0.9.3 installation problems on GNU/Linux with lam-mpi
Rob Ross
rross at mcs.anl.gov
Tue Feb 3 10:28:46 CST 2004
I see. At least a few of those, if not all, are going to be due to the
"ADIOI_Count_contiguous_blocks" problem.
Let me explain what is going on there. LAM takes the ROMIO implementation
for MPI-IO and includes it in their distribution. The version of ROMIO
that they have (which is the latest released one) does not support
subarray or darray types -- it instead includes code that builds these in
terms of other types.
LAM added support for these types, but didn't go to the trouble to update
ROMIO to handle them. So LAM will build types that its MPI-IO can't
process, and that's what you are seeing here.
I have recently added support for these types into ROMIO (our CVS version,
also in MPICH2). I've attached a replacement flatten.c (goes in
romio/adio/common) that you could try dropping into your LAM builds to see
if it helps. I'll try to get someone looking at this particular problem,
but frankly I feel like this is something that the LAM guys need to figure
out or get in touch with us about; they shouldn't be passing types to
ROMIO that they know it can't process.
Rob
On Tue, 3 Feb 2004, Raimondo Giammanco wrote:
> Hello,
> The errors that I have in testing are the following,
> make[1]: Entering directory
> `/mnt/disposable/TMP_giamma/parallel-netcdf-0.9.3/test'
> cd nc_test && make testing
> make[2]: Entering directory
> `/mnt/disposable/TMP_giamma/parallel-netcdf-0.9.3/test/nc_test'
> ./nc_test -c
> Error: Unsupported datatype passed to ADIOI_Count_contiguous_blocks
> rm -f scratch.nc
> ./nc_test
> *** Testing ncmpi_strerror ... ok
> *** Testing ncmpi_open ... 0: MPI_File_open error = MPI_Error_string:
> unknown error
> FAILURE at line 94 of test_read.c: ncmpi_open of nonexistent
> file should have returned system error
> ### 1 FAILURES TESTING ncmpi_open! ###
> *** Testing ncmpi_close ... ok
> *** Testing ncmpi_inq ... ok
> *** Testing ncmpi_inq_dimid ... ok
> *** Testing ncmpi_inq_dim ...
> FAILURE at line 486 of test_read.c: size expected: 2, got: 0
> FAILURE at line 496 of test_read.c: size expected: 2, got: 0
> ### 2 FAILURES TESTING ncmpi_inq_dim! ###
> *** Testing ncmpi_inq_dimlen ...
> FAILURE at line 526 of test_read.c: size expected: 2, got: 0
> ### 1 FAILURES TESTING ncmpi_inq_dimlen! ###
> *** Testing ncmpi_inq_dimname ... ok
> *** Testing ncmpi_inq_varid ... ok
> *** Testing ncmpi_inq_var ... ok
> *** Testing ncmpi_inq_natts ... ok
> *** Testing ncmpi_inq_ndims ... ok
> *** Testing ncmpi_inq_nvars ... ok
> *** Testing ncmpi_inq_unlimdim ... ok
> *** Testing ncmpi_inq_vardimid ... ok
> *** Testing ncmpi_inq_varname ... ok
> *** Testing ncmpi_inq_varnatts ... ok
> *** Testing ncmpi_inq_varndims ... ok
> *** Testing ncmpi_inq_vartype ... ok
> *** Testing ncmpi_get_var_text ...
> FAILURE at line 559 of test_get.c: value read not that expected
> 1 good comparisons.
> ### 178 FAILURES TESTING ncmpi_get_var_text! ###
> *** Testing ncmpi_get_var_short ...
> FAILURE at line 649 of test_get.c: value read not that expected
> FAILURE at line 639 of test_get.c: Range error: status = 0
> 5 good comparisons.
> ### 715 FAILURES TESTING ncmpi_get_var_short! ###
> *** Testing ncmpi_get_var_int ...
> FAILURE at line 739 of test_get.c: value read not that expected
> FAILURE at line 729 of test_get.c: Range error: status = 0
> 5 good comparisons.
> ### 1192 FAILURES TESTING ncmpi_get_var_int! ###
> *** Testing ncmpi_get_var_long ...
> FAILURE at line 829 of test_get.c: value read not that expected
> FAILURE at line 819 of test_get.c: Range error: status = 0
> 5 good comparisons.
> ### 1192 FAILURES TESTING ncmpi_get_var_long! ###
> *** Testing ncmpi_get_var_float ...
> FAILURE at line 919 of test_get.c: value read not that expected
> 5 good comparisons.
> ### 1189 FAILURES TESTING ncmpi_get_var_float! ###
> *** Testing ncmpi_get_var_double ...
> FAILURE at line 1009 of test_get.c: value read not that expected
> 5 good comparisons.
> ### 1202 FAILURES TESTING ncmpi_get_var_double! ###
> *** Testing ncmpi_get_var1_text ...
> FAILURE at line 61 of test_get.c: Index exceeds dimension bound
> FAILURE at line 64 of test_get.c: expected: -128, got: 0
> FAILURE at line 64 of test_get.c: expected: 127, got: 0
> FAILURE at line 64 of test_get.c: expected: 65, got: 0
> 1 good comparisons.
