example timings
michael bane michael.bane at manchester.ac.uk
Wed Jul 18 15:30:21 CDT 2007
On Wed, 2007-07-18 at 15:19 -0500, Wei-keng Liao wrote:
> Can you run the following command on the directory where your
> output files will be stored?
>    lfs getstripe <dir path> |grep stripe
> This will show the stripe info of a Lustre directory.
> Wei-keng
Wei-keng, thanks for helping on this (I'm new to Lustre). Here's the
output:
~$ lfs getstripe ~/tmp/test_par_netcdf/ | grep -i stripe
and if I choose an arbitrary file:
~$ lfs getstripe tmp/test_par_netcdf/newFile_gather_f90.ncf
OBDS:
0: ost_horace2.nec.1_UUID ACTIVE
1: ost_horace2.nec.0_UUID ACTIVE
        obdidx           objid          objid            group
             1         2840580       0x2b5804                0
             0         2840579       0x2b5803                0
all of which means nothing to me I have to admit!
Michael
