Hi, I just took the "-ansi" out of the CFLAGS defined when using the --enable-strict configure option. I was having problems getting PATH_MAX defined in some of the test codes when this was there. If anyone has a good way to both include the -ansi flag and get PATH_MAX cleanly defined, I'd be happy to see it put back in. Rob
