newbie errors
Rajeev Thakur thakur at mcs.anl.gov
Tue Apr 6 13:53:30 CDT 2004
Could you just check that mpif.h is being included somewhere (like in some
other header file). Otherwise, there is no reason why pNetCDF would think of
MPI_COMM_WORLD as an intercommunicator and quit.
Rajeev
> -----Original Message-----
> From: owner-parallel-netcdf at mcs.anl.gov
> [mailto:owner-parallel-netcdf at mcs.anl.gov] On Behalf Of
> jabencke at ncsu.edu
> Sent: Tuesday, April 06, 2004 11:41 AM
> To: Rob Ross
> Cc: parallel-netcdf at mcs.anl.gov
> Subject: Re: newbie errors
> Rob,
> Thanks for the quick response.  I don't believe I need to
> include it.  I don't think the compiler would recognize the
> MPI_COMM_WORLD, otherwise. Anyway, we are using a Linux
> cluster (Rocks), and mpich.
> Joseph Benckert
> Department of Physics
> North Carolina State University
> jabencke at unity.ncsu.edu
> > Hi,
> > What machine and MPI are you using here?  You should be
> including an
> > MPI header too; that might be the cause (or you might have just
> > neglected to include that).
> > Thanks,
> > Rob
> > On Tue, 6 Apr 2004 jabencke at ncsu.edu wrote:
> >> I'm not sure what's causing the errors I'm having, listed
> below.  I'm
> >> trying to baby step here and just create the file to start things
> >> off. Below the errors is the code that causes the problem.  It's
> >> repeated 8 times because it's an 8 processor test job.  Any help
> >> would be fantastic.
> >>  Can not open/create file
> >> -1073749200: MPI_File_open error = Intercommunicator is
> not allowed
> >> -1073746896: MPI_File_open error = Intercommunicator is
> not allowed
> >> -1073751120: MPI_File_open error = Intercommunicator is
> not allowed
> >> -1073747536: MPI_File_open error = Intercommunicator is not allowed
> >> -1073749456: MPI_File_open error = Intercommunicator is not allowed
> >> -1073746512: MPI_File_open error = Intercommunicator is not allowed
> >> -1073750224: MPI_File_open error = Intercommunicator is not allowed
> >> -1073747248: MPI_File_open error = Intercommunicator is not allowed
> >> Code here:
> >>       subroutine prin(prefix)
> >> ! Outputs ascii array if ndim = 1, else if ndim > 1 then
> >> ! write out hdf5 data file containing all variables (plus time).
> >>       include 'pnetcdf.inc'
> >>       include 'global.h'
> >>       include 'sweep.h'
> >>       include 'zone.h'
> >>       ! integer(HID_T) :: hdf_file !file id for hdf file
> >>       integer :: hdf_error !error var for hdf5 file
> >>       character(LEN=1) :: char
> >>       character(LEN=1) :: coord
> >>       character(LEN=4) :: tmp1, tmp2
> >>       character(LEN=5) :: prefix
> >>       character(LEN=15) :: filename
> >> !     Added (Fortran 90 style) for hdf5 stuff
> >>       ! INTEGER(HID_T) :: dsp_id  ! Dataspace ID
> >>       ! INTEGER(HID_T) :: dset_id !Dataset ID
> >>       INTEGER, DIMENSION(3) :: dims
> >>       INTEGER, DIMENSION(3) :: dimids
> >>       INTEGER :: status, ncid
> >>       INTEGER :: xDimID, yDimID, zDimID
> >>       INTEGER :: yMaxDimID, tsDimID
> >>       INTEGER :: density_varID, pressure_varID
> >>       INTEGER :: XVelocity_varID, YVelocity_varID, ZVelocity_varID
> >>       INTEGER :: XScale_varID, YScale_varID, ZScale_varID,
> time_varID
> >> ! Create filename from integer nfile (in global.h) and prefix such
> >> that filename ! looks like prefx.1000 where 1000 is the value of
> >> nfile
> >>       write(tmp1,910) nfile
> >>       write(tmp2,910) mype
> >>  910  format(i4)
> >>       do i = 1, 4
> >>          if ((tmp1(i:i)) .eq. ' ') tmp1(i:i) = '0'
> >>          if ((tmp2(i:i)) .eq. ' ') tmp2(i:i) = '0'
> >>       enddo
> >>       filename = prefix(1:5) // '_' // tmp1(1:4) // '.' //
> tmp2(1:4)
> >>       nfile = nfile + 1
> >>       if (ndim .eq. 1) then
> >> ! Keep 1D output simple, just write out in ascii...
> >>         open(unit=3,file=filename,form='formatted')
> >>         do i = 1, imax
> >>           write(3, 1003) zxa(i), zro(i,1,1),zpr(i,1,1), zux(i,1,1)
> >>         enddo
> >>         close(3)
> >>       else
> >> !     Initialize Dimensions
> >>       dims(1) = imax
> >>       dims(2) = js
> >>       if(ndim.eq.3) dims(3) = kmax
> >>       status = nfmpi_create(MPI_COMM_WORLD, filename,
> >>      &                      MPI_INFO_NULL, nf90_Clobber, ncid)
> >>       if (status /= nf90_NoErr ) print *, nfmpi_strerror(status)
> >>       ! always a necessary statment to flush output
> >>       status = nfmpi_close(ncid)
> >>       endif
> >>       write(8,6000) filename, time, ncycle
> >>  6000 format('Wrote ',a10,' to disk at time =',1pe12.5,'
> (ncycle =',
> >>      &        i6,')')
> >>  1003 format(' ',4e13.5)
> >>       return
> >>       end
