fortran parallel-netcdf
Tyce Mclarty
mclarty3 at llnl.gov
Mon Jul 28 19:50:05 CDT 2003
John,
Enclosed is a tar file with your code and slightly different Makefile that
works for me on snow, which is just a smaller version of frost. It uses the
parallel netCDF library I installed in /usr/local. It should be world useable.
Try it and let me know if it doesn't work for you.
Tyce
At 01:25 PM 7/28/2003 -0700, John Tannahill wrote:
>Robs,
>Have you been able to reproduce my problem? Can I be of any help on this
>end? I am in kind of a holding pattern until this is resolved.
>Regards,
>John
>Rob Ross wrote:
>>Thanks for your patience John; we'll have a look at this on Monday and
>>see if we can fix things.
>>Rob
>>On Fri, 25 Jul 2003, John Tannahill wrote:
>>>Rob and Rob,
>>>I am having a good deal of difficulty getting the Fortran test code that I
>>>put together to run. I have cut it down to where it just defines and
>>>creates the initial file and I can't seem to get it to work. So what I did
>>>is translate it back into C code and tried that. It ran just fine. I am
>>>attaching both versions and the Makefile's I used to create them. I am
>>>hoping that you guys can help me out. I am guessing the problem is with
>>>the Fortran parallel-netcdf library, but who knows? Anyway, enough for
>>>today.
>>>Regards,
>>>John
>John R. Tannahill
>Lawrence Livermore Nat. Lab.
>P.O. Box 808, M/S L-103
>Livermore, CA 94551
>925-423-3514
>Fax: 925-423-4908
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20030728/37020dd4/attachment.obj>
More information about the parallel-netcdf