> ### 178 FAILURES TESTING ncmpi_get_var1_text! ###
> *** Testing ncmpi_get_var1_short ...
> FAILURE at line 141 of test_get.c: Index exceeds dimension bound
> FAILURE at line 152 of test_get.c: Range error: status = -40
> 5 good comparisons.
> ### 1202 FAILURES TESTING ncmpi_get_var1_short! ###
> *** Testing ncmpi_get_var1_int ...
> FAILURE at line 221 of test_get.c: Index exceeds dimension bound
> FAILURE at line 232 of test_get.c: Range error: status = -40
> 5 good comparisons.
> ### 1202 FAILURES TESTING ncmpi_get_var1_int! ###
> *** Testing ncmpi_get_var1_long ...
> FAILURE at line 301 of test_get.c: Index exceeds dimension bound
> FAILURE at line 312 of test_get.c: Range error: status = -40
> 5 good comparisons.
> ### 1202 FAILURES TESTING ncmpi_get_var1_long! ###
> *** Testing ncmpi_get_var1_float ...
> FAILURE at line 381 of test_get.c: Index exceeds dimension bound
> FAILURE at line 396 of test_get.c: OK or Range error: status =
> -40
> 5 good comparisons.
> ### 1192 FAILURES TESTING ncmpi_get_var1_float! ###
> *** Testing ncmpi_get_var1_double ...
> FAILURE at line 461 of test_get.c: Index exceeds dimension bound
> 5 good comparisons.
> ### 1202 FAILURES TESTING ncmpi_get_var1_double! ###
> *** Testing ncmpi_get_vara_text ...
> FAILURE at line 1085 of test_get.c: bad edge: status = -40
> FAILURE at line 1112 of test_get.c: Index exceeds dimension
> bound
> FAILURE at line 1163 of test_get.c: Index exceeds dimension
> bound
> FAILURE at line 1176 of test_get.c: value read not that expected
> bound
> expectedError: Unsupported datatype passed to
> make[2]: Leaving directory
> if [ yes = yes ] ; then cd nf_test && make testing ; fi
> `/mnt/disposable/TMP_giamma/parallel-netcdf-0.9.3/test/nf_test'
> m4 -B10000 test_get.m4 >test_get.F
> + /usr/bin/mpif77 -c -I. -I./../../src/libf -I./../../src/lib
> -I../../src/lib test_get.F
> m4 -B10000 test_put.m4 >test_put.F
> -I../../src/lib test_put.F
> -I../../src/lib nf_error.F
> -I../../src/lib nf_test.F
> -I../../src/lib test_read.F
> -I../../src/lib test_write.F
> -I../../src/lib util.F
> /usr/bin/mpicc -c -g -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64
> -I. -I./../../src/libf -I./../../src/lib -I../../src/lib fortlib.c
> /usr/bin/mpif77 -o nf_test -I. -I./../../src/libf -I./../../src/lib
> -I../../src/lib test_get.o test_put.o nf_error.o nf_test.o test_read.o
> test_write.o util.o fortlib.o ../../src/lib/libpnetcdf.a -lm
> ./nf_test -c
> Rank (0, MPI_COMM_WORLD): Call stack within LAM:
> Rank (0, MPI_COMM_WORLD): - MPI_Comm_rank()
> Rank (0, MPI_COMM_WORLD): - main()
> make[2]: *** [test.nc] Error 22
> make[1]: *** [testing] Error 2
> make[1]: Leaving directory
> make: *** [testing] Error 2
> However these errors have been generated with my version of
> mpinetcdf.c; I am including a patch file, but I am not
> sure It is correct...
> On Tue, 2004-02-03 at 16:25, Rob Ross wrote:
> > I'm basically doing the same if conversion here, so if you want to submit
> > your other errors in the mean time, we can go ahead and have a look at
> > those too.
> > Thanks,
> > Rob
> > > Hello,
> > > I tried to install 0.9.3 on a GNU/Linux PC with lam-mpi-7.0.2,
> > > and I am having the following problem:
> > > 1) autoconf
> > > 2) ./configure --prefix=SOME_PATH --with-mpi=/usr
> > > 3) make all
> > > It returns in src/lib
> > > mpinetcdf.c: In function `length_of_mpitype':
> > > mpinetcdf.c:382: switch quantity not an integer
> > > mpinetcdf.c:383: pointers are not permitted as case values
> > > mpinetcdf.c:383: case label does not reduce to an integer constant
> > > mpinetcdf.c:384: pointers are not permitted as case values
> > > mpinetcdf.c:384: case label does not reduce to an integer constant
> > > mpinetcdf.c:386: pointers are not permitted as case values
> > > mpinetcdf.c:386: case label does not reduce to an integer constant
> > > mpinetcdf.c:388: pointers are not permitted as case values
> > > mpinetcdf.c:388: case label does not reduce to an integer constant
> > > mpinetcdf.c:390: pointers are not permitted as case values
> > > mpinetcdf.c:390: case label does not reduce to an integer constant
> > > mpinetcdf.c:392: pointers are not permitted as case values
> > > mpinetcdf.c:392: case label does not reduce to an integer constant
> > > mpinetcdf.c:394: pointers are not permitted as case values
> > > mpinetcdf.c:394: case label does not reduce to an integer constant
> > > etc. etc. where there is the swith(datatype) command.
