Proposal for addressing latest bugs
Rob Ross
rross at mcs.anl.gov
Tue Feb 10 15:58:22 CST 2004
Hi all,
RobL and I have been looking at the code today to try to get a handle on
the issues that Rene and Joachim have brought up recently. Not sure we've
gotten them all figured out, but here's what we have so far:
- Move from using size_t to MPI_Offset in the API functions.
This will give us a clean interface for very large arrays at some future
date. It also clears up what the values should be when passed in,
syncing the API with the docs.
- Define some well-known value to be the same value as X_INT_MAX, and use
that in range checking.
X_INT_MAX is used in the code to check that the values passed in for
array dimensions etc. are within bounds. It's sort of a weird define,
and is actually defined in a few places (to be the same thing luckily!).
We'll drop this in pnetcdf.h so it's available in the tests etc.
- Move to using MPI_Offset from ptrdiff_t in the tests.
- off_t types used throughout the code should probably all be MPI_Offsets
too.
This leaves us with two things that we haven't exactly figured out what to
do with: Joachim's INT_MAX test errors, and the NF_*_IS_C_* problems that
Rene is having.
We'll get in touch with the Serial netCDF guys to see if they have a
solution to either of these problems that we can port to our version of
the library first -- they are clever guys and might already have figured
this out.
Comments on all this would very much be appreciated.
Thanks!
Rob
More information about the parallel-netcdf
