problem with put_att (maximum number of attributes)
Wei-keng Liao wkliao at ece.northwestern.edu
Fri Feb 20 10:13:25 CST 2009
Hi, Lex, Please read below.
On Feb 20, 2009, at 5:13 AM, Alex Hoffmann wrote:
> Many thanks, Wei-keng, the issue seems to have been tracked down...
> For reasons that are still not completely clear to me, using trim()
> for
> trimming the coordinate variable names and units (lines 480/81,
> 485/86)
> seemed to leave a strange character (such as y diacritic or Y accent)
> trailing on e.g. the units (such as degrees_east).  Though this did
> not
> affect the run on its own, any subsequent attribute definition made
> the
> code crash.  I fixed this by removing the trim().
If you called trim() on a string argument in a function, the tailing
character '\0' will not be passed to the function. So if the string
length
argument has a larger value, the function will include undefined tailing
characters as part of the string. Glad to know you solve the problem.
> If I may, I'd like to clarify one further issue with PnetCDF.
> I initially implemented the code (also a small test program) in
> collective data mode.  This did not work (the different
> processes/Cartesian sub domains) did not write their data into the
> netCDF file.  I then changed the data write statements into
> independent
> data mode, with which it worked immediately.  Am I right to use
> independent data mode for this purpose?
I am not sure what you meant here.
Can you post your small test program to the list?
Wei-keng
> Thank you very much for your support.
> Cheers
> Lex
> Wei-keng Liao wrote:
>> Hi, Lex,
>> If this error message "NC definations on multiprocesses conflict"
>> is the only one you got before every crash, it is most likely the
>> attribute values are not the same across all processes.
>> Please check that first, so you can rule out that possibility.
>> Also, can you check the attributes in the output file for the case
>> that ran successfully? (using ncmpidump -c filename) This is just
>> to see if the attributes are the ones you expected. Also, please
>> make sure the number of attributes created is less than 4K global
>> or per variable, as Rob indicated.
>> Wei-keng
>> On Feb 19, 2009, at 5:53 PM, Alex Hoffmann wrote:
>>> Dear Wei-keng,
>>> I understand that the attribute define arguments must be the same
>>> across
>>> all processes.   I am also almost certain that the arguments you
>>> cited
>>> are identical across processes but I will perform a check.
>>> Be this as it may, I get the same arrow message if I uncomment one
>>> of
>>> the text attributes specifying the unit or one of the real
>>> attributes
>>> specifying the fill value, for instance.  There is no possibility
>>> that
>>> these are different across processes as they are introduced straight
>>> into the function call.  Any check I performed seemed to indicate
>>> that
>>> the problem arises from the number of arguments I defined, and not
>>> from
>>> the arguments themselves, since they work all fine individually.
>>> I was actually thinking to write the attributes ad-hoc once the
>>> dataset
>>> is defined using regular netCDF functions.  This however seemed to
>>> be a
>>> little elegant solution defeating the purpose of using PnetCDF.
>>> Thanks,
>>> Lex
>>> Wei-keng Liao a écrit :
>>>> Hi, Lex,
>>>> PnetCDF requires the attribute define arguments be the same across
>>>> all processes. This is why you got the error message for defining
>>>> attribute "history" in line 400, if its value "conflicts" among
>>>> processes.
>>>> I think you have got this.
>>>> I checked your codes. Starting from line 562, you have a few text
>>>> attributes
>>>> from des_tgas_picture(i), des_trac_picture(i), des_tpas_picture(i),
>>>> and des.
>>>> Similar for out_type == 2. Are you sure their values are all the
>>>> same
>>>> across
>>>> all the processes? May be you can use MPI_Bcast to check if
>>>> anyone has
>>>> different value.
>>>> Wei-keng
>>>> On Feb 19, 2009, at 11:14 AM, Alex Hoffmann wrote:
>>>>> Dear Rob
>>>>> Thanks a lot for your answer.
>>>>> Isolating the PnetCDF output module from the code as a stand-alone
>>>>> would
>>>>> require a substantial effort, and I do not encounter this error
>>>>> in  my
>>>>> small test programs.  I attached the output module for reference.
>>>>> The attribute section that causes trouble is between lines 369-405
>>>>> (global) and 468-613 (variables).  I am aware that the attribute
>>>>> history
>>>>> (line 400) may be problematic as every process may have a slightly
>>>>> different value (for the time element taken from the fortran
>>>>> function
>>>>> date_and_time).  Yet this is not the only issue.
>>>>> If I prematurely exit at line 492, uncommenting any further
>>>>> attribute
>>>>> definition between 468 and 489 causes a crash with the
>>>>> multiprocesses
>>>>> conflict.
>>>>> Note also that the attribute definitions between 558 and 613 only
>>>>> produce no crash currently because of the print statements on
>>>>> lines 560
>>>>> and 591, which made me think that maybe there is an optimization
>>>>> problem.  What is strange is that if these are not included, the
>>>>> crash
>>>>> occurs only when I start writing the first file (movie file,
>>>>> out_type=2), AND if I leave the first block (if out_type==1)
>>>>> uncommented, although this block is not even entered in that
>>>>> particular
>>>>> case, and vice versa.  Hope this is more or less clear...
>>>>> Cheers,
>>>>> Lex
>>>>> Robert Latham wrote:
>>>>>> On Thu, Feb 19, 2009 at 10:09:37AM +0000, Alex Hoffmann wrote:
>>>>>>> Hello,
>>>>>>> I am getting the same error message as had already been inquired
>>>>>>> on in
>>>>>>> this list, i.e.:
>>>>>>> NC definations on multiprocesses conflict.
>>>>>>> NOTE: Definitions across all process
>>>>>>> and this seems to be related somehow randomly to the total
>>>>>>> number of
>>>>>>> attributes (global or for each variable) that I intend to write
>>>>>>> during
>>>>>>> the the definition phase (and, though I am not sure about
>>>>>>> this, to
>>>>>>> the
>>>>>>> number of processes used to run my F90 parallel code).
>>>>>>> More precisely, if I uncomment one put_att to replace another,
>>>>>>> the
>>>>>>> program still runs, if I do not comment out another one, the
>>>>>>> program
>>>>>>> crashes with the above error message.
