parallel netcdf - first experiences
Rob Ross
rross at mcs.anl.gov
Mon Jul 28 17:34:40 CDT 2003
Ok, if that's true then the first call should be hvector() as well.
Although given the MPI_BYTE type it won't make a lot of difference except
in cases where the offset is bigger than an int (and MPI_Aint is bigger
than an int).
Rob
On Mon, 28 Jul 2003, Jianwei Li wrote:
> Yes. That should be MPI_Type_create_hvector in the case of MPI-2.
> I believe it's a typo, which is confirmed with the right function
> name right below that part of src code in "mpinetcdf.c" line 1487.
> Jianwei
> On Mon, 28 Jul 2003, Rob Ross wrote:
> > I think that Rajeev has identified the problem :).
> > Rob
> > On Mon, 28 Jul 2003, Rajeev Thakur wrote:
> > > > > When trying to create the test cases I recognized that
> > > > mpinetcdf.c tries
> > > > > to call MPI_Type_create_vector which I guess is not part of the MPI2
> > > > > standard. Are there any plans to to add this function to the MPI2 in
> > > > > future? I also could not find this function in the mpich-1.2.5 release.
> > > > > Comments are welcome.
> > > > I'm going to defer to someone more familiar with the differnce between
> > > > MPI-1 and MPI-2.. We *should* be using the MPI_VERSION macro to call the
> > > > right type function, like this:
> > > > #if (MPI_VERSION < 2)
> > > > MPI_Type_vector(subcount[0], varp->xsz, ncp->recsize,
> > > > MPI_BYTE, &filetype);
> > > > #else
> > > > MPI_Type_create_vector(subcount[0], varp->xsz, ncp->recsize,
> > > > #endif
> > > There isn't a function called MPI_Type_create_vector in MPI. There is a
> > > type_create_hvector and a type_vector.
> > > Rajeev
More information about the parallel-netcdf
