_text(NCID, NF_GLOBAL, 'version',
>>>>>> 21_MPI_OFFSET_KIND, 'no current versioning'),OP) ! ######### change
>>>>>> once available
>>>>>>  call date_and_time(date, time)
>>>>>>  call getlog(login)
>>>>>>  if (volcano_setup) then
>>>>>>     isetup=1
>>>>>>  else if (coignimbrite_setup) then
>>>>>>     isetup=2
>>>>>>  else if (nuclear_setup) then
>>>>>>     isetup=3
>>>>>>  else if (convection_setup) then
>>>>>>     isetup=4
>>>>>>  else if (procsconfig_setup) then
>>>>>>     isetup=5
>>>>>>  else
>>>>>>     isetup=6
>>>>>>  end if
>>>>>>  hist_string = trim(date//' '//time//'  '//trim(login)//'  atham
>>>>>> '//model_setup(isetup))
>>>>>> !    call handle_err(nfmpi_put_att_text(NCID, NF_GLOBAL, 'history',
>>>>>> 63_MPI_OFFSET_KIND, hist_string),OP) ! 1 line/modification:  - cmd
>>>>>> arg
>>>>>> 'Conventions', 28_MPI_OFFSET_KIND, 'COARDS,
>>>>>> //cf-pcmdi.llnl.gov/'),OP)
>>>>>> 'sim_onset_date_time', 19_MPI_OFFSET_KIND, simdatetime),OP)
>>>>>> !    call handle_err(nfmpi_put_att_real(NCID, NF_GLOBAL,
>>>>>> 'sim_time_offset', NF_FLOAT, 1_MPI_OFFSET_KIND,
>>>>>> real(toffset,real4)),OP)
>>>>>> 'x_zoom_location', NF_FLOAT, 1_MPI_OFFSET_KIND,
>>>>>> real(x(max(1,iindex)),real4)),OP)
>>>>>>  ! ---                        define dimensions --------------------!
>>>>>>  OP = 'define dimensions'
>>>>>>  call handle_err(nfmpi_def_dim(NCID, trim(coord_x_name),
>>>>>> ntx_mpi,             x_dimID),OP)
>>>>>>  if (nty>4) then
>>>>>>     call handle_err(nfmpi_def_dim(NCID, trim(coord_y_name),
>>>>>> nty_mpi,             y_dimID),OP)
>>>>>>  else
>>>>>> 1_MPI_OFFSET_KIND,   y_dimID),OP)
>>>>>>  end if
>>>>>>  call handle_err(nfmpi_def_dim(NCID, trim(coord_z_name),
>>>>>> nz_mpi,              z_dimID),OP)
>>>>>>  call handle_err(nfmpi_def_dim(NCID, coord_t_name,
>>>>>> nfmpi_unlimited,     t_dimID),OP)
>>>>>>  ! ---                        define variables ---------------------!
>>>>>>  ! dimensions
>>>>>>  OP = 'define variables - dimensions'
>>>>>>  call handle_err(nfmpi_def_var(NCID, trim(coord_x_name),
>>>>>> NF_FLOAT, 1, x_dimID, x_varID),OP)
>>>>>>  call handle_err(nfmpi_def_var(NCID, trim(coord_y_name),
>>>>>> NF_FLOAT, 1, y_dimID, y_varID),OP)
>>>>>>  call handle_err(nfmpi_def_var(NCID, trim(coord_z_name),
>>>>>> NF_FLOAT, 1, z_dimID, z_varID),OP)
>>>>>>  call handle_err(nfmpi_def_var(NCID, coord_t_name,
>>>>>> NF_FLOAT, 1, t_dimID, t_varID),OP)
>>>>>>  ! dynamics data
>>>>>>  OP = 'define variables - data'
