problem with put_att (maximum number of attributes)
Alex Hoffmann ah519 at cam.ac.uk
Thu Feb 19 17:53:33 CST 2009
Dear Wei-keng,
I understand that the attribute define arguments must be the same across
all processes.   I am also almost certain that the arguments you cited
are identical across processes but I will perform a check.
Be this as it may, I get the same arrow message if I uncomment one of
the text attributes specifying the unit or one of the real attributes
specifying the fill value, for instance.  There is no possibility that
these are different across processes as they are introduced straight
into the function call.  Any check I performed seemed to indicate that
the problem arises from the number of arguments I defined, and not from
the arguments themselves, since they work all fine individually.
I was actually thinking to write the attributes ad-hoc once the dataset
is defined using regular netCDF functions.  This however seemed to be a
little elegant solution defeating the purpose of using PnetCDF.
Lex
Wei-keng Liao a écrit :
> Hi, Lex,
> PnetCDF requires the attribute define arguments be the same across
> all processes. This is why you got the error message for defining
> attribute "history" in line 400, if its value "conflicts" among
> processes.
> I think you have got this.
> I checked your codes. Starting from line 562, you have a few text
> attributes
> from des_tgas_picture(i), des_trac_picture(i), des_tpas_picture(i),
> and des.
> Similar for out_type == 2. Are you sure their values are all the same
> across
> all the processes? May be you can use MPI_Bcast to check if anyone has
> different value.
> Wei-keng
> On Feb 19, 2009, at 11:14 AM, Alex Hoffmann wrote:
>> Dear Rob
>> Thanks a lot for your answer.
>> Isolating the PnetCDF output module from the code as a stand-alone would
>> require a substantial effort, and I do not encounter this error in  my
>> small test programs.  I attached the output module for reference.
>> The attribute section that causes trouble is between lines 369-405
>> (global) and 468-613 (variables).  I am aware that the attribute history
>> (line 400) may be problematic as every process may have a slightly
>> different value (for the time element taken from the fortran function
>> date_and_time).  Yet this is not the only issue.
>> If I prematurely exit at line 492, uncommenting any further attribute
>> definition between 468 and 489 causes a crash with the multiprocesses
>> conflict.
>> Note also that the attribute definitions between 558 and 613 only
>> produce no crash currently because of the print statements on lines 560
>> and 591, which made me think that maybe there is an optimization
>> problem.  What is strange is that if these are not included, the crash
>> occurs only when I start writing the first file (movie file,
>> out_type=2), AND if I leave the first block (if out_type==1)
>> uncommented, although this block is not even entered in that particular
>> case, and vice versa.  Hope this is more or less clear...
>> Cheers,
>> Lex
>> Robert Latham wrote:
>>> On Thu, Feb 19, 2009 at 10:09:37AM +0000, Alex Hoffmann wrote:
>>>> Hello,
>>>> I am getting the same error message as had already been inquired on in
>>>> this list, i.e.:
>>>> NC definations on multiprocesses conflict.
>>>> NOTE: Definitions across all process
>>>> and this seems to be related somehow randomly to the total number of
>>>> attributes (global or for each variable) that I intend to write during
>>>> the the definition phase (and, though I am not sure about this, to the
>>>> number of processes used to run my F90 parallel code).
>>>> More precisely, if I uncomment one put_att to replace another, the
>>>> program still runs, if I do not comment out another one, the program
>>>> crashes with the above error message.
>>>> Is there any way of identifying where this problem comes from or is
>>>> there a maximum amount of attributes (though I don't write an
>>>> excessive
>>>> amount of them)?  There is no problem running it on one process(or).
>>> Maybe you can show us with a small test program how you are
>>> encountering this error?  The maximum number of attributes is 4k (the
>>> constant NC_MAX_ATTRS).
>>> ==rob
>> ______________________________________________________________________
>> Alex HOFFMANN                     PhD Candidate
>> Centre for Atmospheric Science
>> Department of Geography           University of Cambridge
>> Downing Place, Cambridge CB2 3EN, UK
>> e-mail: ah519 at cam.ac.uk  tel: +44 (0)1223 766581
>> www.geog.cam.ac.uk/people/hoffmann/
>> !-*- F90 -*-
>> module atham_pnetcdf
>>  ! author:  Alex HOFFMANN                                             !
>>  ! email:   ah519 at cam.ac.uk                                           !
>>  ! date:    February 2009                                             !
>>  ! version: v0.1                                                      !
>>  ! collection of routines for ATHAM PnetCDF output                    !
