question
John Tannahill tannahill1 at llnl.gov
Wed Jul 23 11:25:05 CDT 2003
Please keep me posted as to the status of my problem with the
Fortran interface.  I will look at it some more myself, but I
don't have much experience with autoconf, etc.  Maybe the autoconf
stuff is fine and it is just something more basic I am missing?  I
would be happy to send you any diagnostic information you would like.
In fact, I will include here the procedure I used to get the library
installed on seaborg/NERSC (it's a little different than what I
used on frost):
seaborg:
gunzip parallel-netcdf-0.8.4.tar.gz
tar xf parallel-netcdf-0.8.4.tar
cd parallel-netcdf-0.8.4
vi configure.in
   Change:
     UC_PROG_FC
   To:
     UD_PROG_FC
setenv CC xlc
setenv FC xlf
module load gnu
autoconf
vi configure
   Comment out the following lines in configure:
     ###if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
     ###  (eval $ac_compile) 2>&5
     ###  ac_status=$?
     ###  echo "$as_me:$LINENO: \$? = $ac_status" >&5
     ###  (exit $ac_status); } &&
     ###         { ac_try='test -s conftest.$ac_objext'
     ###  { (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
     ###  (eval $ac_try) 2>&5
     ###  ac_status=$?
     ###  (exit $ac_status); }; }; then
     ###  echo "$as_me:$LINENO: result: yes" >&5
     ###echo "${ECHO_T}yes" >&6
     ###else
     ###  echo "$as_me: failed program was:" >&5
     ###cat conftest.$ac_ext >&5
     ###{ { echo "$as_me:$LINENO: error: mpi implementation does not support ...
     ###echo "$as_me: error: mpi implementation does not support MPI-IO" >&2;}
     ###   { (exit 1); exit 1; }; }
     ###fi
./configure --prefix=/usr/common/homes/j/jrt/Pnc/parallel-netcdf-0.8.4
vi macros.make
   Change:
     CC  = xlc
     CXX = xlC_r
     FC  = xlf
   To:
     CC  = mpcc_r
     CXX = mpCC_r
     FC  = mpxlf_r
make
make install
Robert Latham wrote:
> On Tue, Jul 22, 2003 at 01:34:11PM -0700, John Tannahill wrote:
>>I am steadily making progress.  I have installed parallel-netcdf on
>>an IBM-SP at NERSC (seaborg).  I have put together a C test code and
>>gotten it to work.
> fantastic. thanks for the success report!
>>I now have created a Fortran90 version of the
>>test code, but have not gotten it to link and run yet.  Does the
>>default install put together a parallel-netcdf interface for C only?
> The default install *should* try to build the fortran interface, but
> it is not nearly as well tested as the c interface.
>>Do I need to change something and rebuild it to get a Fortran90
>>interface?
> i don't know f90 very well... if we have to do anything special for a
> f90 interface that we wouldn't have to do for an f77 interface, then
> maybe that's the problem?
>>Then do I just change the ncmpi_ calls to nfmpi_, and add
>>an ierror argument at the end?
> that's how it works in theory :>
>>Anywhere I could have looked to get answers to these questions
>>myself?
> nope :> you and troy baer are the only end users who have tried out
> our fortran interface.   I'll see what i can find out tomorrow, and
> i'll be sure to let you know.
> Thanks for exercising the fortran side of things for us.  Sorry you
> are running into so much difficulty, but we'll try to get you
> straight as soon as we can.
> ==rob
John R. Tannahill
Lawrence Livermore Nat. Lab.
P.O. Box 808, M/S L-103
Livermore, CA  94551
925-423-3514
Fax:  925-423-4908
