new
Rob Ross
rross at mcs.anl.gov
Tue Jul 29 17:55:30 CDT 2003
Hi all,
I've gotten back on Frost, and I've made some progress on the build
approach. The approach below will work with the release I'll send out in
a bit, except for the "make tests". The "make tests" is still broken
because it has a pushd/popd in it :(.
There are a couple of changes to note:
- setting MPICC and MPIF77 variables is the best thing to do any time
you want a specific MPI compiler
- if you do this, you don't need the --with-mpi on the configure line
- "make install" now works, using a script included to handle the case
where the default install doesn't understand "-d"
The notes below are in README.frost3 in the upcoming distribution as well.
I'm going to ignore that for a little bit and see if I can get John's test
codes to build over there.
Rob
# Rob Ross, 07/29/2003
# Based off John Tannahill's <tannahill1 at llnl.gov> approach, and Tyce
# Mclarty's <mclarty3 at llnl.gov> improvements, here's the newest version
# of "how to build on Frost".
# gunzip parallel-netcdf-0.8.4.tar.gz
# tar xf parallel-netcdf-0.8.4.tar
# cd parallel-netcdf-0.8.4
# Edit configure change MPICC and MPIF77 defintions to mpcc_r & mpxlf_r.
setenv CC xlc
setenv FC xlf
setenv F90 xlf90
setenv CXX xlC
setenv FFLAGS "-d -qmaxmem=4096 -O2"
setenv MPICC /usr/lpp/ppe.poe/bin/mpcc_r
setenv MPIF77 /usr/lpp/ppe.poe/bin/mpxlf_r
./configure --prefix=/usr/local/hdf5/pnetcdf-0.8.5
# make
# make install
# make tests
More information about the parallel-netcdf