> > > I looked a little in /usr/include mpi.h of lam, and
> > > I tried to substitute the switches with a series of ifs.
> > > I was able to compile, but I received a series of errors
> > > in make testing.
> > > Before submitting the details, I was wondering if this
> > > is an implementation problem of lam, or there is some
> > > other reason behind this strange behavior.
> > > Is there anybody using lam-mpi and that can give me some pointers?
> > > Best Regards
> > > Raimondo Giammanco <rongten at member.fsf.org>
/* -*- Mode: C; c-basic-offset:4 ; -*- */
* $Id: flatten.c,v 1.13 2003/12/18 19:50:46 rross Exp $
* Copyright (C) 1997 University of Chicago.
* See COPYRIGHT notice in top-level directory.
#include "adio.h"
#include "adio_extern.h"
#ifdef MPISGI
#include "mpisgi2.h"
#endif
#define MPIIMPL_HAVE_MPI_COMBINER_DARRAY
#define MPIIMPL_HAVE_MPI_COMBINER_SUBARRAY
void ADIOI_Optimize_flattened(ADIOI_Flatlist_node *flat_type);
void ADIOI_Flatten_subarray(int ndims,
int *array_of_sizes,
int *array_of_subsizes,
int *array_of_starts,
int order,
MPI_Datatype oldtype,
ADIOI_Flatlist_node *flat,
ADIO_Offset start_offset,
int *inout_index_p);
void ADIOI_Flatten_darray(int size,
int rank,
int ndims,
int array_of_gsizes[],
int array_of_distribs[],
int array_of_dargs[],
int array_of_psizes[],
int order,
void ADIOI_Flatten_copy_type(ADIOI_Flatlist_node *flat,
int old_type_start,
int old_type_end,
int new_type_start,
ADIO_Offset offset_adjustment);
/* darray helper functions */
#ifdef MPIIMPL_HAVE_MPI_COMBINER_DARRAY
static int index_of_type(int type_nr,
int dim_size,
int dim_rank,
int dim_ranks,
int k);
static int get_cyclic_k(int dim_size,
int dim_ranks,
int dist,
int d_arg);
static void get_darray_position(int rank,
int ranks,
int ndims,
int r[]);
static int local_types_in_dim(int dim_size,
int dim_rank,
int dim_ranks,
int k);
#endif
/* flatten datatype and add it to Flatlist */
void ADIOI_Flatten_datatype(MPI_Datatype datatype)
#ifdef HAVE_MPIR_TYPE_FLATTEN
MPI_Aint flatten_idx;
#endif
int curr_index=0, is_contig;
ADIOI_Flatlist_node *flat, *prev=0;
/* check if necessary to flatten. */
/* is it entirely contiguous? */
ADIOI_Datatype_iscontig(datatype, &is_contig);
if (is_contig) return;
/* has it already been flattened? */
flat = ADIOI_Flatlist;
while (flat) {
if (flat->type == datatype) {
return;
else {
prev = flat;
flat = flat->next;
/* flatten and add to the list */
flat = prev;
flat->next = (ADIOI_Flatlist_node *)ADIOI_Malloc(sizeof(ADIOI_Flatlist_node));
flat = flat->next;
flat->type = datatype;
flat->next = NULL;
flat->blocklens = NULL;
flat->indices = NULL;
flat->count = ADIOI_Count_contiguous_blocks(datatype, &curr_index);
#if 0
printf("cur_idx = %d\n", curr_index);
#endif
/* FPRINTF(stderr, "%d\n", flat->count);*/
if (flat->count) {
flat->blocklens = (int *) ADIOI_Malloc(flat->count * sizeof(int));
flat->indices = (ADIO_Offset *) ADIOI_Malloc(flat->count * \
sizeof(ADIO_Offset));
curr_index = 0;
flatten_idx = (MPI_Aint) flat->count;
MPIR_Type_flatten(datatype, flat->indices, flat->blocklens, &flatten_idx);
#else
ADIOI_Flatten(datatype, flat, 0, &curr_index);
ADIOI_Optimize_flattened(flat);
#endif
/* debug */
#if 0
int i;
FPRINTF(stderr, "blens: ");
for (i=0; i<flat->count; i++)
FPRINTF(stderr, "%d ", flat->blocklens[i]);
FPRINTF(stderr, "\n\n");
FPRINTF(stderr, "indices: ");
FPRINTF(stderr, "%ld ", (long) flat->indices[i]);
#endif
/* ADIOI_Flatten()
* Assumption: input datatype is not a basic!!!!