>> ! module is to replace existing atham_netcdf.mod (GL) to write ATHAM
>> output as netCDF files
>> ! same as atham_netcdf.mod (AH) but adapted to run with the Parallel
>> NetCDF API,
>> !  developed by Northwestern University and Argonne National Laboratory,
>> !  which is built on top of MPI-IO (tested with MPICH 2.1)
>> use precision,    only : kint, kreal, real4, my_real
>> use atham_module, only : nx, ny, nz, ntx, nty, npx, npy
>> use atham_module, only : ntgas_picture, ntrac_picture, ntpas_picture, &
>>                         ntgas_movie, ntrac_movie, ntpas_movie
>> implicit none
>> private
>> public :: netcdf_data
>> ! 'pnetcdf.inc' file includes cpp directives that were not understood
>> at compile-time
>> ! this is to be changed and hard-wired link to be replaced by the
>> include 'pnetcdf.inc' command
>> !include 'pnetcdf.inc'
>> #include "/usr/local/parallel-netcdf-1.0.1/include/pnetcdf.inc"
>> include 'mpif.h'
>> ! ######### tried saving netCDF variable IDs here so that they must
>> not be retrieved by inquiry
>> ! ######### if this creates conflict, especially between picture and
>> movie file, this must be changed
>>    integer(kint), save                   :: x_dimID, y_dimID,
>> z_dimID, t_dimID
>>    integer(kint), save                   :: x_varID, y_varID,
>> z_varID, t_varID
>>    integer(kint), save                   :: u_varID, v_varID, w_varID
>>    integer(kint), save                   :: pnew_varID, tetnew_varID,
>> tempnew_varID, density_varID
>>    integer(kint), save                   :: turbhor_varID,
>> turbver_varID, turblen_varID
>>    integer(kint), dimension(99), save    :: tgas_varID, trac_varID,
>> tpas_varID, d_trac_varID
>>    integer(MPI_OFFSET_KIND), save        :: tcounter
>>    real(real4), parameter                :: undef = -0.99e33_real4 !
>> make sure precision of _FillValue and output (NF90_FLOAT) is the same
>> contains
>>  subroutine netcdf_data(outfile,out_type,timetot)
>>    ! IF: outfile = picture_file or movie_file (path/filename for
>> output created in atham_module)
>>    !     out_type = 1 (picture_file) or 2 (movie_file)
>>    !     timetot = total simulation time since simulation start
>>    use atham_module, only : unew, vnew, wnew, pnew, tetnew, tempnew, &
>>                             density, turbhor, turbver, turblen
>>    use atham_module, only : tgasnew, tracnew, tpasnew, tracdep
>>    use atham_module, only : itgas_picture, itrac_picture,
>> itpas_picture, &
>>                             itgas_movie, itrac_movie, itpas_movie
>>    use atham_module, only : mycoor, my_cart, myrank
>>    character(*),           intent(in   ) :: outfile
>>    integer(kint),          intent(in   ) :: out_type
>>    real(kreal),            intent(in   ) :: timetot
>>    ! local variables                                                  !
>>    integer(MPI_OFFSET_KIND)              :: nx_mpi,ny_mpi, nz_mpi,
>> y_cl_mpi
>>    integer(MPI_OFFSET_KIND)              :: istart,jstart
>>    integer(kint)                         :: STATUS
>>    character(len=50)                     :: OP  ! debugging variable
>> corresponding to the called netCDF OPeration
>>    integer(kint)                         :: NCID
>>    integer(kint)                         :: i
>>    logical                               :: DynMovie_flag,
>> bounds_control
>>    integer(kint)                         :: y_st, y_sp, y_cl
>>    ! replace DynMovie precompiler flag by program flag for more
>> convenient code structure
>>    DynMovie_flag = .false.
>> #ifdef DynMovie
>>    DynMovie_flag = .true.
>> #endif
>>    ! re-assign dimension lengths as an MPI_Offset type (necessary for
>> the PnetCDF interface)
>>    ! cut-off subdomain borders
>>    nx_mpi  = nx-2
>>    ny_mpi  = ny-2
>>    nz_mpi  = nz
>>    ! assign coordinates of first element of each process in the
>> netCDF file
>>    istart = mycoor(1)*nx_mpi + 1_MPI_OFFSET_KIND
>>    jstart = mycoor(2)*ny_mpi + 1_MPI_OFFSET_KIND
>>    bounds_control = .true. ! debugging flag
>>    tcounter = tcounter+1_MPI_OFFSET_KIND
>>    ! === open netCDF dataset: enter data mode ------------------------!
>>    ! if     dataset does not yet exist (STATUS =  ), create file and
>> enter data mode
>>    ! else   continue
>>    OP = 'open existing netCDF file'
>>    STATUS = nfmpi_open(my_cart, trim(outfile), NF_WRITE,
>> MPI_INFO_NULL, NCID)
>>    if ( STATUS /= nf_noerr ) then
>>       if (myrank==0) then
>>          print *, ""
>>          print *, "P-NetCDF operation: ",trim(OP)
>>          print *, trim(nfmpi_strerror(STATUS))
>>          print *, "atham_pnetcdf netcdf_data(): new netCDF file
>> created: ", outfile
>>          print *, ""
>>       end if
>>       call netcdf_define(outfile,out_type,timetot,NCID)
>>       tcounter = 1_MPI_OFFSET_KIND ! reset time counter for output if
>> new file is created
>>    end if
>>    ! ---                        write data values --------------------!
