[opa-nightly-tests] jelly OPA_Daily_Tests_0909Sat
hdftest hdftest at hdfgroup.org
Sat Sep 9 21:57:34 CDT 2023
*** OPA Tests on 0909Sat ***
   Tests Summary
PASSED jelly: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED moohan: standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
   Tests Time Summary
koala: Ran 1(1/0/0) tests, Grand total test time =  0m 32s
platypus: Ran 1(1/0/0) tests, Grand total test time =  0m 46s
jelly: Ran 1(1/0/0) tests, Grand total test time =  1m 3s
moohan: Ran 1(1/0/0) tests, Grand total test time =  2m 18s
jelly: Ran 6(0/0/0) hosts, Grand total test time =  3m 23s
   Timekeeper log
Timekeeper started at Sat Sep  9 21:54:23 CDT 2023
Timekeeper sleeping for 1200 seconds
   Tests Failures
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
 21:54:01 up 45 days, 56 min,  6 users,  load average: 8.29, 12.53, 11.36
Filesystem                  1K-blocks       Used  Available Use% Mounted on
devtmpfs                     65868920          0   65868920   0% /dev
tmpfs                         4194304      79472    4114832   2% /dev/shm
tmpfs                        65880516     486288   65394228   1% /run
tmpfs                        65880516          0   65880516   0% /sys/fs/cgroup
/dev/mapper/centos00-root    16766976    9510272    7256704  57% /
/dev/md0                   3904859232 2161008976 1743850256  56% /scr
tmpfs                        65880516          0   65880516   0% /mnt/daos
/dev/md10                 11718682624 7816952116 3901730508  67% /mnt/wrk
/dev/mapper/centos00-opt    134152192  127161992    6990200  95% /opt
/dev/sda1                      520876     288780     232096  56% /boot
10.10.10.85:/data/ftp       480719104  419160320   37139584  92% /mnt/ftp
10.10.10.86:/home           961432576  152905728  759689216  17% /home
10.10.10.86:/mnt/hdf        961432576  877330432   35263488  97% /mnt/hdf
10.10.10.86:/mnt/scr1       961432576  886756352   25838592  98% /mnt/scr1
10.10.10.85:/data/web       480719104  419160320   37139584  92% /mnt/web
tmpfs                        13176104          0   13176104   0% /run/user/27429
tmpfs                        13176104          0   13176104   0% /run/user/29138
tmpfs                        13176104          4   13176100   1% /run/user/10019
tmpfs                        13176104          0   13176104   0% /run/user/10022
tmpfs                        13176104          0   13176104   0% /run/user/10013
tmpfs                        13176104          0   13176104   0% /run/user/10008
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly
Running source repository checkout with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0909Sat
*** launching tests from jelly ***
TESTHOST is jelly
koala
platypus
moohan
ostrich
osx1011test
    Fork off timekeeper 20
Testing jelly
ssh -o ConnectTimeout=60 jelly -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jelly
 21:54:29 up 45 days, 56 min,  6 users,  load average: 7.05, 11.90, 11.18
tmpfs                        65880516     486328   65394188   1% /run
/dev/mapper/centos00-root    16766976    9510528    7256448  57% /
/dev/md0                   3904859232 2160928032 1743931200  56% /scr
10.10.10.86:/mnt/hdf        961432576  877411328   35183616  97% /mnt/hdf
10.10.10.86:/mnt/scr1       961432576  886758400   25836544  98% /mnt/scr1
Extract source and run autogen if .
