parallel netcdf - first experiences
rene.redler redler at ccrl-nece.de
Tue Jul 29 09:25:05 CDT 2003
Hello Rob,
> The -C in the Makefiles is my fault and I've gotten rid of it (but not
> in time for 0.8.6 ).  Could you tell me more about the 'other odd
> things'?  It may drive me crazy, but we're going to try to get the
> Makefiles to work with as many make implementations as possible.
As already mentioned in my first email NEC's install comes with a different
syntax than the Linux install. Changing those line to something like
test -d <path/directory> || mkdir -p <path/director> && chmod 755 <path/director>
cp -r <dir/files_to_copy> <path/directory> && chmod 644 <path/directory>/<dir/file>
not very elegant but (I guess) portable and should run at least under
csh and sh.
The Makefile in /src/lib lines 101 to 104 cause some problems. Only the
program is generated while the library files are not processed. The latter
should be invoked in the include files but the NEC's make is not able to
resolve this properly. The reason is still unclear to me.
The Makefile in src/libf has an empty PROGRAM and PROG_CSRCS which causes
line 89 to fail. The reason for this is still unclear to me as well.
But as long as cross-compiling works (which is the case already) I am not
too worried about this.
> > Nevertheless trying to test_read the netCDF files failed, and the ncmpi
> > routines returned and invalid id or dimension. Did anyone encounter a
> > similar behavior on any other architecture?
I placed some printf in the source code to learn more about what is going
wrong.
test_read.c calls ncmpi_open: returned ncid1 = 0
hdr_get_NC (called from ncmpi_open) returns -46=Invalid dimension id or name
NC_computeshapes (called from hdr_get_NC)
NC_var_shape (called from NC_computeshapes)
When printing *ip in the loop starting at line 379 *ip is first 0 and then
16777216 which is obviously a wrong id.
Up to now I was not able to identify why dimids[] contains these wrong
values. It could be due to the fact that on the SX pointer are of size 64
bit, while ints are of size 32 bit.
> On ia32 linux, these tests all pass.  Could you send which tests you
> ran and how you ran them?
So it did on my laptop today. I ran test_int, but the same will probably
happen with test_double and test_float which I briefly tried out yesterday
as well (without success).
> Thanks for helping us shake out problems in our software!
I would rather come up with solutions than only with a list of problems.
But as a 100% Fortran programmer I am hardly at my limits identifying
those kind of problems in C.
Rene
   _______________________________________________________________
      René Redler
      C&C Research Laboratories
      NEC Europe Ltd.                   Tel: +49 (0)2241 925240
      Rathausallee 10                   Fax: +49 (0)2241 925299
      53757 Sankt Augustin              URL: www.ccrl-nece.de/~redler