>>>>>>     call handle_err(nfmpi_def_var(NCID, 'u',       NF_FLOAT, 4,
>>>>>> (/x_dimID,y_dimID,z_dimID,t_dimID/), u_varID),OP)
>>>>>>     call handle_err(nfmpi_def_var(NCID, 'v',       NF_FLOAT, 4,
>>>>>> (/x_dimID,y_dimID,z_dimID,t_dimID/), v_varID),OP)
>>>>>>     call handle_err(nfmpi_def_var(NCID, 'w',       NF_FLOAT, 4,
>>>>>> (/x_dimID,y_dimID,z_dimID,t_dimID/), w_varID),OP)
>>>>>>     call handle_err(nfmpi_def_var(NCID, 'pnew',    NF_FLOAT, 4,
>>>>>> (/x_dimID,y_dimID,z_dimID,t_dimID/), pnew_varID),OP)
>>>>>>     call handle_err(nfmpi_def_var(NCID, 'tetnew',  NF_FLOAT, 4,
>>>>>> (/x_dimID,y_dimID,z_dimID,t_dimID/), tetnew_varID),OP)
>>>>>>     call handle_err(nfmpi_def_var(NCID, 'tempnew', NF_FLOAT, 4,
>>>>>> (/x_dimID,y_dimID,z_dimID,t_dimID/), tempnew_varID),OP)
>>>>>>     call handle_err(nfmpi_def_var(NCID, 'density', NF_FLOAT, 4,
>>>>>> (/x_dimID,y_dimID,z_dimID,t_dimID/), density_varID),OP)
>>>>>>     call handle_err(nfmpi_def_var(NCID, 'turbhor', NF_FLOAT, 4,
>>>>>> (/x_dimID,y_dimID,z_dimID,t_dimID/), turbhor_varID),OP)
>>>>>>     call handle_err(nfmpi_def_var(NCID, 'turbver', NF_FLOAT, 4,
>>>>>> (/x_dimID,y_dimID,z_dimID,t_dimID/), turbver_varID),OP)
>>>>>>     call handle_err(nfmpi_def_var(NCID, 'turblen', NF_FLOAT, 4,
>>>>>> (/x_dimID,y_dimID,z_dimID,t_dimID/), turblen_varID),OP)
>>>>>>  end if
>>>>>>  ! tracer data
>>>>>>        call handle_err(nfmpi_def_var(NCID, var_tgas_picture(i),
>>>>>> NF_FLOAT, 4, (/x_dimID,y_dimID,z_dimID,t_dimID/), tgas_varID(i)),OP)
>>>>>>     enddo
>>>>>>        call handle_err(nfmpi_def_var(NCID, var_trac_picture(i),
>>>>>> NF_FLOAT, 4, (/x_dimID,y_dimID,z_dimID,t_dimID/), trac_varID(i)),OP)
>>>>>>     enddo
>>>>>>        call handle_err(nfmpi_def_var(NCID, var_tpas_picture(i),
>>>>>> NF_FLOAT, 4, (/x_dimID,y_dimID,z_dimID,t_dimID/), tpas_varID(i)),OP)
>>>>>>     enddo
>>>>>>        var='d_'//trim(var_trac_picture(i))
>>>>>>        call handle_err(nfmpi_def_var(NCID, var,
>>>>>> NF_FLOAT, 3, (/x_dimID,y_dimID,t_dimID/), d_trac_varID(i)),OP)
>>>>>>     enddo
>>>>>>     do i=1,ntgas_movie
>>>>>>        call handle_err(nfmpi_def_var(NCID, var_tgas_movie(i),
>>>>>>     enddo
>>>>>>     do i=1,ntrac_movie
>>>>>>        call handle_err(nfmpi_def_var(NCID, var_trac_movie(i),
>>>>>>     enddo
>>>>>>     do i=1,ntpas_movie
>>>>>>        call handle_err(nfmpi_def_var(NCID, var_tpas_movie(i),
>>>>>>     enddo
>>>>>>  endif
>>>>>>  ! ---                        assign attributes --------------------!
