Big file support on BG with 32-bit off_t type
John Michalakes
john at michalakes.us
Mon Jan 8 14:54:23 CST 2007
Working on Blue Gene, we have a code that uses pnetcdf to successfully write a
large file (> 2GB, file type "2"). The pnetcdf library and code are compiled
with 32-bit addressing so that sizeof(off_t) is 4. The file appears to be
correct based on persual with ncdump.
We are unable to read the file back in, however, using pnetcdf with another
program also compiled with 32-bit addressing. The error return is: NC_ESMALL.
I believe the section of pnetcdf code returning the error is ncmpii_hdr_get_NC,
in header.c:
/* check version number in last byte of magic */
if (magic[sizeof(ncmagic)-1] == 0x1) {
getbuf.version = 1;
} else if (magic[sizeof(ncmagic)-1] == 0x2) {
getbuf.version = 2;
fSet(ncp->flags, NC_64BIT_OFFSET);
if (sizeof(off_t) != 8) {
/* take the easy way out: if we can't support all CDF-2
* files, return immediately */
free(getbuf.base);
return NC_ESMALL;
This is around line 1142.
Question: is this error condition correct and necessary? How does 32-bit pnetcdf
manage to *write* the large file (apparently) correctly?
Will pnetcdf compiled for OBJECT_MODE 64 work properly on Blue Gene?
Thank you,
John
John Michalakes, Software Engineer michalak at ucar.edu
NCAR, MMM Division voice: +1 303 497 8199
3450 Mitchell Lane fax: +1 303 497 8181
Boulder, Colorado 80301 U.S.A. cell: +1 720 209 2320
http://www.mmm.ucar.edu/individual/michalakes
More information about the parallel-netcdf