void ADIOI_Flatten(MPI_Datatype datatype, ADIOI_Flatlist_node *flat,
ADIO_Offset st_offset, int *curr_index)
int i, j, k, m, n, num, basic_num, prev_index;
int top_count, combiner, old_combiner, old_is_contig;
int old_size, nints, nadds, ntypes, old_nints, old_nadds, old_ntypes;
MPI_Aint old_extent;
int *ints;
MPI_Aint *adds;
MPI_Datatype *types;
MPI_Type_get_envelope(datatype, &nints, &nadds, &ntypes, &combiner);
ints = (int *) ADIOI_Malloc((nints+1)*sizeof(int));
adds = (MPI_Aint *) ADIOI_Malloc((nadds+1)*sizeof(MPI_Aint));
types = (MPI_Datatype *) ADIOI_Malloc((ntypes+1)*sizeof(MPI_Datatype));
MPI_Type_get_contents(datatype, nints, nadds, ntypes, ints, adds, types);
switch (combiner) {
#ifdef MPIIMPL_HAVE_MPI_COMBINER_DUP
case MPI_COMBINER_DUP:
MPI_Type_get_envelope(types[0], &old_nints, &old_nadds,
&old_ntypes, &old_combiner);
ADIOI_Datatype_iscontig(types[0], &old_is_contig);
if ((old_combiner != MPI_COMBINER_NAMED) && (!old_is_contig))
ADIOI_Flatten(types[0], flat, st_offset, curr_index);
break;
#endif
#ifdef MPIIMPL_HAVE_MPI_COMBINER_SUBARRAY
case MPI_COMBINER_SUBARRAY:
int dims = ints[0];
ADIOI_Flatten_subarray(dims,
&ints[1], /* sizes */
&ints[dims+1], /* subsizes */
&ints[2*dims+1], /* starts */
ints[3*dims+1], /* order */
types[0], /* type */
flat,
st_offset,
curr_index);
break;
#endif
case MPI_COMBINER_DARRAY:
int dims = ints[2];
ADIOI_Flatten_darray(ints[0], /* size */
ints[1], /* rank */
dims,
&ints[3], /* gsizes */
&ints[dims+3], /* distribs */
&ints[2*dims+3], /* dargs */
&ints[3*dims+3], /* psizes */
ints[4*dims+3], /* order */
types[0],
flat,
st_offset,
curr_index);
break;
#endif
case MPI_COMBINER_CONTIGUOUS:
top_count = ints[0];
prev_index = *curr_index;
if (prev_index == *curr_index) {
/* simplest case, made up of basic or contiguous types */
j = *curr_index;
flat->indices[j] = st_offset;
MPI_Type_size(types[0], &old_size);
flat->blocklens[j] = top_count * old_size;
(*curr_index)++;
else {
/* made up of noncontiguous derived types */
j = *curr_index;
num = *curr_index - prev_index;
/* The noncontiguous types have to be replicated count times */
MPI_Type_extent(types[0], &old_extent);
for (m=1; m<top_count; m++) {
for (i=0; i<num; i++) {
flat->indices[j] = flat->indices[j-num] + old_extent;
flat->blocklens[j] = flat->blocklens[j-num];
j++;
*curr_index = j;
break;
case MPI_COMBINER_VECTOR:
/* simplest case, vector of basic or contiguous types */
j = *curr_index;
flat->blocklens[j] = ints[1] * old_size;
for (i=j+1; i<j+top_count; i++) {
flat->indices[i] = flat->indices[i-1] + ints[2]*old_size;
flat->blocklens[i] = flat->blocklens[j];
*curr_index = i;
else {
/* vector of noncontiguous derived types */
j = *curr_index;
/* The noncontiguous types have to be replicated blocklen times
and then strided. Replicate the first one. */
for (m=1; m<ints[1]; m++) {
j++;
*curr_index = j;
/* Now repeat with strides. */
for (i=1; i<top_count; i++) {
for (m=0; m<num; m++) {
flat->indices[j] = flat->indices[j-num] + ints[2]
*old_extent;
j++;
*curr_index = j;
break;
case MPI_COMBINER_HVECTOR:
j = *curr_index;
flat->indices[i] = flat->indices[i-1] + adds[0];
*curr_index = i;
else {
j = *curr_index;
j++;
*curr_index = j;
flat->indices[j] = flat->indices[j-num] + adds[0];
j++;
*curr_index = j;
break;
case MPI_COMBINER_INDEXED:
st_offset+ints[top_count+1]*old_extent, curr_index);
/* simplest case, indexed type made up of basic or contiguous types */
j = *curr_index;
for (i=j; i<j+top_count; i++) {
flat->indices[i] = st_offset + ints[top_count+1+i-j]*old_extent;
flat->blocklens[i] = (int) (ints[1+i-j]*old_extent);
*curr_index = i;
else {
/* indexed type made up of noncontiguous derived types */
j = *curr_index;
basic_num = num;
/* The noncontiguous types have to be replicated blocklens[i] times
j++;
*curr_index = j;
for (m=0; m<basic_num; m++) {
(ints[top_count+1+i]-ints[top_count+i])*old_extent;
j++;
*curr_index = j;
for (m=1; m<ints[1+i]; m++) {
for (k=0; k<basic_num; k++) {
flat->indices[j] = flat->indices[j-basic_num] + old_extent;
flat->blocklens[j] = flat->blocklens[j-basic_num];
j++;
*curr_index = j;
break;
case MPI_COMBINER_HINDEXED:
ADIOI_Flatten(types[0], flat, st_offset+adds[0], curr_index);
j = *curr_index;