>>>>>>  ! common attributes: long_name, units, valid_range, scale_factor,
>>>>>> add_offset, _FillValue, history, conventions
>>>>>>  ! dimensions
>>>>>>  OP = 'assign attributes - dimensions'
>>>>>>  call handle_err(nfmpi_put_att_text(NCID, x_varID,
>>>>>> 'long_name',               9_MPI_OFFSET_KIND,
>>>>>> trim(coord_x_lname)),OP)
>>>>>> 'units',                  13_MPI_OFFSET_KIND,
>>>>>> trim(coord_x_units)),OP)
>>>>>> !    call handle_err(nfmpi_put_att_real(NCID, x_varID,
>>>>>> 'scale_factor', NF_FLOAT,  1_MPI_OFFSET_KIND, coord_scale),OP)
>>>>>> 'add_offset',   NF_FLOAT,  1_MPI_OFFSET_KIND, coord_x_offset),OP)
>>>>>>  call handle_err(nfmpi_put_att_text(NCID, y_varID,
>>>>>> trim(coord_y_lname)),OP)
>>>>>> trim(coord_y_units)),OP)
>>>>>> !    call handle_err(nfmpi_put_att_real(NCID, y_varID,
>>>>>> 'add_offset',   NF_FLOAT,  1_MPI_OFFSET_KIND, coord_y_offset),OP)
>>>>>>  call handle_err(nfmpi_put_att_text(NCID, z_varID,
>>>>>> 'long_name',               6_MPI_OFFSET_KIND, 'height'),OP)
>>>>>> 'units',                   1_MPI_OFFSET_KIND, 'm'),OP)
>>>>>> !    call handle_err(nfmpi_put_att_text(NCID, z_varID,
>>>>>> 'positive',                2_MPI_OFFSET_KIND, 'up'),OP)
>>>>>>  call handle_err(nfmpi_put_att_text(NCID, t_varID,
>>>>>> 'long_name',               4_MPI_OFFSET_KIND, coord_t_name),OP)
>>>>>> 'units',                  33_MPI_OFFSET_KIND,
>>>>>> trim(coord_t_units)),OP)
>>>>>> !    call handle_err(nfmpi_put_att_real(NCID, t_varID,
>>>>>> 'add_offset',   NF_FLOAT,  1_MPI_OFFSET_KIND, coord_t_offset),OP)
>>>>>> !    OP = 'exit define mode NOW for testing
>>>>>> ****************************************************' ! ah_testing
>>>>>> !    call
>>>>>> handle_err(nfmpi_enddef(NCID),OP)
>>>>>> ! ah_testing ********************************
>>>>>>  ! dynamics data
>>>>>>  OP = 'assign attributes - data'
>>>>>> !       call handle_err(nfmpi_put_att_text(NCID, u_varID,
>>>>>> 'long_name',              6_MPI_OFFSET_KIND, 'x_wind'),OP)
>>>>>> 'units',                  7_MPI_OFFSET_KIND, 'm sec-1'),OP)
>>>>>> !       call handle_err(nfmpi_put_att_real(NCID, u_varID,
>>>>>> 'scale_factor',NF_FLOAT,  1_MPI_OFFSET_KIND, 1.),OP)
>>>>>> 'add_offset',  NF_FLOAT,  1_MPI_OFFSET_KIND, 0.0),OP)
>>>>>> '_FillValue',  NF_FLOAT,  1_MPI_OFFSET_KIND, undef),OP)
>>>>>> !       call handle_err(nfmpi_put_att_text(NCID, v_varID,
>>>>>> 'long_name',              6_MPI_OFFSET_KIND, 'y_wind'),OP)
>>>>>> !       call handle_err(nfmpi_put_att_real(NCID, v_varID,
>>>>>> !       call handle_err(nfmpi_put_att_text(NCID, w_varID,
>>>>>> 'long_name',             19_MPI_OFFSET_KIND,
>>>>>> 'upward_air_velocity'),OP)
>>>>>> !       call handle_err(nfmpi_put_att_real(NCID, w_varID,
>>>>>> !       call handle_err(nfmpi_put_att_text(NCID, pnew_varID,
>>>>>> 'long_name',             20_MPI_OFFSET_KIND,
>>>>>> 'air_pressure_anomaly'),OP)
>>>>>> 'units',                  2_MPI_OFFSET_KIND, 'Pa'),OP)
>>>>>> !       call handle_err(nfmpi_put_att_real(NCID, pnew_varID,
>>>>>> !       call handle_err(nfmpi_put_att_text(NCID, tetnew_varID,
>>>>>> 'long_name',             25_MPI_OFFSET_KIND,
>>>>>> 'air_potential_temperature'),OP)
>>>>>> 'units',                  1_MPI_OFFSET_KIND, 'K'),OP)
>>>>>> !       call handle_err(nfmpi_put_att_real(NCID, tetnew_varID,
>>>>>> !       call handle_err(nfmpi_put_att_text(NCID, tempnew_varID,
>>>>>> 'long_name',             15_MPI_OFFSET_KIND, 'air_temperature'),OP)
>>>>>> 'units',                  7_MPI_OFFSET_KIND, 'Celsius'),OP)
>>>>>> !       call handle_err(nfmpi_put_att_real(NCID, tempnew_varID,
>>>>>> 'add_offset',  NF_FLOAT,  1_MPI_OFFSET_KIND, -273.15),OP)
>>>>>> !       call handle_err(nfmpi_put_att_text(NCID, density_varID,
>>>>>> 'long_name',             11_MPI_OFFSET_KIND, 'air_density'),OP)
>>>>>> 'units',                  6_MPI_OFFSET_KIND, 'kg m-3'),OP)
>>>>>> !       call handle_err(nfmpi_put_att_real(NCID, density_varID,
>>>>>> !       call handle_err(nfmpi_put_att_text(NCID, turbhor_varID,
>>>>>> 'long_name',             15_MPI_OFFSET_KIND, 'hor_turb_energy'),OP)
>>>>>> 'units',                  8_MPI_OFFSET_KIND, 'm2 sec-2'),OP)
>>>>>> !       call handle_err(nfmpi_put_att_real(NCID, turbhor_varID,
>>>>>> !       call handle_err(nfmpi_put_att_text(NCID, turbver_varID,
>>>>>> 'long_name',             15_MPI_OFFSET_KIND, 'ver_turb_energy'),OP)
>>>>>> !       call handle_err(nfmpi_put_att_real(NCID, turbver_varID,
>>>>>> !       call handle_err(nfmpi_put_att_text(NCID, turblen_varID,
>>>>>> 'long_name',             17_MPI_OFFSET_KIND, 'turb_length_scale'),OP)
>>>>>> !       call handle_err(nfmpi_put_att_real(NCID, turblen_varID,
>>>>>>  end if
>>>>>>  ! tracer data
>>>>>>     print *, 'NetCDF output type (1-picture,2-movie) ',out_type !