>>>>>>> Is there any way of identifying where this problem comes from
>>>>>>> or is
>>>>>>> there a maximum amount of attributes (though I don't write an
>>>>>>> excessive
>>>>>>> amount of them)?  There is no problem running it on one
>>>>>>> process(or).
>>>>>> Maybe you can show us with a small test program how you are
>>>>>> encountering this error?  The maximum number of attributes is
>>>>>> 4k (the
>>>>>> constant NC_MAX_ATTRS).
>>>>>> ==rob
>>>>> ______________________________________________________________________
>>>>> Alex HOFFMANN                     PhD Candidate
>>>>> Centre for Atmospheric Science
>>>>> Department of Geography           University of Cambridge
>>>>> Downing Place, Cambridge CB2 3EN, UK
>>>>> e-mail: ah519 at cam.ac.uk  tel: +44 (0)1223 766581
>>>>> www.geog.cam.ac.uk/people/hoffmann/
>>>>> !-*- F90 -*-
>>>>> module atham_pnetcdf
>>>>> ! author:  Alex
>>>>> HOFFMANN                                             !
>>>>> ! email:
>>>>> ah519 at cam.ac.uk                                           !
>>>>> ! date:    February
>>>>> 2009                                             !
>>>>> ! version:
>>>>> v0.1                                                      !
>>>>> ! collection of routines for ATHAM PnetCDF
>>>>> output                    !
>>>>> ! module is to replace existing atham_netcdf.mod (GL) to write
>>>>> ATHAM
>>>>> output as netCDF files
>>>>> ! same as atham_netcdf.mod (AH) but adapted to run with the
>>>>> Parallel
>>>>> NetCDF API,
>>>>> !  developed by Northwestern University and Argonne National
>>>>> Laboratory,
>>>>> !  which is built on top of MPI-IO (tested with MPICH 2.1)
>>>>> use precision,    only : kint, kreal, real4, my_real
>>>>> use atham_module, only : nx, ny, nz, ntx, nty, npx, npy
>>>>> use atham_module, only : ntgas_picture, ntrac_picture,
>>>>> ntpas_picture, &
>>>>>                       ntgas_movie, ntrac_movie, ntpas_movie
>>>>> implicit none
>>>>> private
>>>>> public :: netcdf_data
>>>>> ! 'pnetcdf.inc' file includes cpp directives that were not
>>>>> understood
>>>>> at compile-time
>>>>> ! this is to be changed and hard-wired link to be replaced by the
>>>>> include 'pnetcdf.inc' command
>>>>> !include 'pnetcdf.inc'
>>>>> #include "/usr/local/parallel-netcdf-1.0.1/include/pnetcdf.inc"
>>>>> include 'mpif.h'
>>>>> ! ######### tried saving netCDF variable IDs here so that they
>>>>> must
>>>>> not be retrieved by inquiry
>>>>> ! ######### if this creates conflict, especially between picture
>>>>> and
>>>>> movie file, this must be changed
>>>>>  integer(kint), save                   :: x_dimID, y_dimID,
>>>>> z_dimID, t_dimID
>>>>>  integer(kint), save                   :: x_varID, y_varID,
>>>>> z_varID, t_varID
>>>>>  integer(kint), save                   :: u_varID, v_varID,
>>>>> w_varID
>>>>>  integer(kint), save                   :: pnew_varID,
>>>>> tetnew_varID,
>>>>> tempnew_varID, density_varID
>>>>>  integer(kint), save                   :: turbhor_varID,
>>>>> turbver_varID, turblen_varID
>>>>>  integer(kint), dimension(99), save    :: tgas_varID, trac_varID,
>>>>> tpas_varID, d_trac_varID
>>>>>  integer(MPI_OFFSET_KIND), save        :: tcounter
>>>>>  real(real4), parameter                :: undef = -0.99e33_real4 !
>>>>> make sure precision of _FillValue and output (NF90_FLOAT) is the
>>>>> same
>>>>> contains
>>>>> subroutine netcdf_data(outfile,out_type,timetot)
>>>>>  ! IF: outfile = picture_file or movie_file (path/filename for
>>>>> output created in atham_module)
>>>>>  !     out_type = 1 (picture_file) or 2 (movie_file)
>>>>>  !     timetot = total simulation time since simulation start
>>>>>  use atham_module, only : unew, vnew, wnew, pnew, tetnew,
>>>>> tempnew, &
>>>>>                           density, turbhor, turbver, turblen
>>>>>  use atham_module, only : tgasnew, tracnew, tpasnew, tracdep
>>>>>  use atham_module, only : itgas_picture, itrac_picture,
>>>>> itpas_picture, &
>>>>>                           itgas_movie, itrac_movie, itpas_movie
>>>>>  use atham_module, only : mycoor, my_cart, myrank
>>>>>  character(*),           intent(in   ) :: outfile
>>>>>  integer(kint),          intent(in   ) :: out_type
>>>>>  real(kreal),            intent(in   ) :: timetot
>>>>>  ! local
>>>>> variables                                                  !
>>>>>  integer(MPI_OFFSET_KIND)              :: nx_mpi,ny_mpi, nz_mpi,
>>>>> y_cl_mpi
>>>>>  integer(MPI_OFFSET_KIND)              :: istart,jstart
>>>>>  integer(kint)                         :: STATUS
>>>>>  character(len=50)                     :: OP  ! debugging variable
>>>>> corresponding to the called netCDF OPeration
>>>>>  integer(kint)                         :: NCID
>>>>>  integer(kint)                         :: i
>>>>>  logical                               :: DynMovie_flag,
>>>>> bounds_control
>>>>>  integer(kint)                         :: y_st, y_sp, y_cl
>>>>>  ! replace DynMovie precompiler flag by program flag for more
>>>>> convenient code structure
>>>>>  DynMovie_flag = .false.
>>>>> #ifdef DynMovie
>>>>>  DynMovie_flag = .true.
