newbie errors
jabencke at ncsu.edu jabencke at ncsu.edu
Wed Apr 7 09:47:03 CDT 2004
Rob,
First thanks for your attention.
I've done what you asked and I'm still getting errors but they are
different.  This code I've sent you is not the main program but just a
subroutine.  Now I'm seeing errors like:
Killed by signal 2.^M
/opt/mpich/ethernet/icc/bin/mpirun: line 1:  8391 Broken pipe
/hom\e/jabencke/pssdw/vhone -p4pg /home/jabencke/pssdw/PI8171 -p4wd
/home/jabencke/\pssdw
AND
p0_8391:  p4_error: interrupt SIGSEGV: 11
Joseph Benckert
> The reason I think that you might need to is that your error
> "Intercommunicator is not allowed" looks like the result of getting the
> wrong value for MPI_COMM_WORLD.
> In general you should include the MPI headers in MPI programs.  Can you
> try it?
> Thanks,
> Rob
> On Tue, 6 Apr 2004 jabencke at ncsu.edu wrote:
>> Rob,
>> Thanks for the quick response.  I don't believe I need to include it.  I
>> don't think the compiler would recognize the MPI_COMM_WORLD, otherwise.
>> Anyway, we are using a Linux cluster (Rocks), and mpich.
>> Joseph Benckert
>> Department of Physics
>> North Carolina State University
>> jabencke at unity.ncsu.edu
>> > Hi,
>> > What machine and MPI are you using here?  You should be including an
>> MPI
>> > header too; that might be the cause (or you might have just neglected
>> to
>> > include that).
>> > Thanks,
>> > Rob
>> >> I'm not sure what's causing the errors I'm having, listed below.  I'm
>> >> trying to baby step here and just create the file to start things
>> off.
>> >> Below the errors is the code that causes the problem.  It's repeated
>> 8
>> >> times because it's an 8 processor test job.  Any help would be
>> >> fantastic.
>> >>  Can not open/create file
>> >> -1073749200: MPI_File_open error = Intercommunicator is not allowed
>> >> -1073746896: MPI_File_open error = Intercommunicator is not allowed
>> >> -1073751120: MPI_File_open error = Intercommunicator is not allowed
>> >> -1073747536: MPI_File_open error = Intercommunicator is not allowed
>> >> -1073749456: MPI_File_open error = Intercommunicator is not allowed
>> >> -1073746512: MPI_File_open error = Intercommunicator is not allowed
>> >> -1073750224: MPI_File_open error = Intercommunicator is not allowed
>> >> -1073747248: MPI_File_open error = Intercommunicator is not allowed
>> >> Code here:
>> >>       subroutine prin(prefix)
>> >> ! Outputs ascii array if ndim = 1, else if ndim > 1 then
>> >> ! write out hdf5 data file containing all variables (plus time).
>> >>       include 'pnetcdf.inc'
>> >>       include 'global.h'
>> >>       include 'sweep.h'
>> >>       include 'zone.h'
>> >>       ! integer(HID_T) :: hdf_file !file id for hdf file
>> >>       integer :: hdf_error !error var for hdf5 file
>> >>       character(LEN=1) :: char
>> >>       character(LEN=1) :: coord
>> >>       character(LEN=4) :: tmp1, tmp2
>> >>       character(LEN=5) :: prefix
>> >>       character(LEN=15) :: filename
>> >> !     Added (Fortran 90 style) for hdf5 stuff
>> >>       ! INTEGER(HID_T) :: dsp_id  ! Dataspace ID
>> >>       ! INTEGER(HID_T) :: dset_id !Dataset ID
>> >>       INTEGER, DIMENSION(3) :: dims
>> >>       INTEGER, DIMENSION(3) :: dimids
>> >>       INTEGER :: status, ncid
>> >>       INTEGER :: xDimID, yDimID, zDimID
>> >>       INTEGER :: yMaxDimID, tsDimID
>> >>       INTEGER :: density_varID, pressure_varID
>> >>       INTEGER :: XVelocity_varID, YVelocity_varID, ZVelocity_varID
>> >>       INTEGER :: XScale_varID, YScale_varID, ZScale_varID, time_varID
>> >> ! Create filename from integer nfile (in global.h) and prefix such
>> that
>> >> filename
>> >> ! looks like prefx.1000 where 1000 is the value of nfile
>> >>       write(tmp1,910) nfile
>> >>       write(tmp2,910) mype
>> >>  910  format(i4)
>> >>       do i = 1, 4
>> >>          if ((tmp1(i:i)) .eq. ' ') tmp1(i:i) = '0'
>> >>          if ((tmp2(i:i)) .eq. ' ') tmp2(i:i) = '0'
>> >>       enddo
>> >>       filename = prefix(1:5) // '_' // tmp1(1:4) // '.' // tmp2(1:4)
>> >>       nfile = nfile + 1
>> >>       if (ndim .eq. 1) then
>> >> ! Keep 1D output simple, just write out in ascii...
>> >>         open(unit=3,file=filename,form='formatted')
>> >>         do i = 1, imax
>> >>           write(3, 1003) zxa(i), zro(i,1,1),zpr(i,1,1), zux(i,1,1)
>> >>         enddo
>> >>         close(3)
>> >>       else
>> >> !     Initialize Dimensions
>> >>       dims(1) = imax
>> >>       dims(2) = js
>> >>       if(ndim.eq.3) dims(3) = kmax
>> >>       status = nfmpi_create(MPI_COMM_WORLD, filename,
>> >>      &                      MPI_INFO_NULL, nf90_Clobber, ncid)
>> >>       if (status /= nf90_NoErr ) print *, nfmpi_strerror(status)
>> >>       ! always a necessary statment to flush output
>> >>       status = nfmpi_close(ncid)
>> >>       endif
>> >>       write(8,6000) filename, time, ncycle
>> >>  6000 format('Wrote ',a10,' to disk at time =',1pe12.5,' (ncycle =',
>> >>      &        i6,')')
>> >>  1003 format(' ',4e13.5)
>> >>       return
>> >>       end