>>>>>> #####  DO NOT REMOVE!!! optimization problem, trace source
>>>>>>        call handle_err(nfmpi_put_att_text(NCID, tgas_varID(i),
>>>>>> 'long_name',             25_MPI_OFFSET_KIND, des_tgas_picture(i)),OP)
>>>>>> 'units',                  9_MPI_OFFSET_KIND, 'gram kg-1'),OP)
>>>>>>        call handle_err(nfmpi_put_att_real(NCID, tgas_varID(i),
>>>>>> 'scale_factor',NF_FLOAT,  1_MPI_OFFSET_KIND, 1000.),OP)
>>>>>>     enddo
>>>>>>        call handle_err(nfmpi_put_att_text(NCID, trac_varID(i),
>>>>>> 'long_name',             25_MPI_OFFSET_KIND, des_trac_picture(i)),OP)
>>>>>>        call handle_err(nfmpi_put_att_real(NCID, trac_varID(i),
>>>>>>     enddo
>>>>>>        call handle_err(nfmpi_put_att_text(NCID, tpas_varID(i),
>>>>>> 'long_name',             25_MPI_OFFSET_KIND, des_tpas_picture(i)),OP)
>>>>>> 'units',                  1_MPI_OFFSET_KIND, '%'),OP)
>>>>>>        call handle_err(nfmpi_put_att_real(NCID, tpas_varID(i),
>>>>>> 'scale_factor',NF_FLOAT,  1_MPI_OFFSET_KIND, 100.),OP)
>>>>>>     enddo
>>>>>>        des='deposited_'//trim(des_trac_picture(i))
>>>>>>        call handle_err(nfmpi_put_att_text(NCID, d_trac_varID(i),
>>>>>> 'long_name',             35_MPI_OFFSET_KIND, des),OP)
>>>>>> 'units',                  9_MPI_OFFSET_KIND, 'gram m-2'),OP)
>>>>>>        call handle_err(nfmpi_put_att_real(NCID, d_trac_varID(i),
>>>>>>     enddo
>>>>>>     do i=1,ntgas_movie
>>>>>> 'long_name',             25_MPI_OFFSET_KIND, des_tgas_movie(i)),OP)
>>>>>>     enddo
>>>>>>     do i=1,ntrac_movie
>>>>>> 'long_name',             25_MPI_OFFSET_KIND, des_trac_movie(i)),OP)
>>>>>>     enddo
>>>>>>     do i=1,ntpas_movie
>>>>>> 'long_name',             25_MPI_OFFSET_KIND, des_tpas_movie(i)),OP)
>>>>>>     enddo
>>>>>>  end if
>>>>>>  ! === create netCDF dataset: exit define mode, enter data mode ----!
>>>>>>  OP = 'exit define mode'
>>>>>>  call handle_err(nfmpi_enddef(NCID),OP)
>>>>>>  ! dimensions (only one process writes the whole dimension, i.e.