>>>>> #endif
>>>>>  ! re-assign dimension lengths as an MPI_Offset type (necessary
>>>>> for
>>>>> the PnetCDF interface)
>>>>>  ! cut-off subdomain borders
>>>>>  nx_mpi  = nx-2
>>>>>  ny_mpi  = ny-2
>>>>>  nz_mpi  = nz
>>>>>  ! assign coordinates of first element of each process in the
>>>>> netCDF file
>>>>>  istart = mycoor(1)*nx_mpi + 1_MPI_OFFSET_KIND
>>>>>  jstart = mycoor(2)*ny_mpi + 1_MPI_OFFSET_KIND
>>>>>  bounds_control = .true. ! debugging flag
>>>>>  tcounter = tcounter+1_MPI_OFFSET_KIND
>>>>>  ! === open netCDF dataset: enter data mode
>>>>>  ! if     dataset does not yet exist (STATUS =  ), create file and
>>>>> enter data mode
>>>>>  ! else   continue
>>>>>  OP = 'open existing netCDF file'
>>>>>  STATUS = nfmpi_open(my_cart, trim(outfile), NF_WRITE,
>>>>> MPI_INFO_NULL, NCID)
>>>>>  if ( STATUS /= nf_noerr ) then
>>>>>     if (myrank==0) then
>>>>>        print *, ""
>>>>>        print *, "P-NetCDF operation: ",trim(OP)
>>>>>        print *, trim(nfmpi_strerror(STATUS))
>>>>>        print *, "atham_pnetcdf netcdf_data(): new netCDF file
>>>>> created: ", outfile
>>>>>        print *, ""
>>>>>     end if
>>>>>     call netcdf_define(outfile,out_type,timetot,NCID)
>>>>>     tcounter = 1_MPI_OFFSET_KIND ! reset time counter for output
>>>>> if
>>>>> new file is created
>>>>>  end if
>>>>>  ! ---                        write data values
>>>>>  ! unlimited record dimension time (only one process writes the
>>>>> whole dimension, i.e. accross all processes)
>>>>>  OP = 'write data values - unlimited dimension t'
>>>>>  call handle_err(nfmpi_begin_indep_data(NCID))
>>>>>  if (myrank==0) then
>>>>>     call handle_err(nfmpi_put_vara_real(NCID, t_varID,
>>>>> (/tcounter/), (/1_MPI_OFFSET_KIND/), real(timetot,real4)),OP)
>>>>>  end if
>>>>>  call handle_err(nfmpi_end_indep_data(NCID))
>>>>>  ! discriminate between 2D and 3D case for output generation
>>>>>  if (nty>4) then
>>>>>     y_st = 2    ! y index start
>>>>>     y_sp = ny-1 ! y index stop
>>>>>     y_cl = ny-2 ! y number of columns
>>>>>  else
>>>>>     y_st = ny-1 ! 3 in 2D case
>>>>>     y_sp = ny-1 ! 3 in 2D case
>>>>>     y_cl = 1
>>>>>  end if
>>>>>  y_cl_mpi = y_cl
>>>>>  ! dynamics data
>>>>>  OP = 'write data values - data'
>>>>>  if (out_type == 1 .OR. DynMovie_flag == .true.) then
>>>>>     call write_data(real(unew,real4),u_varID)
>>>>>     bounds_control = .false.
>>>>>     call write_data(real(vnew,   real4),v_varID)
>>>>>     call write_data(real(wnew,   real4),w_varID)
>>>>>     call write_data(real(pnew,   real4),pnew_varID)
>>>>>     call write_data(real(tetnew, real4),tetnew_varID)
>>>>>     call write_data(real(tempnew,real4),tempnew_varID)
>>>>>     call write_data(real(density,real4),density_varID)
>>>>>     call write_data(real(turbhor,real4),turbhor_varID)
>>>>>     call write_data(real(turbver,real4),turbver_varID)
>>>>>     call write_data(real(turblen,real4),turblen_varID)
>>>>>  end if
>>>>>  ! tracer data
>>>>>  if (out_type == 1) then
>>>>>     do i=1,ntgas_picture
>>>>>        call
>>>>> write_data
>>>>> (real(tgasnew(:,:,:,itgas_picture(i)),real4),tgas_varID(i))
>>>>>     enddo
>>>>>     do i=1,ntrac_picture
>>>>>        call
>>>>> write_data
>>>>> (real(tracnew(:,:,:,itrac_picture(i)),real4),trac_varID(i))
>>>>>     enddo
>>>>>     do i=1,ntpas_picture
>>>>>        call
>>>>> write_data
>>>>> (real(tpasnew(:,:,:,itpas_picture(i)),real4),tpas_varID(i))
>>>>>     enddo
>>>>> d_trac_varID(i),(/istart,jstart,tcounter/), &
>>>>>             (/nx_mpi,y_cl_mpi,1_MPI_OFFSET_KIND/),
>>>>> real(reshape(tracdep(2:nx-1,y_st:y_sp,itrac_picture(i)),shape=(/
>>>>> nx-2,y_cl,1/)),real4)
>>>>> ),OP)
>>>>>     enddo
>>>>>  else if (out_type == 2) then
>>>>>     do i=1,ntgas_movie
>>>>>        call
>>>>> write_data
>>>>> (real(tgasnew(:,:,:,itgas_movie(i)),real4),tgas_varID(i))
>>>>>     enddo
>>>>>     do i=1,ntrac_movie
>>>>>        call
>>>>> write_data
>>>>> (real(tracnew(:,:,:,itrac_movie(i)),real4),trac_varID(i))
>>>>>     enddo
>>>>>     do i=1,ntpas_movie
>>>>>        call
>>>>> write_data
>>>>> (real(tpasnew(:,:,:,itpas_movie(i)),real4),tpas_varID(i))
>>>>>     enddo
>>>>>  endif
>>>>>  ! === close netCDF dataset: exit data mode & save
>>>>>  OP = 'close netCDF file'
>>>>>  call handle_err(nfmpi_close(NCID))
>>>>>  if (myrank==0) then
>>>>>     print *, ''
>>>>>     print *, 'wrote netCDF output to file ', outfile
>>>>>     print *, ''
>>>>>  end if
>>>>>  contains
>>>>>    subroutine write_data(array_in,varID)
>>>>>      ! IF: array_in = data array (3D) to be written to netCDF
>>>>>      !     varID    = data variable netCDF ID
>>>>>      use atham_module, only : iflgs ! topography mask: topography
>>>>> (iflgs=0) remains undef
>>>>>      use atham_module, only  : myrank
>>>>>      real(real4),dimension(nx,ny,nz), intent (in   )   :: array_in
>>>>>      integer(kint),                intent(in   )       :: varID
>>>>>      ! local
>>>>> variables                                              !
