argument stride in ncmpi_put_vars_all()
Wei-keng Liao
wkliao at ece.northwestern.edu
Thu May 24 14:02:08 CDT 2007
According to the NetCDF C interface guide, the argument stride in
functions nc_get_vars_* and nc_put_vars_* can be NULL, which is
equivalent to passing (1,1,...,1).
I checked the source file for ncmpi_put_vars_all(), there is no such
checking and can cause application Segmentation fault if NULL is used.
This should be easy to correct by using a temp array allocated in
ncmpi_put_vars_all().
Wei-keng
More information about the parallel-netcdf
