Compile pnetcdf library at a new Linux cluster at NERSC
Rob Ross
rross at mcs.anl.gov
Fri Dec 9 13:19:18 CST 2005
Not at this time, no. You'll have to use another compiler/MPI library.
We will look into options for allowing PnetCDF to operate without those
calls. Of course, MPI-IO itself is part of MPI-2, so we need a
significant fraction of MPI-2 :)...
Rob
Yu-Heng Tseng wrote:
> Yes. Only part of MPI-2 is implemented in the compiler.
> Both MPI_Type_dup and MPI_Request_get_status
> are not supported in the Linux cluster at NERSC (jacquard).
> Is it possible to test the library without both functionalities?
> Yu-Heng Tseng
> Computational Research Division
> Lawrence Berkeley National Laboratory
> One Cyclotron Rd, MS: 50F-1650
> Berkeley, CA94720
> YHTseng at lbl.gov
> 510.495.2904
> From: William Gropp <gropp at mcs.anl.gov>
> Date: Friday, December 9, 2005 5:02 am
> Subject: Re: Compile pnetcdf library at a new Linux cluster at NERSC
>> At 02:44 AM 12/9/2005, Yu-Heng Tseng wrote:
>>> Hi,
>>> I couldn't compile the library using "pathf90/pathcc" compiler. It
>>> gives me the following error during "gmake". It seems "MPI_Type_dup"
>>> is not defined. A bug in the compiler or the library?
>> Both MPI_Type_dup and MPI_Request_get_status are part of MPI-2.
>> What
>> version of MPI does your system support?
>> It sounds like we should add tests for these routines to the
>> configure step.
>> Bill
>>> mpicc -o ncmpigen -g -O2 -D_LARGEFILE64_SOURCE -
> D_FILE_OFFSET_BITS=64
>>> main.o load.o ncgentab.o escapes.o getfill.o init.o genlib.o -
>>> L../../../src/lib -lpnetcdf
>>> ../../../src/lib/libpnetcdf.a(mpinetcdf.o)(.text+0x1041d): In
>> function>`ncmpi_request_get_status':
>>> /scratch/scratchdirs/yhtseng/cam_PIO/CAMMODELS/parallel-netcdf-
>>> 1.0.1/src/lib/mpinetcdf.c:8218: undefined reference to
>>> `MPI_Request_get_status'
>>> ../../../src/lib/libpnetcdf.a(mpinetcdf.o)(.text+0x10cf4): In
>> function>`ncmpi_iget_var1':
>>> 1.0.1/src/lib/mpinetcdf.c:8528: undefined reference to
> `MPI_Type_dup'
>>> Yu-Heng Tseng
>>> Berkeley, CA94720
>>> YHTseng at lbl.gov
>>> 510.495.2904
>>> From: Jim Edwards <jedwards at ucar.edu>
>>> Date: Tuesday, December 6, 2005 0:40 am
>>> Subject: Re: Compile pnetcdf library in IBM SP at NCAR
>>>> There is a pnetcdf version installed in the /contrib file system
>>>> on the NCAR
>>>> IBM machines. I have already reported this problem with
> configure
>>>> to the
>>>> parallel netcdf developers. They have provided a patched
>> release to
>>>> address the problem.
>>>> Jim Edwards
>>>> IBM applications support
>>>> NCAR
>>>> On 12/6/05, Yu-Heng Tseng <YHTseng at lbl.gov> wrote:
>>>>> Hi,
>>>>> I couldn't compile the library in NCAR's IBM SP.
>>>>> It works fine in NERSC's IBM SP machine.
>>>>> I am not sure if this is compiler's or the library's problem.
>>>>> When I tried to "./configure" the
>>>>> it stops at the following line
>>>>> checking for Fortran-equivalent to netCDF "byte"... byte
>>>>> checking for Fortran-equivalent to netCDF "short"... integer*2
>>>>> checking for Fortran "integer*"... no
>>>>> configure: error: F77 does not support "integer*"
>>>>> The "integer*" is actually "integer8" in a successful check.
>>>>> Anyone has clues to solve the problem? The c compiler at NCAR
>>>>> seems different from that at NERSC.
>>>>> NCAR uses VisualAge C++ Professional / C for AIX Compiler,
>>>> Version 6
>>>>> Thanks a lot for your help!
>>>>> Yu-heng
>>>>> Yu-Heng Tseng
>>>>> Berkeley, CA94720
>>>>> YHTseng at lbl.gov
>>>>> 510.495.2904
>> William Gropp
>> http://www.mcs.anl.gov/~gropp
More information about the parallel-netcdf