>>>>>      real(real4), dimension(nx,ny,nz)            :: array_masked
>>>>>      ! dimensions & bounds control
>>>>>      integer(MPI_OFFSET_KIND)                    :: dimlenx,
>>>>> dimleny, dimlenz, dimlent
>>>>>      integer(kint), dimension(NF_max_var_dims)   :: dimIDs
>>>>>      if (myrank == 0) then
>>>>>         if (bounds_control) then
>>>>>            print *, ''
>>>>>            print *, 'atham var in xyz
>>>>> ',shape(array_in)
>>>>>            print *, 'atham var reshaped to xyzt
>>>>> ',shape(reshape(array_in(2:nx-1,y_st:y_sp,1:nz),shape=(/
>>>>> nx-2,y_cl,nz,1/)))
>>>>>            call handle_err(nfmpi_inq_vardimid(NCID, u_varID,
>>>>> dimIDs)) ! taken unew as ref
>>>>>            call handle_err(nfmpi_inq_dimlen(NCID, dimIDs(1),
>>>>> dimlenx))
>>>>>            call handle_err(nfmpi_inq_dimlen(NCID, dimIDs(2),
>>>>> dimleny))
>>>>>            call handle_err(nfmpi_inq_dimlen(NCID, dimIDs(3),
>>>>> dimlenz))
>>>>>            call handle_err(nfmpi_inq_dimlen(NCID, dimIDs(4),
>>>>> dimlent))
>>>>>            print *, 'netCDF var dimensions in xyzt
>>>>> ',dimlenx,dimleny,dimlenz,dimlent
>>>>>         end if
>>>>>      end if
>>>>>      ! mask topography
>>>>>      where (iflgs == 1)
>>>>>         array_masked = array_in
>>>>>      elsewhere
>>>>>         array_masked = undef
>>>>>      endwhere
>>>>>      ! mask control
>>>>>      !print *, ''
>>>>>      !print *, 'topography mask'
>>>>>      !print *, iflgs(1:5,3,3)
>>>>>      !print *, iflgs(1:5,3,2)
>>>>>      !print *, iflgs(1:5,3,1)
>>>>>      !print *, ''
>>>>>      !print *, 'masked variable array'
>>>>>      !print *, array_masked(:,3,3)
>>>>>      !print *, array_masked(:,3,2)
>>>>>      !print *, array_masked(:,3,1)
>>>>>      !print *, ''
>>>>> varID,(/istart,jstart,1_MPI_OFFSET_KIND,tcounter/), &
>>>>>           (/nx_mpi,y_cl_mpi,nz_mpi,1_MPI_OFFSET_KIND/),
>>>>> reshape(array_masked(2:nx-1,y_st:y_sp,1:nz),shape=(/nx-2,y_cl,nz,
>>>>> 1/))
>>>>> ),OP)
>>>>>    end subroutine write_data
>>>>> end subroutine netcdf_data
>>>>> subroutine netcdf_define(outfile,out_type,timetot,ncid_def)
>>>>>  !     timetot = simulation time since simulation start (from
>>>>> atham/atham_out)
>>>>>  !     ncid_def = netCDF ID assigned to file during creation
>>>>>  use atham_module, only   : var_tgas_picture,
>>>>> var_tgas_movie,           &
>>>>>                             des_tgas_picture,
>>>>> des_tgas_movie,           &
>>>>>                             var_trac_picture,
>>>>> var_trac_movie,           &
>>>>>                             des_trac_picture,
>>>>> des_trac_movie,           &
>>>>>                             var_tpas_picture,
>>>>> var_tpas_movie,           &
>>>>>                             des_tpas_picture, des_tpas_movie
>>>>>  use atham_module, only   : iindex, spinup, nrep, periodt
>>>>>  use atham_module, only   : volcano_setup,
>>>>> coignimbrite_setup,          &
>>>>>                             nuclear_setup, convection_setup,
>>>>> procsconfig_setup
>>>>>  use atham_module, only   : x, y, z, xg, yg
>>>>>  use atham_module, only   : grid2geo, sim_d_YYYY, sim_d_MM,
>>>>> sim_d_DD,   &
>>>>>                             sim_t_hh, sim_t_mm, sim_t_ss
>>>>>  use atham_module, only   : my_cart, myrank
>>>>>  integer(kint),          intent(  out) :: ncid_def
>>>>>  ! local
>>>>> variables                                                  !
