error when using pnetcdf
Rajeev Thakur thakur at mcs.anl.gov
Mon Apr 5 18:33:33 CDT 2004
Can you check whether the lockd daemon is running on your machine? That is
needed for NFS file locking to work correctly.
If you are just running on single machine, you could write to a local file
system instead of an NFS home directory;
Rajeev
> -----Original Message-----
> From: owner-parallel-netcdf at mcs.anl.gov
> [mailto:owner-parallel-netcdf at mcs.anl.gov] On Behalf Of
> Foucar, James G
> Sent: Monday, April 05, 2004 6:01 PM
> To: 'parallel-netcdf at mcs.anl.gov'
> Subject: error when using pnetcdf
> hello, i am having trouble getting pnetcdf to work. it
> compiles and links, but when i run it i get the following error:
> File locking failed in ADIOI_Set_lock. If the file system is
> NFS, you need to use NFS version 3 and mount the directory
> with the 'noac' option (no attribute caching). [0] MPI Abort
> by user Aborting program ! [0] Aborting program!
> p0_23262:  p4_error: : 1
> When I use netcdf instead, the error goes away. any idea how
> to fix this? Platform = Xeon CPU, Red hat 9, pnetcdf 0.9.3,
> mpiCC 3.2.2
> thanks,
> james
