[Fwd: Parallel versus serial netCDF?] (fwd)
Rob Ross
rross at mcs.anl.gov
Thu Aug 21 11:22:15 CDT 2003
On Thu, 21 Aug 2003 John Tannahill wrote:
> Rob,
> Do you know when the switch [to functions over subroutines] will be made?
Very soon. We want to do one more release with a working nf_test before
we change this (and then have to change nf_test again!).
> Also, another small item:
> I had to change Nf_Get_Vara_Real to Nfmpi_Get_Vara_Float_All, and
> Nf_Put_Vara_Real to Nfmpi_Put_Vara_Float_All. I think the serial
> version always uses REAL and your parallel version always uses
> FLOAT? Would be nice if they were the same, or if your version
> could do both.
Hmm. We'll have a look at this one.
Thanks for all this input John; this is a big help to us, and hopefully
we're not holding you back too much.
Rob
More information about the parallel-netcdf