>>>>>  integer(MPI_OFFSET_KIND)              :: ntx_mpi,nty_mpi,nz_mpi
>>>>>  integer(kint)                         :: i
>>>>>  character(len=50)                     :: var, des
>>>>>  real(kreal)                           :: toffset
>>>>>  real(real4)                           :: coord_scale,
>>>>> coord_x_offset, coord_y_offset, coord_t_offset
>>>>>  character(len=3)                      :: coord_x_name,
>>>>> coord_y_name, coord_z_name
>>>>>  character(len=4)                      :: coord_t_name
>>>>>  character(len=9)                      :: coord_x_lname,
>>>>> coord_y_lname
>>>>>  character(len=13)                     :: coord_x_units,
>>>>> coord_y_units
>>>>>  character(len=33)                     :: coord_t_units
>>>>>  character(len=8)                      :: date
>>>>>  character(len=10)                     :: time
>>>>>  character(len=19)                     :: simdatetime
>>>>>  character(len=10)                     :: simdate
>>>>>  character(len=20)                     :: login
>>>>>  character(len=63)                     :: hist_string
>>>>>  integer(kint)                         :: isetup
>>>>>  character(len=12)                     :: model_setup(6)
>>>>>  data model_setup /'volcano     ', 'coignimbrite', 'nuclear     ',
>>>>> 'convection  ', 'procsconfig ','unknown     '/
>>>>> #ifdef DynMovie
>>>>> #endif
>>>>> for
>>>>>  ! cut-off domain borders
>>>>>  ntx_mpi = ntx-2
>>>>>  nty_mpi = nty-2
>>>>>  nz_mpi  = nz
>>>>>  ! convert date and time integers into string 'YYYYMMDD hh:mm:ss'
>>>>>  write (simdatetime,10)
>>>>> sim_d_YYYY,sim_d_MM,sim_d_DD,sim_t_hh,sim_t_mm,sim_t_ss
>>>>> 10 format (I4,'-',I2,'-',I2,1X,I2,':',I2,':',I2)
>>>>>  simdate = simdatetime(1:10)
>>>>>  ! switch between cartesian axes/time (default) and geographic
>>>>> axes/date (linear approx)
>>>>>  coord_scale    = 1._real4
>>>>>  coord_x_offset = 0._real4
>>>>>  coord_x_name   = 'x  '
>>>>>  coord_x_lname  = 'x_coor   '
>>>>>  coord_x_units  = 'm            '
>>>>>  coord_y_offset = 0._real4
>>>>>  coord_y_name   = 'y  '
>>>>>  coord_y_lname  = 'y_coor   '
>>>>>  coord_y_units  = 'm            '
>>>>>  coord_z_name   = 'z  '
>>>>>  coord_t_offset = 0._real4
>>>>>  coord_t_name   = 'time'
>>>>>  coord_t_units  = 'sec                              '
>>>>>  if (grid2geo) then
>>>>>     call
>>>>> gridconvert
>>>>> (coord_scale
>>>>> ,coord_x_offset,coord_x_name,coord_x_lname,coord_x_units,
>>>>> coord_y_offset,coord_y_name,coord_y_lname,coord_y_units, &
>>>>> coord_z_name,coord_t_offset,coord_t_name,coord_t_units)
>>>>>  end if
>>>>>  ! === create netCDF dataset: enter define mode
>>>>>  OP = 'enter define mode'
>>>>>  call handle_err(nfmpi_create(my_cart, trim(outfile), 0,
>>>>> MPI_INFO_NULL,NCID),OP)
>>>>>  ncid_def = NCID
>>>>>  ! === create netCDF dataset: assign metadata
>>>>>  ! ---                        set global attributes
>>>>>  OP = 'set global attributes'
>>>>>     toffset = timetot - spinup
>>>>>     call handle_err(nfmpi_put_att_text(NCID, NF_GLOBAL, 'title',
>>>>> 13_MPI_OFFSET_KIND, 'atham_picture'),OP)
>>>>>  else
>>>>>     toffset = timetot - spinup - nrep*periodt
>>>>> 11_MPI_OFFSET_KIND, 'atham_movie'),OP)
>>>>>  end if
>>>>>  call handle_err(nfmpi_put_att_text(NCID, NF_GLOBAL, 'content',
>>>>> 223_MPI_OFFSET_KIND, &
>>>>>       'This data corresponds to a simulation run of the
>>>>> mesoscale-beta/gamma type non-hydrostatic Active Tracer
>>>>> High-resolution Atmospheric Model ATHAM ' &
>>>>>       // '(Oberhuber et al., 1998, Herzog, 1998), for a setup as
>>>>> specified under history'),OP) ! ######### add further
>>>>> description as
>>>>> necessary
>>>>>  call handle_err(nfmpi_put_att_text(NCID, NF_GLOBAL, 'version',
>>>>> 21_MPI_OFFSET_KIND, 'no current versioning'),OP) ! #########
>>>>> change
>>>>> once available
>>>>>  call date_and_time(date, time)
>>>>>  call getlog(login)
>>>>>  if (volcano_setup) then
>>>>>     isetup=1
>>>>>  else if (coignimbrite_setup) then
>>>>>     isetup=2
>>>>>  else if (nuclear_setup) then
>>>>>     isetup=3
>>>>>  else if (convection_setup) then
>>>>>     isetup=4
>>>>>  else if (procsconfig_setup) then
>>>>>     isetup=5
>>>>>  else
>>>>>     isetup=6
>>>>>  end if
>>>>>  hist_string = trim(date//' '//time//'  '//trim(login)//'  atham
>>>>> '//model_setup(isetup))
>>>>> !    call handle_err(nfmpi_put_att_text(NCID, NF_GLOBAL,