>>    ! unlimited record dimension time (only one process writes the
>> whole dimension, i.e. accross all processes)
>>    OP = 'write data values - unlimited dimension t'
>>    call handle_err(nfmpi_begin_indep_data(NCID))
>>    if (myrank==0) then
>>       call handle_err(nfmpi_put_vara_real(NCID, t_varID,
>> (/tcounter/), (/1_MPI_OFFSET_KIND/), real(timetot,real4)),OP)
>>    end if
>>    call handle_err(nfmpi_end_indep_data(NCID))
>>    ! discriminate between 2D and 3D case for output generation
>>    if (nty>4) then
>>       y_st = 2    ! y index start
>>       y_sp = ny-1 ! y index stop
>>       y_cl = ny-2 ! y number of columns
>>    else
>>       y_st = ny-1 ! 3 in 2D case
>>       y_sp = ny-1 ! 3 in 2D case
>>       y_cl = 1
>>    end if
>>    y_cl_mpi = y_cl
>>    ! dynamics data
>>    OP = 'write data values - data'
>>    if (out_type == 1 .OR. DynMovie_flag == .true.) then
>>       call write_data(real(unew,real4),u_varID)
>>       bounds_control = .false.
>>       call write_data(real(vnew,   real4),v_varID)
>>       call write_data(real(wnew,   real4),w_varID)
>>       call write_data(real(pnew,   real4),pnew_varID)
>>       call write_data(real(tetnew, real4),tetnew_varID)
>>       call write_data(real(tempnew,real4),tempnew_varID)
>>       call write_data(real(density,real4),density_varID)
>>       call write_data(real(turbhor,real4),turbhor_varID)
>>       call write_data(real(turbver,real4),turbver_varID)
>>       call write_data(real(turblen,real4),turblen_varID)
>>    end if
>>    ! tracer data
>>    if (out_type == 1) then
>>       do i=1,ntgas_picture
>>          call
>> write_data(real(tgasnew(:,:,:,itgas_picture(i)),real4),tgas_varID(i))
>>       enddo
>>       do i=1,ntrac_picture
>>          call
>> write_data(real(tracnew(:,:,:,itrac_picture(i)),real4),trac_varID(i))
>>       enddo
>>       do i=1,ntpas_picture
>>          call
>> write_data(real(tpasnew(:,:,:,itpas_picture(i)),real4),tpas_varID(i))
>>       enddo
>> d_trac_varID(i),(/istart,jstart,tcounter/), &
>>               (/nx_mpi,y_cl_mpi,1_MPI_OFFSET_KIND/),
>> real(reshape(tracdep(2:nx-1,y_st:y_sp,itrac_picture(i)),shape=(/nx-2,y_cl,1/)),real4)
>> ),OP)
>>       enddo
>>    else if (out_type == 2) then
>>       do i=1,ntgas_movie
>>          call
>> write_data(real(tgasnew(:,:,:,itgas_movie(i)),real4),tgas_varID(i))
>>       enddo
>>       do i=1,ntrac_movie
>>          call
>> write_data(real(tracnew(:,:,:,itrac_movie(i)),real4),trac_varID(i))
>>       enddo
>>       do i=1,ntpas_movie
>>          call
>> write_data(real(tpasnew(:,:,:,itpas_movie(i)),real4),tpas_varID(i))
>>       enddo
>>    endif
>>    ! === close netCDF dataset: exit data mode & save -----------------!
>>    OP = 'close netCDF file'
>>    call handle_err(nfmpi_close(NCID))
>>    if (myrank==0) then
>>       print *, ''
>>       print *, 'wrote netCDF output to file ', outfile
>>       print *, ''
>>    end if
>>    contains
>>      subroutine write_data(array_in,varID)
>>        ! IF: array_in = data array (3D) to be written to netCDF
>>        !     varID    = data variable netCDF ID
>>        use atham_module, only : iflgs ! topography mask: topography
>> (iflgs=0) remains undef
>>        use atham_module, only  : myrank
>>        real(real4),dimension(nx,ny,nz), intent (in   )   :: array_in
>>        integer(kint),                intent(in   )       :: varID
>>        ! local variables                                              !