flat->indices[i] = st_offset + adds[i-j];
flat->blocklens[i] = ints[1+i-j]*old_size;
*curr_index = i;
else {
j = *curr_index;
basic_num = num;
j++;
*curr_index = j;
flat->indices[j] = flat->indices[j-num] + adds[i] - adds[i-1];
j++;
*curr_index = j;
j++;
*curr_index = j;
break;
case MPI_COMBINER_STRUCT:
for (n=0; n<top_count; n++) {
MPI_Type_get_envelope(types[n], &old_nints, &old_nadds,
ADIOI_Datatype_iscontig(types[n], &old_is_contig);
ADIOI_Flatten(types[n], flat, st_offset+adds[n], curr_index);
/* simplest case, current type is basic or contiguous types */
j = *curr_index;
flat->indices[j] = st_offset + adds[n];
MPI_Type_size(types[n], &old_size);
flat->blocklens[j] = ints[1+n] * old_size;
(*curr_index)++;
else {
/* current type made up of noncontiguous derived types */
j = *curr_index;
/* The current type has to be replicated blocklens[n] times */
MPI_Type_extent(types[n], &old_extent);
for (m=1; m<ints[1+n]; m++) {
j++;
*curr_index = j;
break;
default:
FPRINTF(stderr, "Error: Unsupported datatype passed to ADIOI_Flatten\n");
MPI_Abort(MPI_COMM_WORLD, 1);
#ifndef MPISGI
/* There is a bug in SGI's impl. of MPI_Type_get_contents. It doesn't
return new datatypes. Therefore no need to free. */
for (i=0; i<ntypes; i++) {
MPI_Type_get_envelope(types[i], &old_nints, &old_nadds, &old_ntypes,
&old_combiner);
if (old_combiner != MPI_COMBINER_NAMED) MPI_Type_free(types+i);
#endif
ADIOI_Free(ints);
ADIOI_Free(adds);
ADIOI_Free(types);
/* ADIOI_Count_contiguous_blocks
* Returns number of contiguous blocks in type, and also saves this value in
* curr_index.
* ASSUMES THAT TYPE IS NOT A BASIC!!!
int ADIOI_Count_contiguous_blocks(MPI_Datatype datatype, int *curr_index)
#ifdef HAVE_MPIR_TYPE_GET_CONTIG_BLOCKS
/* MPICH2 can get us this value without all the envelope/contents calls */
int blks;
MPIR_Type_get_contig_blocks(datatype, &blks);
*curr_index = blks;
return blks;
#else
int count=0, i, n, num, basic_num, prev_index;
int nints, nadds, ntypes, old_nints, old_nadds, old_ntypes;
int *ints;
MPI_Aint *adds;
switch (combiner) {
count = ADIOI_Count_contiguous_blocks(types[0], curr_index);
else count = 1;
break;
#endif
/* first get an upper bound (since we're not optimizing) on the
* number of blocks in the child type.
else count = 1;
/* now multiply that by the number of types in the subarray.
* note: we could be smarter about this, because chances are
* our data is contiguous in the first dimension if the child
* type is contiguous.
* ints[0] - ndims
* ints[ndims+1..2*ndims] - subsizes
n = 1; /* going to tally up # of types in here */
for (i=0; i < ints[0]; i++) {
n *= ints[ints[0]+1+i];
count *= n;
break;
#endif
int dims, k, *ranks;
else count = 1;
n = 1;
dims = ints[2];
ranks = ADIOI_Malloc(sizeof(int) * dims);
get_darray_position(ints[1], /* rank */
ints[0], /* size */
dims,
ranks);
for (i=0; i < dims; i++) {
k = get_cyclic_k(ints[3+i], /* gsize */
ints[3*dims+3+i], /* psize */
ints[dims+3+i], /* distrib */
ints[2*dims+3+i]); /* darg */
n *= local_types_in_dim(ints[3+i], /* gsize */
ranks[i], /* dim rank */
k);
ADIOI_Free(ranks);
count *= n;
break;
#endif
else count = 1;
(*curr_index)++;
else {
count *= top_count;
*curr_index += (top_count - 1)*num;
break;
else count = 1;
count = top_count;
*curr_index += count;
else {
and then strided. */
count *= ints[1] * top_count;
/* First one */
*curr_index += (ints[1] - 1)*num;
break;
else count = 1;
count = top_count;
else {
basic_num = *curr_index - prev_index;
*curr_index += (ints[1]-1) * basic_num;
count *= ints[1];
count += ints[1+i] * basic_num;
*curr_index += ints[1+i] * basic_num;
break;
count = 0;
count += ADIOI_Count_contiguous_blocks(types[n], curr_index);
count++;
(*curr_index)++;
else {
count += (ints[1+n]-1)*num;
(*curr_index) += (ints[1+n]-1)*num;
break;
default:
FPRINTF(stderr, "Error: Unsupported datatype passed to ADIOI_Count_contiguous_blocks\n");
#ifndef MPISGI
&old_combiner);
#endif
ADIOI_Free(ints);
ADIOI_Free(adds);
ADIOI_Free(types);
return count;
#endif /* HAVE_MPIR_TYPE_GET_CONTIG_BLOCKS */
/* ADIOI_Optimize_flattened()
* Scans the blocks of a flattened type and merges adjacent blocks
* together, resulting in a shorter blocklist (and thus fewer
* contiguous operations).