>>>>> 'history',
>>>>> 63_MPI_OFFSET_KIND, hist_string),OP) ! 1 line/modification:  -
>>>>> cmd arg
>>>>> 'Conventions', 28_MPI_OFFSET_KIND, 'COARDS, //cf-
>>>>> pcmdi.llnl.gov/'),OP)
>>>>> 'sim_onset_date_time', 19_MPI_OFFSET_KIND, simdatetime),OP)
>>>>> !    call handle_err(nfmpi_put_att_real(NCID, NF_GLOBAL,
>>>>> 'sim_time_offset', NF_FLOAT, 1_MPI_OFFSET_KIND,
>>>>> real(toffset,real4)),OP)
>>>>> 'x_zoom_location', NF_FLOAT, 1_MPI_OFFSET_KIND,
>>>>> real(x(max(1,iindex)),real4)),OP)
>>>>>  ! ---                        define dimensions
>>>>>  OP = 'define dimensions'
>>>>>  call handle_err(nfmpi_def_dim(NCID, trim(coord_x_name),
>>>>> ntx_mpi,             x_dimID),OP)
>>>>>  if (nty>4) then
>>>>>     call handle_err(nfmpi_def_dim(NCID, trim(coord_y_name),
>>>>> nty_mpi,             y_dimID),OP)
>>>>>  else
>>>>> 1_MPI_OFFSET_KIND,   y_dimID),OP)
>>>>>  end if
>>>>>  call handle_err(nfmpi_def_dim(NCID, trim(coord_z_name),
>>>>> nz_mpi,              z_dimID),OP)
>>>>>  call handle_err(nfmpi_def_dim(NCID, coord_t_name,
>>>>> nfmpi_unlimited,     t_dimID),OP)
>>>>>  ! ---                        define variables
>>>>>  ! dimensions
>>>>>  OP = 'define variables - dimensions'
>>>>>  call handle_err(nfmpi_def_var(NCID, trim(coord_x_name),
>>>>> NF_FLOAT, 1, x_dimID, x_varID),OP)
>>>>>  call handle_err(nfmpi_def_var(NCID, trim(coord_y_name),
>>>>> NF_FLOAT, 1, y_dimID, y_varID),OP)
>>>>>  call handle_err(nfmpi_def_var(NCID, trim(coord_z_name),
>>>>> NF_FLOAT, 1, z_dimID, z_varID),OP)
>>>>>  call handle_err(nfmpi_def_var(NCID, coord_t_name,
>>>>> NF_FLOAT, 1, t_dimID, t_varID),OP)
>>>>>  ! dynamics data
>>>>>  OP = 'define variables - data'
>>>>>     call handle_err(nfmpi_def_var(NCID, 'u',       NF_FLOAT, 4,
>>>>> (/x_dimID,y_dimID,z_dimID,t_dimID/), u_varID),OP)
>>>>>     call handle_err(nfmpi_def_var(NCID, 'v',       NF_FLOAT, 4,
>>>>> (/x_dimID,y_dimID,z_dimID,t_dimID/), v_varID),OP)
>>>>>     call handle_err(nfmpi_def_var(NCID, 'w',       NF_FLOAT, 4,
>>>>> (/x_dimID,y_dimID,z_dimID,t_dimID/), w_varID),OP)
>>>>>     call handle_err(nfmpi_def_var(NCID, 'pnew',    NF_FLOAT, 4,
>>>>> (/x_dimID,y_dimID,z_dimID,t_dimID/), pnew_varID),OP)
>>>>>     call handle_err(nfmpi_def_var(NCID, 'tetnew',  NF_FLOAT, 4,
>>>>> (/x_dimID,y_dimID,z_dimID,t_dimID/), tetnew_varID),OP)
>>>>>     call handle_err(nfmpi_def_var(NCID, 'tempnew', NF_FLOAT, 4,
>>>>> (/x_dimID,y_dimID,z_dimID,t_dimID/), tempnew_varID),OP)
>>>>>     call handle_err(nfmpi_def_var(NCID, 'density', NF_FLOAT, 4,
>>>>> (/x_dimID,y_dimID,z_dimID,t_dimID/), density_varID),OP)
>>>>>     call handle_err(nfmpi_def_var(NCID, 'turbhor', NF_FLOAT, 4,
>>>>> (/x_dimID,y_dimID,z_dimID,t_dimID/), turbhor_varID),OP)
>>>>>     call handle_err(nfmpi_def_var(NCID, 'turbver', NF_FLOAT, 4,
>>>>> (/x_dimID,y_dimID,z_dimID,t_dimID/), turbver_varID),OP)
>>>>>     call handle_err(nfmpi_def_var(NCID, 'turblen', NF_FLOAT, 4,
>>>>> (/x_dimID,y_dimID,z_dimID,t_dimID/), turblen_varID),OP)
>>>>>  end if
>>>>>  ! tracer data
>>>>>        call handle_err(nfmpi_def_var(NCID, var_tgas_picture(i),
>>>>> NF_FLOAT, 4, (/x_dimID,y_dimID,z_dimID,t_dimID/),
>>>>> tgas_varID(i)),OP)
>>>>>     enddo
>>>>>        call handle_err(nfmpi_def_var(NCID, var_trac_picture(i),
>>>>> trac_varID(i)),OP)
>>>>>     enddo
>>>>>        call handle_err(nfmpi_def_var(NCID, var_tpas_picture(i),
>>>>> tpas_varID(i)),OP)
>>>>>     enddo
>>>>>        var='d_'//trim(var_trac_picture(i))
>>>>>        call handle_err(nfmpi_def_var(NCID, var,
>>>>> NF_FLOAT, 3, (/x_dimID,y_dimID,t_dimID/), d_trac_varID(i)),OP)
>>>>>     enddo
>>>>>     do i=1,ntgas_movie
>>>>>        call handle_err(nfmpi_def_var(NCID, var_tgas_movie(i),
>>>>> tgas_varID(i)),OP)
>>>>>     enddo
>>>>>     do i=1,ntrac_movie
>>>>>        call handle_err(nfmpi_def_var(NCID, var_trac_movie(i),
>>>>> trac_varID(i)),OP)
>>>>>     enddo
>>>>>     do i=1,ntpas_movie
>>>>>        call handle_err(nfmpi_def_var(NCID, var_tpas_movie(i),
>>>>> tpas_varID(i)),OP)
>>>>>     enddo
>>>>>  endif
>>>>>  ! ---                        assign attributes
>>>>>  ! common attributes: long_name, units, valid_range, scale_factor,
>>>>> add_offset, _FillValue, history, conventions
>>>>>  ! dimensions
>>>>>  OP = 'assign attributes - dimensions'
>>>>>  call handle_err(nfmpi_put_att_text(NCID, x_varID,
