Fwd: Re: pnetcdf 0.8.8 release
William Gropp gropp at mcs.anl.gov
Thu Jul 31 11:51:28 CDT 2003
One thing to consider is the use of a "cross file" such as MPICH2
uses.  For each test that must be run, the environment variable CROSS_XXX
provides the value for the cross-compilation case (e.g.,
CROSS_SIZEOF_INT).  A --enable-cross=crossfile can cause configure to load
a file containing the definitions (provided separately by the user, or,
also a in MPICH2, with a *single* program that writes out all of the
necessary values).
Bill
>Date: Thu, 31 Jul 2003 09:56:19 +0200 (CEST)
>From: "rene.redler" <redler at ccrl-nece.de>
>To: parallel-netcdf at mcs.anl.gov
>Subject: Re: pnetcdf 0.8.8 release
>X-Virus-Scanned: by amavisd-milter (http://amavis.org/
>Sender: owner-parallel-netcdf at mcs.anl.gov
>X-Spam-Status: No, hits=-3.9 required=5.0
>tests=IN_REP_TO,FROM_NAME_NO_SPACES version=2.21
>X-Spam-Level:
>Hello,
> > I've put up version 0.8.8.  Major changes include a big cleanup in the
> > test directory and fixes to the makefiles to address issues on the NEC and
> > AIX platforms. Hopefully make; make install; make tests will just work
> > now.  A configure script is included, so you don't need to run autoconf.
>No problems so far with SX anymore :)
> > Rene -- any suggestions on getting the cross-compilation to work on your
> > system?  I've never tried to deal with this before.
>If the configure procedure requires to build and run executables for
>consistency checks there is no other way than invoking the configure on
>the target system itself. For building the lib and test programs e.g. on a
>Linux PC by using the SX cross compiler I edited the macros.make (which
>was generated on the SX) and replaced c++ by sxc++, mpic++ by sxmpic++,
>f90 by sxf90, ar by sxar, and set MAKEWHATIS_CMD to an empty string.
>I am not sure whether this should be recommended as a general strategy,
>but ...
>When applying these changes running  make; make install; make tests on
>the Linux PC worked, and most important the testing of the programs on the
>SX worked as well.
>Rene
>P.S.:
>To make the above really working I had to change the Makefile.in in
>directory test/common. I added a line
>AR = @AR@
>and replaced "ar cru" by "$(AR) cru"
>Perhaps the ar flags should be treated in a similar way (via environment
>variable ARFLAGS). This would require to modify /src/lib/Makefile.in as
>well.