>>        real(real4), dimension(nx,ny,nz)            :: array_masked
>>        ! dimensions & bounds control
>>        integer(MPI_OFFSET_KIND)                    :: dimlenx,
>> dimleny, dimlenz, dimlent
>>        integer(kint), dimension(NF_max_var_dims)   :: dimIDs
>>        if (myrank == 0) then
>>           if (bounds_control) then
>>              print *, ''
>>              print *, 'atham var in xyz              ',shape(array_in)
>>              print *, 'atham var reshaped to xyzt
>> ',shape(reshape(array_in(2:nx-1,y_st:y_sp,1:nz),shape=(/nx-2,y_cl,nz,1/)))
>>              call handle_err(nfmpi_inq_vardimid(NCID, u_varID,
>> dimIDs)) ! taken unew as ref
>>              call handle_err(nfmpi_inq_dimlen(NCID, dimIDs(1), dimlenx))
>>              call handle_err(nfmpi_inq_dimlen(NCID, dimIDs(2), dimleny))
>>              call handle_err(nfmpi_inq_dimlen(NCID, dimIDs(3), dimlenz))
>>              call handle_err(nfmpi_inq_dimlen(NCID, dimIDs(4), dimlent))
>>              print *, 'netCDF var dimensions in xyzt
>> ',dimlenx,dimleny,dimlenz,dimlent
>>           end if
>>        end if
>>        ! mask topography
>>        where (iflgs == 1)
>>           array_masked = array_in
>>        elsewhere
>>           array_masked = undef
>>        endwhere
>>        ! mask control
>>        !print *, ''
>>        !print *, 'topography mask'
>>        !print *, iflgs(1:5,3,3)
>>        !print *, iflgs(1:5,3,2)
>>        !print *, iflgs(1:5,3,1)
>>        !print *, ''
>>        !print *, 'masked variable array'
>>        !print *, array_masked(:,3,3)
>>        !print *, array_masked(:,3,2)
>>        !print *, array_masked(:,3,1)
>>        !print *, ''
>> varID,(/istart,jstart,1_MPI_OFFSET_KIND,tcounter/), &
>>             (/nx_mpi,y_cl_mpi,nz_mpi,1_MPI_OFFSET_KIND/),
>> reshape(array_masked(2:nx-1,y_st:y_sp,1:nz),shape=(/nx-2,y_cl,nz,1/))
>> ),OP)
>>      end subroutine write_data
>>  end subroutine netcdf_data
>>  subroutine netcdf_define(outfile,out_type,timetot,ncid_def)
>>    !     timetot = simulation time since simulation start (from
>> atham/atham_out)
>>    !     ncid_def = netCDF ID assigned to file during creation
>>    use atham_module, only   : var_tgas_picture,
>> var_tgas_movie,           &
>>                               des_tgas_picture,
>> des_tgas_movie,           &
>>                               var_trac_picture,
>> var_trac_movie,           &
>>                               des_trac_picture,
>> des_trac_movie,           &
>>                               var_tpas_picture,
>> var_tpas_movie,           &
>>                               des_tpas_picture, des_tpas_movie
>>    use atham_module, only   : iindex, spinup, nrep, periodt
>>    use atham_module, only   : volcano_setup,
>> coignimbrite_setup,          &
>>                               nuclear_setup, convection_setup,
>> procsconfig_setup
>>    use atham_module, only   : x, y, z, xg, yg
>>    use atham_module, only   : grid2geo, sim_d_YYYY, sim_d_MM,
>> sim_d_DD,   &
>>                               sim_t_hh, sim_t_mm, sim_t_ss
>>    use atham_module, only   : my_cart, myrank
>>    integer(kint),          intent(  out) :: ncid_def
>>    ! local variables                                                  !
>>    integer(MPI_OFFSET_KIND)              :: ntx_mpi,nty_mpi,nz_mpi
>>    integer(kint)                         :: i
>>    character(len=50)                     :: var, des
>>    real(kreal)                           :: toffset
>>    real(real4)                           :: coord_scale,
>> coord_x_offset, coord_y_offset, coord_t_offset
>>    character(len=3)                      :: coord_x_name,
>> coord_y_name, coord_z_name
>>    character(len=4)                      :: coord_t_name
>>    character(len=9)                      :: coord_x_lname, coord_y_lname
>>    character(len=13)                     :: coord_x_units, coord_y_units
>>    character(len=33)                     :: coord_t_units
>>    character(len=8)                      :: date
>>    character(len=10)                     :: time
>>    character(len=19)                     :: simdatetime
>>    character(len=10)                     :: simdate
>>    character(len=20)                     :: login
>>    character(len=63)                     :: hist_string
>>    integer(kint)                         :: isetup
>>    character(len=12)                     :: model_setup(6)
>>    data model_setup /'volcano     ', 'coignimbrite', 'nuclear     ',
>> 'convection  ', 'procsconfig ','unknown     '/
>> #ifdef DynMovie
>> #endif
>>    ! cut-off domain borders
>>    ntx_mpi = ntx-2
>>    nty_mpi = nty-2
>>    nz_mpi  = nz
>>    ! convert date and time integers into string 'YYYYMMDD hh:mm:ss'
>>    write (simdatetime,10)
>> sim_d_YYYY,sim_d_MM,sim_d_DD,sim_t_hh,sim_t_mm,sim_t_ss
>> 10 format (I4,'-',I2,'-',I2,1X,I2,':',I2,':',I2)
>>    simdate = simdatetime(1:10)
>>    ! switch between cartesian axes/time (default) and geographic
>> axes/date (linear approx)
>>    coord_scale    = 1._real4
>>    coord_x_offset = 0._real4
>>    coord_x_name   = 'x  '
>>    coord_x_lname  = 'x_coor   '
>>    coord_x_units  = 'm            '
>>    coord_y_offset = 0._real4
>>    coord_y_name   = 'y  '
>>    coord_y_lname  = 'y_coor   '
>>    coord_y_units  = 'm            '
>>    coord_z_name   = 'z  '
>>    coord_t_offset = 0._real4
>>    coord_t_name   = 'time'
>>    coord_t_units  = 'sec                              '
>>    if (grid2geo) then
>>       call
>> gridconvert(coord_scale,coord_x_offset,coord_x_name,coord_x_lname,coord_x_units,
>> coord_y_offset,coord_y_name,coord_y_lname,coord_y_units, &
>> coord_z_name,coord_t_offset,coord_t_name,coord_t_units)
>>    end if
>>    ! === create netCDF dataset: enter define mode --------------------!
