parallel-netcdf 0.9.4 released
Robert Latham robl at mcs.anl.gov
Thu Jul 22 17:55:36 CDT 2004
On Wed, Jul 21, 2004 at 03:33:08PM +0200, Joachim Worringen wrote:
> Problems I found (on SX-6):
> - configure probing for the sizeof(MPI_Offset): linking is done with $CC
> instead of $MPICC. This does not work on SX (don't ask me why; I know it
> should as no MPI function is referenced). This works alright on IA32. Anyway,
> in configure.in, line 245, it should read:
> if $MPICC -c conftest.c && $MPICC -o conftest conftest.o ; then
Ok, that change makes sense.  Jianwei, is there a platform (maybe the
IBM? ) where we should use CC instead of MPICC to link?
> - In the same context, the declaration of 'a' in line 236 can be omitted (our
> compiler gives ugly warning for unused variables.
fixed this to use 'sizeof(a)'
> Other notes:
> - I used the settings as described in README.SX. It seems that the additional
> iteration (calling make again in src/libf after the initial make) is no
> longer necessary, at least not on the system I tested on which was upgraded
> to Super-UX 14.1 from 12.1 in the meantime. As the additional invocation
> causes no harm, we should better leave the README as is.
good to know.  I'll make a note that the extra step might not be
necessary, but doesn't hurt things.
> - Although crossconfiguring does not work (checking for working ftruncate is
> not possible), configuring on the target host and then do a cross-compile
> works fine when setting up necessary aliases on the configure host (cc ->
> sxcc etc.) or vice versa on the compile host (sxcc -> cc). Might be changed
> in README.SX.
I've updates README.SX
> Test results for SX:
> _ nf_test: the int1 and int2 tests fail with "value read not that expected"
> for get operations and "Range error: No error" for put operations. I'll have
> to look into this more closely (if it has to do with the fact that integer*1
> is not supported on SX)
Most likely.  We *shouldn't* be running int1 tests if there is no int1
support:
#if defined(NF_INT1_T)
        external        test_nfmpi_get_var_int1
#endif
        call test('nfmpi_get_var1_int1', test_nfmpi_get_var1_int1)
#endif
so this might not be working like w
> - nc_test: passes with the expected two errors
great!
> - nc_test2: fails with a number of errors like this (also fails like this on
> IA32):
>         FAILURE at line 637 of util.c: ncmpi_put_vara_text_all: Edge+start
> exceeds dimension bound
> I assume this doesn't really matter as only nc_test and nf_test are included
> in the 'testing' target of test/Makefile?
nc_test2 still uses ptrdiff_t instead of MPI_Offset.  I'll add it to
the 'testing' target to make sure I don't make such a mistake again.
> Final note: is the introduction of a ncmpi_delete() function (wrapper for
> MPI_File_delete) still planned?
It should be in 0.9.4:
int
ncmpi_delete(char *filename, MPI_Info info)
I'm not sure if we'll ever need the 'info' parameter, but it's there
just in case.
Thanks for trying out the new release!
==rob
Rob Latham
Mathematics and Computer Science Division    A215 0178 EA2D B059 8CDF
Argonne National Labs, IL USA                B29D F333 664A 4280 315B
