Compiling parallel-netcdf 0.8.9 on QSC (ASCI Q)
Tyce Mclarty
mclarty3 at llnl.gov
Thu Aug 21 10:35:10 CDT 2003
Can't you use the -i8 fortran flag to force 64 bit integers, so it will
pass the configure test?
From f90 man page:
-i8 Makes default integer and logical variables 8-bytes long (same
as the -integer_size 64 option). The default is -integer_size
32.
Tyce
At 05:59 PM 8/20/2003 -0500, JB Gallagher wrote:
>Rob, Jianwei,
>Today I tried getting parallelnetcdf working with the Flash code on ASCI Q
>(Alpha Compaq cluster running Tru64) I was able to get older versions
>supplied to me by Jianwei to compile (becasue the configure's don't check
>if size_t and int are the same size) but code linked with this library
>fails in a similar way that hdf5_parallel i/o is failing on Q in Flash, I
>get errors saying the comminucator is not valid:
>4 4: The communicator is invalid8
>4 0: Exiting with status 500 (MPI_ERR_COMM in class MPI_ERR_COMM)
>3 3: Exiting with status 500 (MPI_ERR_COMM in class MPI_ERR_COMM)
>But most important to you all the configure script from your newest
>distribution (0.8.9) stops with the size_t int comparison:
>checking for size_t... yes
>checking whether size_t and int size match... no
>configure: error: This is a critical error; please report this size
>mismatch to the developers!
>I'll be talking with system folks that administor the ASCI machines
>tommorow, so I'll tell them what I've learned (as I indicated before even
>or hdf5_parallel module doesn't work on this system) so far, but if you
>have any questions that I should ask them based on what I said here let me
>know before tommorow morning.
>thanks,
>--Brad
>Brad Gallagher
>ASCI Flash Center
>jbgallag at flash.uchicago.edu
More information about the parallel-netcdf
