0.9.3 installation problems on GNU/Linux with lam-mpi
Rob Ross rross at mcs.anl.gov
Tue Feb 3 11:09:09 CST 2004
On Tue, 3 Feb 2004, Raimondo Giammanco wrote:
> On Tue, 2004-02-03 at 17:28, Rob Ross wrote:
> > Hi,
> > I see.  At least a few of those, if not all, are going to be due to the
> > "ADIOI_Count_contiguous_blocks" problem.
> > but frankly I feel like this is something that the LAM guys need to figure
> > out or get in touch with us about; they shouldn't be passing types to
> > ROMIO that they know it can't process.
> > Rob
> Hello,
>  I am just now compiling lam-mpi-7.0.4 locally, since in my system the
> last stable was 7.0.2 and 7.0.3 is still masked.
> I will compile against this new version, check the persistence of the
> problem, try your file and report back to LAM.
Sounds good.
> But before I think I should wait for the code with the updated
> mpinetcdf.c to be available, for not having them complain about it.
If you have a version that you have already hacked to use ifs, then you
could go with that.  I'm just doing basically the same thing.
> Alternatively, I could explain them in advance and give directly a
> patch... I have to learn how to make them properly.
> Any suggestions? It is not urgent, so I guess it would be possible to
> wait for pnetcdf's next release and report then the problem.
It's up to you.  With your modified "if" version of mpinetcdf.c and that
flatten.c, you might be a-ok already.  Let us know...
Rob
