Build process: sizeof (MPI_Offset)
Robert Latham
robl at mcs.anl.gov
Thu Dec 14 16:47:46 CST 2006
On Fri, Nov 17, 2006 at 06:49:55PM -0500, Christopher Subich wrote:
> There is a way to check sizeof_MPI_Offset at compile time; this example
> was adapted from the autoconf manual, which describes the same pattern
> for checking sizeof(int):
Good contribution, Christopher. This approach has been sorely needed
on many systems. Further, it reduces the nubmer of environment
variables I have to set before running configure on bluegene (as long
as I want the default gcc-based mpicc) to zero. That's fantastic.
Thanks
==rob
Rob Latham
Mathematics and Computer Science Division A215 0178 EA2D B059 8CDF
Argonne National Lab, IL USA B29D F333 664A 4280 315B
More information about the parallel-netcdf
