Irix 64 nc_test error
Rhoades.Jon
Rhoades.Jon at ensco.com
Tue Apr 20 08:01:12 CDT 2004
I made the change and the make works building the executables but when I do a make test in the nc_test dir I get the following.
andrew 5# make test
./nc_test
*** Testing ncmpi_strerror ... ok
*** Testing ncmpi_open ... 0: MPI_File_open error = No such file or directory
FAILURE at line 94 of test_read.c: ncmpi_open of nonexistent file should have returned system error
### 1 FAILURES TESTING ncmpi_open! ###
*** Testing ncmpi_close ... ok
*** Testing ncmpi_inq ... ok
*** Testing ncmpi_inq_dimid ... ok
*** Testing ncmpi_inq_dim ... ok
*** Testing ncmpi_inq_dimlen ... ok
*** Testing ncmpi_inq_dimname ... ok
*** Testing ncmpi_inq_varid ... ok
*** Testing ncmpi_inq_var ... ok
*** Testing ncmpi_inq_natts ... ok
*** Testing ncmpi_inq_ndims ... ok
*** Testing ncmpi_inq_nvars ... ok
*** Testing ncmpi_inq_unlimdim ... ok
*** Testing ncmpi_inq_vardimid ... ok
*** Testing ncmpi_inq_varname ... ok
*** Testing ncmpi_inq_varnatts ... ok
*** Testing ncmpi_inq_varndims ... ok
*** Testing ncmpi_inq_vartype ... ok
*** Testing ncmpi_get_var_text ... 179 good comparisons. ok
*** Testing ncmpi_get_var_short ... 682 good comparisons. ok
*** Testing ncmpi_get_var_int ... 1189 good comparisons. ok
*** Testing ncmpi_get_var_long ...
FAILURE at line 829 of test_get.c: value read not that expected
903 good comparisons.
It continues with the value read not that expected errors.
-Jon Rhoades
-----Original Message-----
From: Jianwei Li [mailto:jianwei at cheetah.cpdc.ece.northwestern.edu]
Sent: Monday, April 19, 2004 7:06 PM
To: parallel-netcdf at mcs.anl.gov; Rhoades.Jon
Subject: Re: Irix 64 nc_test error
Hi Jon,
Thank you for the interest in using PnetCDF and for pointing out this problem!
The problem occurs because we put different arguement datatype "size_t" for the
strided access interface than the original netCDF's "ptrdiff_t" that is also
used in the nc_test. Could you try to replace the "ptrdiff_t" to "size_t" in
the variable declaration to solve your problem temperarily for now? We'll look
into the code to further address this problem.
Thanks!
Jianwei
>I am trying to get Parallel Netcdf 0.9.3 installed and when I try to compile
the test scripts I get the following errors.
>cc-1164 cc: WARNING File = test_get.c, Line = 2071
> Argument of type "ptrdiff_t *" is incompatible with parameter of type
> "const size_t *".
> err = ncmpi_get_vars_text_all(BAD_ID, i, start, edge, stride, value);
>I also have compiled MPI V2 and the test scripts for it ran fine. I am running
on a an SGI O2000 Irix 6.5. Any help would be appreciated.
>Thanks,
>Jon Rhoades, CCNA MCP
>Deputy Division Manager
>Information Systems & Technology
>ENSCO, Inc.
More information about the parallel-netcdf