* Q: IS IT SAFE TO REMOVE THE 0-LENGTH BLOCKS TOO?
int i, j, opt_blocks;
int *opt_blocklens;
ADIO_Offset *opt_indices;
opt_blocks = 1;
/* save number of noncontiguous blocks in opt_blocks */
for (i=0; i < (flat_type->count - 1); i++) {
if ((flat_type->indices[i] + flat_type->blocklens[i] !=
flat_type->indices[i + 1]))
opt_blocks++;
/* if we can't reduce the number of blocks, quit now */
if (opt_blocks == flat_type->count) return;
opt_blocklens = (int *) ADIOI_Malloc(opt_blocks * sizeof(int));
opt_indices = (ADIO_Offset *)ADIOI_Malloc(opt_blocks*sizeof(ADIO_Offset));
/* fill in new blocklists */
opt_blocklens[0] = flat_type->blocklens[0];
opt_indices[0] = flat_type->indices[0];
j = 0;
if ((flat_type->indices[i] + flat_type->blocklens[i] ==
opt_blocklens[j] += flat_type->blocklens[i + 1];
else {
j++;
opt_indices[j] = flat_type->indices[i + 1];
opt_blocklens[j] = flat_type->blocklens[i + 1];
flat_type->count = opt_blocks;
ADIOI_Free(flat_type->blocklens);
ADIOI_Free(flat_type->indices);
flat_type->blocklens = opt_blocklens;
flat_type->indices = opt_indices;
return;
void ADIOI_Delete_flattened(MPI_Datatype datatype)
ADIOI_Flatlist_node *flat, *prev;
prev = flat = ADIOI_Flatlist;
while (flat && (flat->type != datatype)) {
prev = flat;
flat = flat->next;
if (flat) {
prev->next = flat->next;
if (flat->blocklens) ADIOI_Free(flat->blocklens);
if (flat->indices) ADIOI_Free(flat->indices);
ADIOI_Free(flat);
/* ADIOI_Flatten_subarray()
* ndims - number of dimensions in the array
* array_of_sizes - dimensions of the array (one value per dim)
* array_of_subsizes - dimensions of the subarray (one value per dim)
* array_of_starts - starting offsets of the subarray (one value per dim)
* order - MPI_ORDER_FORTRAN or MPI_ORDER_C
* oldtype - type on which this subarray as built
* flat - ...
* start_offset - offset of this type to begin with
* inout_index_p - as an input holds the count of indices (and blocklens)
* that have already been used (also the index to the next
* location to fill in!)
int order,
int *inout_index_p)
int i, j, oldtype_extent, total_types, *dim_sz, flatten_start_offset,
flatten_end_offset;
int old_nints, old_nadds, old_ntypes, old_combiner;
ADIO_Offset subarray_start_offset, type_offset, *dim_skipbytes;
MPI_Type_extent(oldtype, &oldtype_extent);
/* TODO: optimization for 1-dimensional types -- treat like a contig */
/* general case - make lots of copies of the offsets, adjusting
* the indices as necessary.
/* allocate space for temporary values */
dim_sz = (int *) ADIOI_Malloc(sizeof(int)*(ndims));
dim_skipbytes = (ADIO_Offset *) ADIOI_Malloc(sizeof(ADIO_Offset)*(ndims));
/* get a count of the total number of types (of type oldtype) in
* the subarray.
total_types = 1;
for (i=0; i < ndims; i++) total_types *= array_of_subsizes[i];
/* fill in the temporary values dim_sz and dim_skipbytes.
* these are used to calculate the starting offset for each instance
* of oldtype in the subarray. we precalculate these values so that
* we can avoid calculating them for every instance. this is all done
* so that we can avoid a recursive algorithm here, which could be very
* expensive if done for every dimension.
* finally, we're going to store these in C order regardless of how the
* arrays were described in the first place.
* dim_sz is a value describing the number of types that go into a single
* block in this dimension. dim_skipbytes is the distance necessary to
* move from one block to the next in this dimension.
* this is a little misleading, because actually dim_sz[ndims-1] is
* always 1 and the dim_skipbytes[ndims-1] is always the extent...
* the dim_sz values are in terms of types, the dim_skipbytes are in
* terms of bytes, and do *not* include the starting offset calculated
* above.
/* priming the loop more or less */
dim_sz[ndims-1] = 1;
dim_skipbytes[ndims-1] = oldtype_extent;
for (i=ndims-2; i >= 0; i--) {
dim_sz[i] = dim_sz[i+1];
dim_skipbytes[i] = dim_skipbytes[i+1];
if (order == MPI_ORDER_FORTRAN) {
dim_sz[i] *= array_of_subsizes[ndims-2-i];
dim_skipbytes[i] *= array_of_sizes[ndims-2-i];
else {
dim_sz[i] *= array_of_subsizes[i+1];
dim_skipbytes[i] *= array_of_sizes[i+1];
/* determine our starting offset for use later; this is a lot
* easier to do now that we have the dim_skipbytes[] array from
* above.
subarray_start_offset = 0;
for (i=0; i < ndims; i++) {
subarray_start_offset += array_of_starts[ndims-1-i]*dim_skipbytes[i];
else {
subarray_start_offset += array_of_starts[i]*dim_skipbytes[i];
subarray_start_offset += start_offset; /* add in input parameter */
/* flatten one of the type to get the offsets that we need;
* really we need the starting offset to be right in order to
* do this in-place.