>>    OP = 'enter define mode'
>>    call handle_err(nfmpi_create(my_cart, trim(outfile), 0,
>> MPI_INFO_NULL,NCID),OP)
>>    ncid_def = NCID
>>    ! === create netCDF dataset: assign metadata ----------------------!
>>    ! ---                        set global attributes ----------------!
>>    OP = 'set global attributes'
>>       toffset = timetot - spinup
>>       call handle_err(nfmpi_put_att_text(NCID, NF_GLOBAL, 'title',
>> 13_MPI_OFFSET_KIND, 'atham_picture'),OP)
>>    else
>>       toffset = timetot - spinup - nrep*periodt
>> 11_MPI_OFFSET_KIND, 'atham_movie'),OP)
>>    end if
>>    call handle_err(nfmpi_put_att_text(NCID, NF_GLOBAL, 'content',
>> 223_MPI_OFFSET_KIND, &
>>         'This data corresponds to a simulation run of the
>> mesoscale-beta/gamma type non-hydrostatic Active Tracer
>> High-resolution Atmospheric Model ATHAM ' &
>>         // '(Oberhuber et al., 1998, Herzog, 1998), for a setup as
>> specified under history'),OP) ! ######### add further description as
>> necessary
>>    call handle_err(nfmpi_put_att_text(NCID, NF_GLOBAL, 'version',
>> 21_MPI_OFFSET_KIND, 'no current versioning'),OP) ! ######### change
>> once available
>>    call date_and_time(date, time)
>>    call getlog(login)
>>    if (volcano_setup) then
>>       isetup=1
>>    else if (coignimbrite_setup) then
>>       isetup=2
>>    else if (nuclear_setup) then
>>       isetup=3
>>    else if (convection_setup) then
>>       isetup=4
>>    else if (procsconfig_setup) then
>>       isetup=5
>>    else
>>       isetup=6
>>    end if
>>    hist_string = trim(date//' '//time//'  '//trim(login)//'  atham
>> '//model_setup(isetup))
>> !    call handle_err(nfmpi_put_att_text(NCID, NF_GLOBAL, 'history',
>> 63_MPI_OFFSET_KIND, hist_string),OP) ! 1 line/modification:  - cmd arg
>> 'Conventions', 28_MPI_OFFSET_KIND, 'COARDS, //cf-pcmdi.llnl.gov/'),OP)
>> 'sim_onset_date_time', 19_MPI_OFFSET_KIND, simdatetime),OP)
>> !    call handle_err(nfmpi_put_att_real(NCID, NF_GLOBAL,
>> 'sim_time_offset', NF_FLOAT, 1_MPI_OFFSET_KIND, real(toffset,real4)),OP)
>> 'x_zoom_location', NF_FLOAT, 1_MPI_OFFSET_KIND,
>> real(x(max(1,iindex)),real4)),OP)
>>    ! ---                        define dimensions --------------------!
>>    OP = 'define dimensions'
>>    call handle_err(nfmpi_def_dim(NCID, trim(coord_x_name),
>> ntx_mpi,             x_dimID),OP)
>>    if (nty>4) then
>>       call handle_err(nfmpi_def_dim(NCID, trim(coord_y_name),
>> nty_mpi,             y_dimID),OP)
>>    else
>> 1_MPI_OFFSET_KIND,   y_dimID),OP)
>>    end if
>>    call handle_err(nfmpi_def_dim(NCID, trim(coord_z_name),
>> nz_mpi,              z_dimID),OP)
>>    call handle_err(nfmpi_def_dim(NCID, coord_t_name,
>> nfmpi_unlimited,     t_dimID),OP)
>>    ! ---                        define variables ---------------------!
>>    ! dimensions
>>    OP = 'define variables - dimensions'
>>    call handle_err(nfmpi_def_var(NCID, trim(coord_x_name),
>> NF_FLOAT, 1, x_dimID, x_varID),OP)
>>    call handle_err(nfmpi_def_var(NCID, trim(coord_y_name),
>> NF_FLOAT, 1, y_dimID, y_varID),OP)
>>    call handle_err(nfmpi_def_var(NCID, trim(coord_z_name),
>> NF_FLOAT, 1, z_dimID, z_varID),OP)
>>    call handle_err(nfmpi_def_var(NCID, coord_t_name,
>> NF_FLOAT, 1, t_dimID, t_varID),OP)
>>    ! dynamics data
>>    OP = 'define variables - data'
>>       call handle_err(nfmpi_def_var(NCID, 'u',       NF_FLOAT, 4,
>> (/x_dimID,y_dimID,z_dimID,t_dimID/), u_varID),OP)
>>       call handle_err(nfmpi_def_var(NCID, 'v',       NF_FLOAT, 4,
>> (/x_dimID,y_dimID,z_dimID,t_dimID/), v_varID),OP)
>>       call handle_err(nfmpi_def_var(NCID, 'w',       NF_FLOAT, 4,
>> (/x_dimID,y_dimID,z_dimID,t_dimID/), w_varID),OP)
>>       call handle_err(nfmpi_def_var(NCID, 'pnew',    NF_FLOAT, 4,
>> (/x_dimID,y_dimID,z_dimID,t_dimID/), pnew_varID),OP)
>>       call handle_err(nfmpi_def_var(NCID, 'tetnew',  NF_FLOAT, 4,
>> (/x_dimID,y_dimID,z_dimID,t_dimID/), tetnew_varID),OP)
>>       call handle_err(nfmpi_def_var(NCID, 'tempnew', NF_FLOAT, 4,