Sat Sep  9 21:54:39 CDT 2023
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly tests in jelly ***
Uname -a: Linux jelly 3.10.0-1160.80.1.el7.x86_64 #1 SMP Tue Nov 8 15:48:59 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
Running snapshot with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/jelly_0909Sat_2154
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly tests for jelly ***
Sat Sep  9 21:55:42 CDT 2023
Total time = 1m 3s
*** finished tests in jelly ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
 21:54:31 up 63 days, 13:32,  0 users,  load average: 0.21, 0.23, 0.41
/dev/sda7             22292052   4428132  16713268  21% /
/dev/sda5             12192608    398740  11164524   4% /tmp
/dev/sda3             12192636   1202336  10360956  11% /var
/dev/sda1               101086     18614     77253  20% /boot
/dev/sdc1             41279536  26323756  12858900  68% /usr
/dev/sdb             152754284  79719636  65275188  55% /scr
tmpfs                  6149552         0   6149552   0% /dev/shm
10.10.10.86:/mnt/hdf 961432576 877417472  35176448  97% /mnt/hdf
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Sat Sep  9 21:54:41 CDT 2023
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-409.el5 #1 SMP Tue Mar 15 18:13:50 EDT 2016 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/koala_0909Sat_2154
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Sat Sep  9 21:55:13 CDT 2023
Total time = 0m 32s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
 21:54:34 up 63 days, 13:32,  1 user,  load average: 3.36, 4.05, 4.23
/dev/sda6             54205540  43007028   8438372  84% /
tmpfs                  6099068         0   6099068   0% /dev/shm
/dev/sda1               194241     48310    135691  27% /boot
/dev/sda2             12850716     69628  12121632   1% /tmp
/dev/sda3             12850716   6189336   6001924  51% /var
/dev/sdd             152623212 123044740  21819012  85% /scr
10.10.10.86:/mnt/hdf 961432576 877426688  35168256  97% /mnt/hdf
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Sat Sep  9 21:54:44 CDT 2023
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-573.22.1.el6.x86_64 #1 SMP Wed Mar 23 03:35:39 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/platypus_0909Sat_2154
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Sat Sep  9 21:55:30 CDT 2023
Total time = 0m 46s
*** finished tests in platypus ***
Testing moohan
ssh -o ConnectTimeout=60 moohan -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname moohan
 21:54:36 up 63 days, 18:22,  1 user,  load average: 2.51, 2.67, 2.87
/dev/mapper/centos_moohan-root  52196352  10417912  41778440  20% /
devtmpfs                         3923072         0   3923072   0% /dev
tmpfs                            3939844        84   3939760   1% /dev/shm
tmpfs                            3939844    418852   3520992  11% /run
tmpfs                            3939844         0   3939844   0% /sys/fs/cgroup
/dev/md126p1                      506752    312960    193792  62% /boot
/dev/mapper/centos_moohan-tmp   16371712     33440  16338272   1% /tmp
/dev/mapper/centos_moohan-var   16371712   4695256  11676456  29% /var
/dev/mapper/centos_moohan-scr  858065536 399875308 458190228  47% /scr
tmpfs                             787972        16    787956   1% /run/user/42
jam:/home                      961432576 152905728 759689216  17% /home
jam:/mnt/hdf                   961432576 877433856  35160064  97% /mnt/hdf
jam:/mnt/scr1                  961432576 886758400  25836544  98% /mnt/scr1
gumund:/data/web               480719104 419160320  37139584  92% /mnt/web
gumund:/data/ftp               480719104 419160320  37139584  92% /mnt/ftp
tmpfs                             787972         0    787972   0% /run/user/27429
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
Sat Sep  9 21:54:47 CDT 2023
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests in moohan ***
Uname -a: Linux moohan.ad.hdfgroup.org 3.10.0-327.10.1.el7.x86_64 #1 SMP Tue Feb 16 17:03:50 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/moohan_0909Sat_2154
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests for moohan ***
Sat Sep  9 21:57:04 CDT 2023
Total time = 2m 17s
*** finished tests in moohan ***
Testing ostrich
ostrich is not reachable (Sat Sep  9 21:54:36 CDT 2023)
	****SYSTEM ERROR: ostrich is not reachable (Sat Sep  9 21:54:36 CDT 2023)
	****INCOMPLETE ostrich: snaptest did not complete****
Testing osx1011test
ssh -o ConnectTimeout=60 osx1011test -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname osx1011test
grep: /proc/cpuinfo: No such file or directory
snapshots-opa: No such file or directory.
/mnt/scr1/SnapTest/snapshots-opa/bin/runtest: Command not found.
****SYSTEM ERROR osx1011test: Abnormal exit from runtest ****
	****SYSTEM ERROR osx1011test: runtest command failed ****
More information about the opa-nightly-tests mailing list