* we save the offset to the first piece of the flattened type
* so we can know what to make copies of in the next step.
flatten_start_offset = *inout_index_p;
MPI_Type_get_envelope(oldtype, &old_nints, &old_nadds,
ADIOI_Flatten(oldtype, flat, subarray_start_offset, inout_index_p);
else {
int oldtype_size;
flat->indices[flatten_start_offset] = subarray_start_offset;
MPI_Type_size(oldtype, &oldtype_size);
flat->blocklens[flatten_start_offset] = oldtype_size;
(*inout_index_p)++;
/* note this is really one larger than the end offset, but
* that's what we want below.
flatten_end_offset = *inout_index_p;
/* now we run through all the blocks, calculating their effective
* offset and then making copies of all the regions for the type
* for this instance.
for (i=1; i < total_types; i++) {
int block_nr = i;
type_offset = 0;
for (j=0; j < ndims; j++) {
/* move through dimensions from least frequently changing
* to most frequently changing, calculating offset to get
* to a particular block, then reducing our block number
* so that we can correctly calculate based on the next
* dimension's size.
int dim_index = block_nr / dim_sz[j];
if (dim_index) type_offset += dim_index * dim_skipbytes[j];
block_nr %= dim_sz[j];
/* do the copy */
ADIOI_Flatten_copy_type(flat,
flatten_end_offset,
flatten_start_offset + i * (flatten_end_offset - flatten_start_offset),
type_offset);
/* free our temp space */
ADIOI_Free(dim_sz);
ADIOI_Free(dim_skipbytes);
*inout_index_p = flatten_start_offset + total_types * (flatten_end_offset - flatten_start_offset);
#endif
/* ADIOI_Flatten_copy_type()
* flat - pointer to flatlist node holding offset and lengths
* start - starting index of src type in arrays
* end - one larger than ending index of src type (makes loop clean)
* offset_adjustment - amount to add to "indices" (offset) component
* of each off/len pair copied
int old_type_start,
int old_type_end,
int new_type_start,
int i, out_index = new_type_start;
for (i=old_type_start; i < old_type_end; i++) {
flat->indices[out_index] = flat->indices[i] + offset_adjustment;
flat->blocklens[out_index] = flat->blocklens[i];
out_index++;
/* ADIOI_Flatten_darray()
* size - number of processes across which darray is defined
* rank - our rank in the group of processes
* ndims - number of dimensions of darray type
* gsizes - dimensions of the array in types (order varies)
* distribs - type of dist. for each dimension (order varies)
* dargs - argument to dist. for each dimension (order varies)
* psizes - number of processes across which each dimension
* is split (always C order)
* order - order of parameters (c or fortran)
* oldtype - type on which this darray is built
* flat - ...
* inout_index_p - count of indices already used on input, updated
* for output
* The general approach is to convert everything into cyclic-k and process
* it from there.
int rank,
int ndims,
int order,
int *inout_index_p)
int i, j, total_types, flatten_start_offset,
flatten_end_offset, oldtype_nints, oldtype_nadds, oldtype_ntypes,
oldtype_combiner, *dim_ranks, *dim_ks, *dim_localtypes;
ADIO_Offset darray_start_offset, first_darray_offset;
MPI_Aint oldtype_extent, *dim_skipbytes;
dim_localtypes = ADIOI_Malloc(sizeof(int) * ndims);
dim_skipbytes = ADIOI_Malloc(sizeof(MPI_Aint) * ndims);
dim_ranks = (int *) ADIOI_Malloc(sizeof(int) * ndims);
dim_ks = (int *) ADIOI_Malloc(sizeof(int) * ndims);
/* fill in dim_ranks, C order (just like psizes) */
get_darray_position(rank, size, ndims, array_of_psizes, dim_ranks);
/* calculate all k values; store in same order as arrays */
dim_ks[i] = get_cyclic_k(array_of_gsizes[i],
array_of_psizes[i],
array_of_distribs[i],
array_of_dargs[i]);
/* calculate total number of oldtypes in this type */
total_types = 1;
total_types *= local_types_in_dim(array_of_gsizes[i],
dim_ranks[i],
array_of_psizes[i],
dim_ks[i]);
/* fill in temporary values; these are just cached so we aren't
* calculating them for every type instance.
* dim_localtypes holds the # of types this process has in the given
* dimension.
* dim_skipbytes (in this function) is going to hold the distance
* to skip to move from one type to the next in that dimension, in
* bytes, in terms of the darray as a whole. sort of like the stride
* for a vector.