>> (/x_dimID,y_dimID,z_dimID,t_dimID/), tempnew_varID),OP)
>>       call handle_err(nfmpi_def_var(NCID, 'density', NF_FLOAT, 4,
>> (/x_dimID,y_dimID,z_dimID,t_dimID/), density_varID),OP)
>>       call handle_err(nfmpi_def_var(NCID, 'turbhor', NF_FLOAT, 4,
>> (/x_dimID,y_dimID,z_dimID,t_dimID/), turbhor_varID),OP)
>>       call handle_err(nfmpi_def_var(NCID, 'turbver', NF_FLOAT, 4,
>> (/x_dimID,y_dimID,z_dimID,t_dimID/), turbver_varID),OP)
>>       call handle_err(nfmpi_def_var(NCID, 'turblen', NF_FLOAT, 4,
>> (/x_dimID,y_dimID,z_dimID,t_dimID/), turblen_varID),OP)
>>    end if
>>    ! tracer data
>>          call handle_err(nfmpi_def_var(NCID, var_tgas_picture(i),
>> NF_FLOAT, 4, (/x_dimID,y_dimID,z_dimID,t_dimID/), tgas_varID(i)),OP)
>>       enddo
>>          call handle_err(nfmpi_def_var(NCID, var_trac_picture(i),
>> NF_FLOAT, 4, (/x_dimID,y_dimID,z_dimID,t_dimID/), trac_varID(i)),OP)
>>       enddo
>>          call handle_err(nfmpi_def_var(NCID, var_tpas_picture(i),
>> NF_FLOAT, 4, (/x_dimID,y_dimID,z_dimID,t_dimID/), tpas_varID(i)),OP)
>>       enddo
>>          var='d_'//trim(var_trac_picture(i))
>>          call handle_err(nfmpi_def_var(NCID, var,
>> NF_FLOAT, 3, (/x_dimID,y_dimID,t_dimID/), d_trac_varID(i)),OP)
>>       enddo
>>       do i=1,ntgas_movie
>>          call handle_err(nfmpi_def_var(NCID, var_tgas_movie(i),
>>       enddo
>>       do i=1,ntrac_movie
>>          call handle_err(nfmpi_def_var(NCID, var_trac_movie(i),
>>       enddo
>>       do i=1,ntpas_movie
>>          call handle_err(nfmpi_def_var(NCID, var_tpas_movie(i),
>>       enddo
>>    endif
>>    ! ---                        assign attributes --------------------!
>>    ! common attributes: long_name, units, valid_range, scale_factor,
>> add_offset, _FillValue, history, conventions
>>    ! dimensions
>>    OP = 'assign attributes - dimensions'
>>    call handle_err(nfmpi_put_att_text(NCID, x_varID,
>> 'long_name',               9_MPI_OFFSET_KIND, trim(coord_x_lname)),OP)
>> 'units',                  13_MPI_OFFSET_KIND, trim(coord_x_units)),OP)
>> !    call handle_err(nfmpi_put_att_real(NCID, x_varID,
>> 'scale_factor', NF_FLOAT,  1_MPI_OFFSET_KIND, coord_scale),OP)
>> 'add_offset',   NF_FLOAT,  1_MPI_OFFSET_KIND, coord_x_offset),OP)
>>    call handle_err(nfmpi_put_att_text(NCID, y_varID,
>> 'long_name',               9_MPI_OFFSET_KIND, trim(coord_y_lname)),OP)
>> 'units',                  13_MPI_OFFSET_KIND, trim(coord_y_units)),OP)
>> !    call handle_err(nfmpi_put_att_real(NCID, y_varID,
>> 'add_offset',   NF_FLOAT,  1_MPI_OFFSET_KIND, coord_y_offset),OP)
>>    call handle_err(nfmpi_put_att_text(NCID, z_varID,
>> 'long_name',               6_MPI_OFFSET_KIND, 'height'),OP)
>> 'units',                   1_MPI_OFFSET_KIND, 'm'),OP)
>> !    call handle_err(nfmpi_put_att_text(NCID, z_varID,
>> 'positive',                2_MPI_OFFSET_KIND, 'up'),OP)
>>    call handle_err(nfmpi_put_att_text(NCID, t_varID,
>> 'long_name',               4_MPI_OFFSET_KIND, coord_t_name),OP)
>> 'units',                  33_MPI_OFFSET_KIND, trim(coord_t_units)),OP)
>> !    call handle_err(nfmpi_put_att_real(NCID, t_varID,
>> 'add_offset',   NF_FLOAT,  1_MPI_OFFSET_KIND, coord_t_offset),OP)
>> !    OP = 'exit define mode NOW for testing
>> ****************************************************' ! ah_testing
>> !    call
>> handle_err(nfmpi_enddef(NCID),OP)
>> ! ah_testing ********************************
>>    ! dynamics data
>>    OP = 'assign attributes - data'
>> !       call handle_err(nfmpi_put_att_text(NCID, u_varID,
>> 'long_name',              6_MPI_OFFSET_KIND, 'x_wind'),OP)
>> 'units',                  7_MPI_OFFSET_KIND, 'm sec-1'),OP)
>> !       call handle_err(nfmpi_put_att_real(NCID, u_varID,
>> 'scale_factor',NF_FLOAT,  1_MPI_OFFSET_KIND, 1.),OP)
>> 'add_offset',  NF_FLOAT,  1_MPI_OFFSET_KIND, 0.0),OP)
>> '_FillValue',  NF_FLOAT,  1_MPI_OFFSET_KIND, undef),OP)
>> !       call handle_err(nfmpi_put_att_text(NCID, v_varID,