>>>>>>  OP = 'write data values - dimensions'
>>>>>>  if (myrank==0) then
>>>>>>     call handle_err(nfmpi_put_vara_real(NCID, x_varID,
>>>>>> (/1_MPI_OFFSET_KIND/), (/ntx_mpi/),real(xg(2:ntx-1),real4)),OP)
>>>>>>     if (nty>4) then
>>>>>>        call handle_err(nfmpi_put_vara_real(NCID, y_varID,
>>>>>> (/1_MPI_OFFSET_KIND/), (/nty_mpi/), real(yg(2:nty-1),real4)),OP)
>>>>>>     else
>>>>>> (/1_MPI_OFFSET_KIND/), (/1_MPI_OFFSET_KIND/),
>>>>>> real(yg(nty-1),real4)),OP)
>>>>>>     end if
>>>>>>     call handle_err(nfmpi_put_vara_real(NCID, z_varID,
>>>>>> (/1_MPI_OFFSET_KIND/), (/nz_mpi/), real(z,real4)),OP)
>>>>>>  end if
>>>>>>  contains
>>>>>>    subroutine
>>>>>> gridconvert(cd_scale,cd_x_offset,cd_x_name,cd_x_lname,cd_x_units, &
>>>>>> cd_y_offset,cd_y_name,cd_y_lname,cd_y_units, &
>>>>>> cd_z_name,cd_t_offset,cd_t_name,cd_t_units)
>>>>>>      ! IF: cd_* = coordinate parameters
>>>>>>      ! linear conversion from cartesian grid into lon/lat system    !
>>>>>>      ! only valid as first approxiamtion over small domains         !
>>>>>>      ! to be replaced once a dyn core in a lat/lon system available !
>>>>>>      use atham_module, only             : deglat_start, deglon_start
>>>>>>      use phys_constants, only           : pi
>>>>>>      real(real4),        intent(inout) :: cd_scale, cd_x_offset,
>>>>>> cd_y_offset, cd_t_offset
>>>>>>      character(len=3),   intent(inout) :: cd_x_name, cd_y_name,
>>>>>> cd_z_name
>>>>>>      character(len=4),   intent(inout) :: cd_t_name
>>>>>>      character(len=9),   intent(inout) :: cd_x_lname, cd_y_lname
>>>>>>      character(len=13),  intent(inout) :: cd_x_units, cd_y_units
>>>>>>      character(len=33),  intent(inout) :: cd_t_units
>>>>>>      ! local variables                                              !
>>>>>>      real(kreal)                       :: r
>>>>>>      real(kreal), parameter            :: a = 6378137._kreal     !
>>>>>> (WGS 84)
>>>>>>      real(kreal), parameter            :: b = 6356752.3142_kreal !
>>>>>> (WGS 84)
>>>>>>      ! ellipsoid radius at ATHAM domain start
>>>>>>      r = a*b / sqrt((b*b*(cos(deglat_start*pi/180._kreal))**2
>>>>>> )+(a*a*(sin(deglat_start*pi/180._kreal))**2 ))
>>>>>>      cd_scale    = real((1/r) * (180._kreal/pi),real4)
>>>>>>      cd_x_offset = deglon_start
>>>>>>      cd_x_name   = 'lon'
>>>>>>      cd_x_lname  = 'longitude'
>>>>>>      cd_x_units  = 'degrees_east '
>>>>>>      cd_y_offset = deglat_start
>>>>>>      cd_y_name   = 'lat'
>>>>>>      cd_y_lname  = 'latitude '
>>>>>>      cd_y_units  = 'degrees_north'
>>>>>>      cd_z_name   = 'lev'
>>>>>>      coord_t_offset = real((sim_t_hh*3600 + sim_t_mm*60
>>>>>> +sim_t_ss),real4)
>>>>>>      coord_t_name   = 'date'
>>>>>>      coord_t_units  = 'seconds since '//simdate//' 00:00:00 [local]'
>>>>>>      ! COARDS conventions require time zone from UTC to be specified
>>>>>>      ! not necessary for local area version of ATHAM
>>>>>>    end subroutine gridconvert
>>>>>> end subroutine netcdf_define
>>>>>> subroutine handle_err(status,op)
>>>>>> integer,                    intent (in   ) :: status
>>>>>> character(len=*), optional, intent (in   ) :: op
>>>>>> if ( status /= nf_noerr ) then
>>>>>>   if (myrank==0) then
>>>>>>      print *, ""
>>>>>>      print *, "P-NetCDF operation: ",trim(op)
>>>>>>      print *, trim(nfmpi_strerror(status))
>>>>>>      print *, "atham_pnetcdf error: program execution stopped"
>>>>>>      print *, ""
>>>>>>      stop
>>>>>>   end if
>>>>>> end if
>>>>>> return
>>>>>> end subroutine handle_err
>>>>>> end module atham_pnetcdf
Type: text/x-fortran
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20090220/4fad630f/attachment-0001.bin>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20090220/4fad630f/attachment-0001.diff>