* we keep this stuff in row-major (C) order -- least-frequently changing
* first.
int idx = (order == MPI_ORDER_C) ? i : ndims-1-i;
dim_localtypes[i] = local_types_in_dim(array_of_gsizes[idx],
dim_ranks[idx],
array_of_psizes[idx],
dim_ks[idx]);
int idx = (order == MPI_ORDER_C) ? i+1 : ndims-2-i;
dim_skipbytes[i] = array_of_gsizes[idx] * dim_skipbytes[i+1];
#if 0
MPIU_dbg_printf("dim_skipbytes[%d] = %d, dim_localtypes[%d] = %d\n",
i, (int) dim_skipbytes[i], i, dim_localtypes[i]);
#endif
/* determine starting offset */
darray_start_offset = start_offset;
first_darray_offset = 0;
ADIO_Offset this_dim_off;
this_dim_off = index_of_type(0,
dim_ranks[i],
array_of_psizes[i],
dim_ks[idx]);
this_dim_off *= (ADIO_Offset) dim_skipbytes[i];
darray_start_offset += this_dim_off;
first_darray_offset += this_dim_off;
* we need an accurate starting offset to do this in-place.
* we save the starting offset so we can adjust when copying
* later on.
&oldtype_nints,
&oldtype_nadds,
&oldtype_ntypes,
&oldtype_combiner);
if (oldtype_combiner != MPI_COMBINER_NAMED) {
ADIOI_Flatten(oldtype, flat, darray_start_offset, inout_index_p);
else {
int oldtype_size;
flat->indices[flatten_start_offset] = darray_start_offset;
(*inout_index_p)++;
/* now run through all the types, calculating the effective
* offset and then making a copy of the flattened regions for the
* type (and adjusting the offsets of them appropriately)
for (i=0; i < total_types; i++) {
int block_nr = i;
ADIO_Offset type_offset = 0;
for (j=ndims-1; j >= 0; j--) {
ADIO_Offset dim_off;
int idx = (order == MPI_ORDER_C) ? j : ndims-1-j;
int dim_index = block_nr % dim_localtypes[j];
dim_off = index_of_type(dim_index,
dim_ranks[j],
array_of_psizes[j],
dim_ks[idx]);
if (dim_off) type_offset += (ADIO_Offset) dim_off *
(ADIO_Offset) dim_skipbytes[j];
#if 0
char s1[] = " ", s2[] = " ", s3[] = " ";
MPIU_dbg_printf("%sindex of type %d (pass %d,%d) is %d; new offset = %d\n",
(j == 0) ? s1 : ((j == 1) ? s2 : s3),
dim_index, i, j, (int) dim_off, (int) type_offset);
#endif
block_nr /= dim_localtypes[j];
/* perform copy; noting in this case that the type offsets that
* we are calculating here are relative to the beginning of the
* darray as a whole, not relative to the first of our elements.
* because of that we have to subtract off the first_darray_offset
* in order to get the right offset adjustment.
flatten_end_offset,
type_offset - first_darray_offset);
/* free temp space */
ADIOI_Free(dim_localtypes);
ADIOI_Free(dim_ranks);
ADIOI_Free(dim_ks);
/* darray processing helper functions */
int dim_size,
int dim_rank,
int dim_ranks,
int k)
int cycle, leftover, index;
/* handle MPI_DISTRIBUTE_NONE case */
if (k == 0) return type_nr;
cycle = type_nr / k;
leftover = type_nr % k;
index = (dim_rank * k) + (dim_ranks * k * cycle) + leftover;
return index;
int dim_ranks,
int dist,
int d_arg)
int k;
/* calculate correct "k" if DFLT_DARG passed in */
if (dist == MPI_DISTRIBUTE_NONE) return 0; /* indicates NONE */
else if (d_arg == MPI_DISTRIBUTE_DFLT_DARG) {
if (dist == MPI_DISTRIBUTE_BLOCK) {
k = (dim_size + dim_ranks - 1) / dim_ranks;
else {
k = 1;
else {
k = d_arg;
return k;
int dim_rank,
int dim_ranks,
int k)
int count, n_blocks, n_types, leftover;
if (k == 0) {
/* indicates MPI_DISTRIBUTE_NONE */
return dim_size;
/* blocks are regions of (up to k) types; this count
* includes partials
n_blocks = (dim_size + k - 1) / k;
/* count gets us a total # of blocks that the particular
* rank gets, including possibly a partial block
count = n_blocks / dim_ranks;
leftover = n_blocks - (count * dim_ranks);
if (dim_rank < leftover) count++;
n_types = count * k;
/* subtract off the types that are missing from the final
* partial block, if there is a partial and this rank is
* the one that has it.
if ((dim_rank == leftover - 1) && (dim_size % k != 0)) {
n_types -= k - (dim_size - ((dim_size / k) * k));
return n_types;
/* get_darray_position(rank, ranks, ndims, array_of_psizes, r[])
* Calculates the position of this process in the darray
* given the rank of the process passed to the darray create
* and the total number of processes also passed to the darray
* create.
* Assumes that the array (r[]) has already been allocated.
int ranks,
int ndims,
int r[])
int i;
int t_rank = rank;
int t_size = ranks;
for (i = 0; i < ndims; i++) {
t_size = t_size / array_of_psizes[i];
r[i] = t_rank / t_size;
t_rank = t_rank % t_size;
#endif
More information about the parallel-netcdf