>>>>> 'long_name',               9_MPI_OFFSET_KIND,
>>>>> trim(coord_x_lname)),OP)
>>>>> 'units',                  13_MPI_OFFSET_KIND,
>>>>> trim(coord_x_units)),OP)
>>>>> !    call handle_err(nfmpi_put_att_real(NCID, x_varID,
>>>>> 'scale_factor', NF_FLOAT,  1_MPI_OFFSET_KIND, coord_scale),OP)
>>>>> 'add_offset',   NF_FLOAT,  1_MPI_OFFSET_KIND, coord_x_offset),OP)
>>>>>  call handle_err(nfmpi_put_att_text(NCID, y_varID,
>>>>> trim(coord_y_lname)),OP)
>>>>> trim(coord_y_units)),OP)
>>>>> !    call handle_err(nfmpi_put_att_real(NCID, y_varID,
>>>>> 'add_offset',   NF_FLOAT,  1_MPI_OFFSET_KIND, coord_y_offset),OP)
>>>>>  call handle_err(nfmpi_put_att_text(NCID, z_varID,
>>>>> 'long_name',               6_MPI_OFFSET_KIND, 'height'),OP)
>>>>> 'units',                   1_MPI_OFFSET_KIND, 'm'),OP)
>>>>> !    call handle_err(nfmpi_put_att_text(NCID, z_varID,
>>>>> 'positive',                2_MPI_OFFSET_KIND, 'up'),OP)
>>>>>  call handle_err(nfmpi_put_att_text(NCID, t_varID,
>>>>> 'long_name',               4_MPI_OFFSET_KIND, coord_t_name),OP)
>>>>> 'units',                  33_MPI_OFFSET_KIND,
>>>>> trim(coord_t_units)),OP)
>>>>> !    call handle_err(nfmpi_put_att_real(NCID, t_varID,
>>>>> 'add_offset',   NF_FLOAT,  1_MPI_OFFSET_KIND, coord_t_offset),OP)
>>>>> !    OP = 'exit define mode NOW for testing
>>>>> ****************************************************' ! ah_testing
>>>>> !    call
>>>>> handle_err(nfmpi_enddef(NCID),OP)
>>>>> ! ah_testing ********************************
>>>>>  ! dynamics data
>>>>>  OP = 'assign attributes - data'
>>>>> !       call handle_err(nfmpi_put_att_text(NCID, u_varID,
>>>>> 'long_name',              6_MPI_OFFSET_KIND, 'x_wind'),OP)
>>>>> 'units',                  7_MPI_OFFSET_KIND, 'm sec-1'),OP)
>>>>> !       call handle_err(nfmpi_put_att_real(NCID, u_varID,
>>>>> 'scale_factor',NF_FLOAT,  1_MPI_OFFSET_KIND, 1.),OP)
>>>>> 'add_offset',  NF_FLOAT,  1_MPI_OFFSET_KIND, 0.0),OP)
>>>>> '_FillValue',  NF_FLOAT,  1_MPI_OFFSET_KIND, undef),OP)
>>>>> !       call handle_err(nfmpi_put_att_text(NCID, v_varID,
>>>>> 'long_name',              6_MPI_OFFSET_KIND, 'y_wind'),OP)
>>>>> !       call handle_err(nfmpi_put_att_real(NCID, v_varID,
>>>>> !       call handle_err(nfmpi_put_att_text(NCID, w_varID,
>>>>> 'long_name',             19_MPI_OFFSET_KIND,
>>>>> 'upward_air_velocity'),OP)
>>>>> !       call handle_err(nfmpi_put_att_real(NCID, w_varID,
>>>>> !       call handle_err(nfmpi_put_att_text(NCID, pnew_varID,
>>>>> 'long_name',             20_MPI_OFFSET_KIND,
>>>>> 'air_pressure_anomaly'),OP)
>>>>> 'units',                  2_MPI_OFFSET_KIND, 'Pa'),OP)
>>>>> !       call handle_err(nfmpi_put_att_real(NCID, pnew_varID,
>>>>> !       call handle_err(nfmpi_put_att_text(NCID, tetnew_varID,
>>>>> 'long_name',             25_MPI_OFFSET_KIND,
>>>>> 'air_potential_temperature'),OP)
>>>>> 'units',                  1_MPI_OFFSET_KIND, 'K'),OP)
>>>>> !       call handle_err(nfmpi_put_att_real(NCID, tetnew_varID,
>>>>> !       call handle_err(nfmpi_put_att_text(NCID, tempnew_varID,
>>>>> 'long_name',             15_MPI_OFFSET_KIND,
>>>>> 'air_temperature'),OP)
>>>>> 'units',                  7_MPI_OFFSET_KIND, 'Celsius'),OP)
>>>>> !       call handle_err(nfmpi_put_att_real(NCID, tempnew_varID,
>>>>> 'add_offset',  NF_FLOAT,  1_MPI_OFFSET_KIND, -273.15),OP)
>>>>> !       call handle_err(nfmpi_put_att_text(NCID, density_varID,
>>>>> 'long_name',             11_MPI_OFFSET_KIND, 'air_density'),OP)
>>>>> 'units',                  6_MPI_OFFSET_KIND, 'kg m-3'),OP)
>>>>> !       call handle_err(nfmpi_put_att_real(NCID, density_varID,
>>>>> !       call handle_err(nfmpi_put_att_text(NCID, turbhor_varID,
>>>>> 'hor_turb_energy'),OP)
>>>>> 'units',                  8_MPI_OFFSET_KIND, 'm2 sec-2'),OP)
>>>>> !       call handle_err(nfmpi_put_att_real(NCID, turbhor_varID,
>>>>> !       call handle_err(nfmpi_put_att_text(NCID, turbver_varID,
>>>>> 'ver_turb_energy'),OP)
>>>>> !       call handle_err(nfmpi_put_att_real(NCID, turbver_varID,
>>>>> !       call handle_err(nfmpi_put_att_text(NCID, turblen_varID,
>>>>> 'long_name',             17_MPI_OFFSET_KIND,
>>>>> 'turb_length_scale'),OP)
>>>>> !       call handle_err(nfmpi_put_att_real(NCID, turblen_varID,
>>>>>  end if
>>>>>  ! tracer data
>>>>>     print *, 'NetCDF output type (1-picture,2-movie) ',out_type !