>> 'long_name',              6_MPI_OFFSET_KIND, 'y_wind'),OP)
>> !       call handle_err(nfmpi_put_att_real(NCID, v_varID,
>> !       call handle_err(nfmpi_put_att_text(NCID, w_varID,
>> 'long_name',             19_MPI_OFFSET_KIND, 'upward_air_velocity'),OP)
>> !       call handle_err(nfmpi_put_att_real(NCID, w_varID,
>> !       call handle_err(nfmpi_put_att_text(NCID, pnew_varID,
>> 'long_name',             20_MPI_OFFSET_KIND, 'air_pressure_anomaly'),OP)
>> 'units',                  2_MPI_OFFSET_KIND, 'Pa'),OP)
>> !       call handle_err(nfmpi_put_att_real(NCID, pnew_varID,
>> !       call handle_err(nfmpi_put_att_text(NCID, tetnew_varID,
>> 'long_name',             25_MPI_OFFSET_KIND,
>> 'air_potential_temperature'),OP)
>> 'units',                  1_MPI_OFFSET_KIND, 'K'),OP)
>> !       call handle_err(nfmpi_put_att_real(NCID, tetnew_varID,
>> !       call handle_err(nfmpi_put_att_text(NCID, tempnew_varID,
>> 'long_name',             15_MPI_OFFSET_KIND, 'air_temperature'),OP)
>> 'units',                  7_MPI_OFFSET_KIND, 'Celsius'),OP)
>> !       call handle_err(nfmpi_put_att_real(NCID, tempnew_varID,
>> 'add_offset',  NF_FLOAT,  1_MPI_OFFSET_KIND, -273.15),OP)
>> !       call handle_err(nfmpi_put_att_text(NCID, density_varID,
>> 'long_name',             11_MPI_OFFSET_KIND, 'air_density'),OP)
>> 'units',                  6_MPI_OFFSET_KIND, 'kg m-3'),OP)
>> !       call handle_err(nfmpi_put_att_real(NCID, density_varID,
>> !       call handle_err(nfmpi_put_att_text(NCID, turbhor_varID,
>> 'long_name',             15_MPI_OFFSET_KIND, 'hor_turb_energy'),OP)
>> 'units',                  8_MPI_OFFSET_KIND, 'm2 sec-2'),OP)
>> !       call handle_err(nfmpi_put_att_real(NCID, turbhor_varID,
>> !       call handle_err(nfmpi_put_att_text(NCID, turbver_varID,
>> 'long_name',             15_MPI_OFFSET_KIND, 'ver_turb_energy'),OP)
>> !       call handle_err(nfmpi_put_att_real(NCID, turbver_varID,
>> !       call handle_err(nfmpi_put_att_text(NCID, turblen_varID,
>> 'long_name',             17_MPI_OFFSET_KIND, 'turb_length_scale'),OP)
>> !       call handle_err(nfmpi_put_att_real(NCID, turblen_varID,
>>    end if
>>    ! tracer data
>>       print *, 'NetCDF output type (1-picture,2-movie) ',out_type !
>> #####  DO NOT REMOVE!!! optimization problem, trace source
>>          call handle_err(nfmpi_put_att_text(NCID, tgas_varID(i),
>> 'long_name',             25_MPI_OFFSET_KIND, des_tgas_picture(i)),OP)
>> 'units',                  9_MPI_OFFSET_KIND, 'gram kg-1'),OP)
>>          call handle_err(nfmpi_put_att_real(NCID, tgas_varID(i),
>> 'scale_factor',NF_FLOAT,  1_MPI_OFFSET_KIND, 1000.),OP)
>>       enddo
>>          call handle_err(nfmpi_put_att_text(NCID, trac_varID(i),
>> 'long_name',             25_MPI_OFFSET_KIND, des_trac_picture(i)),OP)
>>          call handle_err(nfmpi_put_att_real(NCID, trac_varID(i),
>>       enddo
>>          call handle_err(nfmpi_put_att_text(NCID, tpas_varID(i),
>> 'long_name',             25_MPI_OFFSET_KIND, des_tpas_picture(i)),OP)
>> 'units',                  1_MPI_OFFSET_KIND, '%'),OP)
>>          call handle_err(nfmpi_put_att_real(NCID, tpas_varID(i),
>> 'scale_factor',NF_FLOAT,  1_MPI_OFFSET_KIND, 100.),OP)
>>       enddo
>>          des='deposited_'//trim(des_trac_picture(i))
>>          call handle_err(nfmpi_put_att_text(NCID, d_trac_varID(i),
>> 'long_name',             35_MPI_OFFSET_KIND, des),OP)
>> 'units',                  9_MPI_OFFSET_KIND, 'gram m-2'),OP)
>>          call handle_err(nfmpi_put_att_real(NCID, d_trac_varID(i),
>>       enddo
>>       do i=1,ntgas_movie
>> 'long_name',             25_MPI_OFFSET_KIND, des_tgas_movie(i)),OP)
>>       enddo
>>       do i=1,ntrac_movie
>> 'long_name',             25_MPI_OFFSET_KIND, des_trac_movie(i)),OP)
>>       enddo
>>       do i=1,ntpas_movie
>> 'long_name',             25_MPI_OFFSET_KIND, des_tpas_movie(i)),OP)
>>       enddo
>>    end if
>>    ! === create netCDF dataset: exit define mode, enter data mode ----!
