problem with def_var
Jim Edwards
edwards.jim at gmail.com
Mon May 21 14:49:27 CDT 2007
Would it be possible to provide some identifying information at the enddef
call?
What call the problem came from, the varid or the attribute name? Binary
search will
get you there ... slooowly.
On 5/17/07, Robert Latham <robl at mcs.anl.gov> wrote:
> On Thu, May 10, 2007 at 11:27:35AM -0600, Jim Edwards wrote:
> > I'm getting a rather criptic message on initialization that I think
> means
> > that one of def_var, def_dim, or put_att has a confict from one mpi task
> to
> > the next:
> > NC definations on multiprocesses conflict.
> > NOTE: Definitions across all process
> > the problem is that it's at enddef that I get this message so I can't
> tell
> > which of the 50 or so calls prior to that is really the problem. Is
> there
> > any way to move this message closer to the point of origin?
> Hi Jim
> We don't have any way to do that now: processes don't communicate
> their header information until enddef for performance reasons.
> Having a way to debug this sort of problem would be useful. We could
> have an optional debugging mode that did some sort of header
> comparison after every def_far, def_dim, put_att, etc. Since that
> would be a collective call, processes would hang if they were doing
> the wrong thing.
> Since I'm not going to be able to implement this debugging mode for a
> bit, another short-term approach would be to take a binary search
> through the 50 calls, insering enddef/begindef calls after 25 calls.
> If the newly placed enddef doesn't trigger the message, then you've
> narrowed your search by half. repeat until you find the bunk call.
> Not the most attractive solution, but will probably get you on your
> way fastest.
> ==rob
> Rob Latham
> Mathematics and Computer Science Division A215 0178 EA2D B059 8CDF
> Argonne National Lab, IL USA B29D F333 664A 4280 315B
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20070521/3e347d17/attachment.htm>
More information about the parallel-netcdf
