Houston, we have a problem
John Tannahill
tannahill1 at llnl.gov
Thu Jul 31 13:17:13 CDT 2003
Rob,
I am hoping that I can catch you before you leave, so that you can
pass this on to someone, but if you are already gone, can anyone
else take a look at this?
I have graduated up to my original bigger test case and the C version
works, but the Fortran version doesn't. It's certainly possible that
I have screwed up the translation from C to Fortran and I will be
looking at that, but I wanted to pass this back to you folks, so that
you can take a look at it to.
I am using 0.8.8. Attached are two tar files that should be pretty
self-explanatory, but let me know if you have questions.
John
John R. Tannahill
Lawrence Livermore Nat. Lab.
P.O. Box 808, M/S L-103
Livermore, CA 94551
925-423-3514
Fax: 925-423-4908
Type: application/x-tar
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20030731/fbad19b0/attachment.tar>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20030731/fbad19b0/attachment-0001.tar>
More information about the parallel-netcdf
