can't build on linux system...
Robert Latham
robl at mcs.anl.gov
Wed Oct 22 12:05:48 CDT 2008
On Wed, Oct 22, 2008 at 07:39:43AM -0600, Ed Hartnett wrote:
> "kgao at eecs" <kgao at eecs.northwestern.edu> writes:
> > Hi Ed Hartnett,
> > Please remove '--disable-fortran' and try it again.
> > When I run "./configure --with-mpi=/home/kgao/mpich2-1.0.7
> > --disable-fortran" on our cluster, the same problem is appeared.
> > When I run "./configure --with-mpi=/home/kgao/mpich2-1.0.7", it is
> > OK.
> > Regards,
> > Kui.
> That was it! Thanks!
Wow, wonder what's going on there. I'll have to investigate further.
I've put this in the bug tracker so I don't forget..
> Now it builds and installs just fine.
> I notice there is no "check" target. Is there a set of tests I should
> run?
In addition to Kui's tips, you can also use "make testing"
> Thanks!
> Ed
Welcome to pnetcdf! Hope you enjoy what you see :>
==rob
Rob Latham
Mathematics and Computer Science Division A215 0178 EA2D B059 8CDF
Argonne National Lab, IL USA B29D F333 664A 4280 315B
More information about the parallel-netcdf
