can't build on linux system...
Robert Latham
robl at mcs.anl.gov
Thu Oct 23 17:31:00 CDT 2008
On Wed, Oct 22, 2008 at 12:05:48PM -0500, Robert Latham wrote:
> On Wed, Oct 22, 2008 at 07:39:43AM -0600, Ed Hartnett wrote:
> > "kgao at eecs" <kgao at eecs.northwestern.edu> writes:
> > > Hi Ed Hartnett,
> > > Please remove '--disable-fortran' and try it again.
> > > When I run "./configure --with-mpi=/home/kgao/mpich2-1.0.7
> > > --disable-fortran" on our cluster, the same problem is appeared.
> > > When I run "./configure --with-mpi=/home/kgao/mpich2-1.0.7", it is
> > > OK.
> > > Regards,
> > > Kui.
> > That was it! Thanks!
> Wow, wonder what's going on there. I'll have to investigate further.
> I've put this in the bug tracker so I don't forget..
Well that's interesting. Apparently in the "enable fortran" path,
something invokes AC_HEADER_STDC. Well, something invokes something
that invokes AC_HEADER_STDC... I kind of got lost in the M4 macro
maze.
Also: this only happens on x86-64. I don't test on that platform very
often. I should fix that, too.
Thanks for the bug report. I'll commit this to SVN after a bit more
testing.
==rob
Rob Latham
Mathematics and Computer Science Division A215 0178 EA2D B059 8CDF
Argonne National Lab, IL USA B29D F333 664A 4280 315B
More information about the parallel-netcdf