>>>>> #####  DO NOT REMOVE!!! optimization problem, trace source
>>>>>        call handle_err(nfmpi_put_att_text(NCID, tgas_varID(i),
>>>>> des_tgas_picture(i)),OP)
>>>>> 'units',                  9_MPI_OFFSET_KIND, 'gram kg-1'),OP)
>>>>>        call handle_err(nfmpi_put_att_real(NCID, tgas_varID(i),
>>>>> 'scale_factor',NF_FLOAT,  1_MPI_OFFSET_KIND, 1000.),OP)
>>>>>     enddo
>>>>>        call handle_err(nfmpi_put_att_text(NCID, trac_varID(i),
>>>>> des_trac_picture(i)),OP)
>>>>>        call handle_err(nfmpi_put_att_real(NCID, trac_varID(i),
>>>>>     enddo
>>>>>        call handle_err(nfmpi_put_att_text(NCID, tpas_varID(i),
>>>>> des_tpas_picture(i)),OP)
>>>>> 'units',                  1_MPI_OFFSET_KIND, '%'),OP)
>>>>>        call handle_err(nfmpi_put_att_real(NCID, tpas_varID(i),
>>>>> 'scale_factor',NF_FLOAT,  1_MPI_OFFSET_KIND, 100.),OP)
>>>>>     enddo
>>>>>        des='deposited_'//trim(des_trac_picture(i))
>>>>>        call handle_err(nfmpi_put_att_text(NCID, d_trac_varID(i),
>>>>> 'long_name',             35_MPI_OFFSET_KIND, des),OP)
>>>>> 'units',                  9_MPI_OFFSET_KIND, 'gram m-2'),OP)
>>>>>        call handle_err(nfmpi_put_att_real(NCID, d_trac_varID(i),
>>>>>     enddo
>>>>>     do i=1,ntgas_movie
>>>>> des_tgas_movie(i)),OP)
>>>>>     enddo
>>>>>     do i=1,ntrac_movie
>>>>> des_trac_movie(i)),OP)
>>>>>     enddo
>>>>>     do i=1,ntpas_movie
>>>>> des_tpas_movie(i)),OP)
>>>>>     enddo
>>>>>  end if
>>>>>  ! === create netCDF dataset: exit define mode, enter data mode
>>>>>  OP = 'exit define mode'
>>>>>  call handle_err(nfmpi_enddef(NCID),OP)
>>>>>  ! dimensions (only one process writes the whole dimension, i.e.
>>>>>  OP = 'write data values - dimensions'
>>>>>  if (myrank==0) then
>>>>>     call handle_err(nfmpi_put_vara_real(NCID, x_varID,
>>>>> (/1_MPI_OFFSET_KIND/), (/ntx_mpi/),real(xg(2:ntx-1),real4)),OP)
>>>>>     if (nty>4) then
>>>>>        call handle_err(nfmpi_put_vara_real(NCID, y_varID,
>>>>> (/1_MPI_OFFSET_KIND/), (/nty_mpi/), real(yg(2:nty-1),real4)),OP)
>>>>>     else
>>>>> (/1_MPI_OFFSET_KIND/), (/1_MPI_OFFSET_KIND/),
>>>>> real(yg(nty-1),real4)),OP)
>>>>>     end if
>>>>>     call handle_err(nfmpi_put_vara_real(NCID, z_varID,
>>>>> (/1_MPI_OFFSET_KIND/), (/nz_mpi/), real(z,real4)),OP)
>>>>>  end if
>>>>>  contains
>>>>>    subroutine
>>>>> gridconvert
>>>>> (cd_scale,cd_x_offset,cd_x_name,cd_x_lname,cd_x_units, &
>>>>> cd_y_offset,cd_y_name,cd_y_lname,cd_y_units, &
>>>>> cd_z_name,cd_t_offset,cd_t_name,cd_t_units)
>>>>>      ! IF: cd_* = coordinate parameters
>>>>>      ! linear conversion from cartesian grid into lon/lat
>>>>> system    !
>>>>>      ! only valid as first approxiamtion over small
>>>>> domains         !
>>>>>      ! to be replaced once a dyn core in a lat/lon system
>>>>> available !
>>>>>      use atham_module, only             : deglat_start,
>>>>> deglon_start
>>>>>      use phys_constants, only           : pi
>>>>>      real(real4),        intent(inout) :: cd_scale, cd_x_offset,
>>>>> cd_y_offset, cd_t_offset
>>>>>      character(len=3),   intent(inout) :: cd_x_name, cd_y_name,
>>>>> cd_z_name
>>>>>      character(len=4),   intent(inout) :: cd_t_name
>>>>>      character(len=9),   intent(inout) :: cd_x_lname, cd_y_lname
>>>>>      character(len=13),  intent(inout) :: cd_x_units, cd_y_units
>>>>>      character(len=33),  intent(inout) :: cd_t_units
>>>>>      ! local
>>>>> variables                                              !
>>>>>      real(kreal)                       :: r
>>>>>      real(kreal), parameter            :: a = 6378137._kreal     !
>>>>> (WGS 84)
>>>>>      real(kreal), parameter            :: b = 6356752.3142_kreal !
>>>>> (WGS 84)
>>>>>      ! ellipsoid radius at ATHAM domain start
>>>>>      r = a*b / sqrt((b*b*(cos(deglat_start*pi/180._kreal))**2
>>>>> )+(a*a*(sin(deglat_start*pi/180._kreal))**2 ))
>>>>>      cd_scale    = real((1/r) * (180._kreal/pi),real4)
>>>>>      cd_x_offset = deglon_start
>>>>>      cd_x_name   = 'lon'
>>>>>      cd_x_lname  = 'longitude'
>>>>>      cd_x_units  = 'degrees_east '
>>>>>      cd_y_offset = deglat_start
>>>>>      cd_y_name   = 'lat'
>>>>>      cd_y_lname  = 'latitude '
>>>>>      cd_y_units  = 'degrees_north'
>>>>>      cd_z_name   = 'lev'
>>>>>      coord_t_offset = real((sim_t_hh*3600 + sim_t_mm*60
>>>>> +sim_t_ss),real4)
>>>>>      coord_t_name   = 'date'
>>>>>      coord_t_units  = 'seconds since '//simdate//' 00:00:00
>>>>> [local]'
>>>>>      ! COARDS conventions require time zone from UTC to be
>>>>> specified
>>>>>      ! not necessary for local area version of ATHAM
>>>>>    end subroutine gridconvert
>>>>> end subroutine netcdf_define
>>>>> subroutine handle_err(status,op)
>>>>> integer,                    intent (in   ) :: status
>>>>> character(len=*), optional, intent (in   ) :: op
>>>>> if ( status /= nf_noerr ) then
>>>>>   if (myrank==0) then
>>>>>      print *, ""
>>>>>      print *, "P-NetCDF operation: ",trim(op)
>>>>>      print *, trim(nfmpi_strerror(status))
>>>>>      print *, "atham_pnetcdf error: program execution stopped"
>>>>>      print *, ""
>>>>>      stop
>>>>>   end if
>>>>> end if
>>>>> return
>>>>> end subroutine handle_err
>>>>> end module atham_pnetcdf