>>    OP = 'exit define mode'
>>    call handle_err(nfmpi_enddef(NCID),OP)
>>    ! dimensions (only one process writes the whole dimension, i.e.
>>    OP = 'write data values - dimensions'
>>    if (myrank==0) then
>>       call handle_err(nfmpi_put_vara_real(NCID, x_varID,
>> (/1_MPI_OFFSET_KIND/), (/ntx_mpi/),real(xg(2:ntx-1),real4)),OP)
>>       if (nty>4) then
>>          call handle_err(nfmpi_put_vara_real(NCID, y_varID,
>> (/1_MPI_OFFSET_KIND/), (/nty_mpi/), real(yg(2:nty-1),real4)),OP)
>>       else
>> (/1_MPI_OFFSET_KIND/), (/1_MPI_OFFSET_KIND/), real(yg(nty-1),real4)),OP)
>>       end if
>>       call handle_err(nfmpi_put_vara_real(NCID, z_varID,
>> (/1_MPI_OFFSET_KIND/), (/nz_mpi/), real(z,real4)),OP)
>>    end if
>>    contains
>>      subroutine
>> gridconvert(cd_scale,cd_x_offset,cd_x_name,cd_x_lname,cd_x_units, &
>> cd_y_offset,cd_y_name,cd_y_lname,cd_y_units, &
>> cd_z_name,cd_t_offset,cd_t_name,cd_t_units)
>>        ! IF: cd_* = coordinate parameters
>>        ! linear conversion from cartesian grid into lon/lat system    !
>>        ! only valid as first approxiamtion over small domains         !
>>        ! to be replaced once a dyn core in a lat/lon system available !
>>        use atham_module, only             : deglat_start, deglon_start
>>        use phys_constants, only           : pi
>>        real(real4),        intent(inout) :: cd_scale, cd_x_offset,
>> cd_y_offset, cd_t_offset
>>        character(len=3),   intent(inout) :: cd_x_name, cd_y_name,
>> cd_z_name
>>        character(len=4),   intent(inout) :: cd_t_name
>>        character(len=9),   intent(inout) :: cd_x_lname, cd_y_lname
>>        character(len=13),  intent(inout) :: cd_x_units, cd_y_units
>>        character(len=33),  intent(inout) :: cd_t_units
>>        ! local variables                                              !
>>        real(kreal)                       :: r
>>        real(kreal), parameter            :: a = 6378137._kreal     !
>> (WGS 84)
>>        real(kreal), parameter            :: b = 6356752.3142_kreal !
>> (WGS 84)
>>        ! ellipsoid radius at ATHAM domain start
>>        r = a*b / sqrt((b*b*(cos(deglat_start*pi/180._kreal))**2
>> )+(a*a*(sin(deglat_start*pi/180._kreal))**2 ))
>>        cd_scale    = real((1/r) * (180._kreal/pi),real4)
>>        cd_x_offset = deglon_start
>>        cd_x_name   = 'lon'
>>        cd_x_lname  = 'longitude'
>>        cd_x_units  = 'degrees_east '
>>        cd_y_offset = deglat_start
>>        cd_y_name   = 'lat'
>>        cd_y_lname  = 'latitude '
>>        cd_y_units  = 'degrees_north'
>>        cd_z_name   = 'lev'
>>        coord_t_offset = real((sim_t_hh*3600 + sim_t_mm*60
>> +sim_t_ss),real4)
>>        coord_t_name   = 'date'
>>        coord_t_units  = 'seconds since '//simdate//' 00:00:00 [local]'
>>        ! COARDS conventions require time zone from UTC to be specified
>>        ! not necessary for local area version of ATHAM
>>      end subroutine gridconvert
>>  end subroutine netcdf_define
>> subroutine handle_err(status,op)
>>  integer,                    intent (in   ) :: status
>>  character(len=*), optional, intent (in   ) :: op
>>  if ( status /= nf_noerr ) then
>>     if (myrank==0) then
>>        print *, ""
>>        print *, "P-NetCDF operation: ",trim(op)
>>        print *, trim(nfmpi_strerror(status))
>>        print *, "atham_pnetcdf error: program execution stopped"
>>        print *, ""
>>        stop
>>     end if
>>  end if
>>  return
>> end subroutine handle_err
>> end module atham_pnetcdf
