parallel netcdf - first experiences
Jianwei Li
jianwei at cheetah.cpdc.ece.nwu.edu
Mon Jul 28 13:57:06 CDT 2003
Yes. That should be MPI_Type_create_hvector in the case of MPI-2.
I believe it's a typo, which is confirmed with the right function
name right below that part of src code in "mpinetcdf.c" line 1487.
Jianwei
On Mon, 28 Jul 2003, Rob Ross wrote:
> I think that Rajeev has identified the problem :).
> Rob
> On Mon, 28 Jul 2003, Rajeev Thakur wrote:
> > > > When trying to create the test cases I recognized that
> > > mpinetcdf.c tries
> > > > to call MPI_Type_create_vector which I guess is not part of the MPI2
> > > > standard. Are there any plans to to add this function to the MPI2 in
> > > > future? I also could not find this function in the mpich-1.2.5 release.
> > > > Comments are welcome.
> > > I'm going to defer to someone more familiar with the differnce between
> > > MPI-1 and MPI-2.. We *should* be using the MPI_VERSION macro to call the
> > > right type function, like this:
> > > #if (MPI_VERSION < 2)
> > > MPI_Type_vector(subcount[0], varp->xsz, ncp->recsize,
> > > MPI_BYTE, &filetype);
> > > #else
> > > MPI_Type_create_vector(subcount[0], varp->xsz, ncp->recsize,
> > > #endif
> > There isn't a function called MPI_Type_create_vector in MPI. There is a
> > type_create_hvector and a type_vector.
> > Rajeev
More information about the parallel-netcdf
