runtime problems with parallel netcdf on Apple intel machines
Robert Latham robl at mcs.anl.gov
Tue Jan 16 13:10:25 CST 2007
On Tue, Jan 16, 2007 at 09:44:31AM -0700, Amjad Majid Ali wrote:
> Hello,
> I have compiled and installed parallel-netcdf-1.0.1 on apple intel
> machine. I am using openmpi and intel ifort fortran compiler.
> I  am sending config.log and make.log file  and makeinstall.log
> When we try to use any applications. It hangs.  the first pnetcdf
> command (nfmpi_create) has problems.
> IS there any way that this could be solve??
Let's try to remove pnetcdf from the equation.  Does an mpi-only
application work?
> totalview does not work on  parallelnetcdf. ??
> Are there any other debuggers
Totalview should work, but you can also use GDB. Both won't do much
for you if you have not built pnetcdf with debugging symbols.
==rob
Rob Latham
Mathematics and Computer Science Division    A215 0178 EA2D B059 8CDF
Argonne National Lab, IL USA                 B29D F333 664A 4280 315B
