[opa-nightly-tests] jelly OPA_Daily_Tests_0908Fri
hdftest
hdftest at hdfgroup.org
Fri Sep 8 21:59:12 CDT 2023
*** OPA Tests on 0908Fri ***
Tests Summary
PASSED jelly: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED moohan: standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Tests Time Summary
koala: Ran 1(1/0/0) tests, Grand total test time = 0m 34s
platypus: Ran 1(1/0/0) tests, Grand total test time = 0m 48s
jelly: Ran 1(1/0/0) tests, Grand total test time = 1m 8s
moohan: Ran 1(1/0/0) tests, Grand total test time = 1m 11s
jelly: Ran 6(0/0/0) hosts, Grand total test time = 2m 17s
Timekeeper log
Timekeeper started at Fri Sep 8 21:57:07 CDT 2023
Timekeeper sleeping for 1200 seconds
Tests Failures
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
21:56:45 up 44 days, 59 min, 6 users, load average: 12.64, 12.80, 13.55
Filesystem 1K-blocks Used Available Use% Mounted on
devtmpfs 65868920 0 65868920 0% /dev
tmpfs 4194304 77296 4117008 2% /dev/shm
tmpfs 65880516 470000 65410516 1% /run
tmpfs 65880516 0 65880516 0% /sys/fs/cgroup
/dev/mapper/centos00-root 16766976 9505304 7261672 57% /
/dev/md0 3904859232 2164804344 1740054888 56% /scr
tmpfs 65880516 0 65880516 0% /mnt/daos
/dev/md10 11718682624 7817244740 3901437884 67% /mnt/wrk
/dev/mapper/centos00-opt 134152192 127161992 6990200 95% /opt
/dev/sda1 520876 288780 232096 56% /boot
10.10.10.85:/data/ftp 480719104 447447552 8852352 99% /mnt/ftp
10.10.10.86:/home 961432576 152905728 759689216 17% /home
10.10.10.86:/mnt/hdf 961432576 877722624 34871296 97% /mnt/hdf
10.10.10.86:/mnt/scr1 961432576 887278592 25316352 98% /mnt/scr1
10.10.10.85:/data/web 480719104 447447552 8852352 99% /mnt/web
tmpfs 13176104 0 13176104 0% /run/user/27429
tmpfs 13176104 0 13176104 0% /run/user/29138
tmpfs 13176104 4 13176100 1% /run/user/10019
tmpfs 13176104 0 13176104 0% /run/user/10022
tmpfs 13176104 0 13176104 0% /run/user/22417
tmpfs 13176104 0 13176104 0% /run/user/10013
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0908Fri
*** launching tests from jelly ***
TESTHOST is jelly
koala
platypus
moohan
ostrich
osx1011test
Fork off timekeeper 20
Testing jelly
ssh -o ConnectTimeout=60 jelly -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jelly
21:57:12 up 44 days, 59 min, 6 users, load average: 9.56, 12.05, 13.28
tmpfs 65880516 470040 65410476 1% /run
/dev/mapper/centos00-root 16766976 9505560 7261416 57% /
/dev/md0 3904859232 2163817936 1741041296 56% /scr
10.10.10.86:/mnt/hdf 961432576 877199360 35395584 97% /mnt/hdf
10.10.10.86:/mnt/scr1 961432576 887277568 25317376 98% /mnt/scr1
Extract source and run autogen if .
Fri Sep 8 21:57:23 CDT 2023
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly tests in jelly ***
Uname -a: Linux jelly 3.10.0-1160.80.1.el7.x86_64 #1 SMP Tue Nov 8 15:48:59 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
Running snapshot with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/jelly_0908Fri_2157
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly tests for jelly ***
Fri Sep 8 21:58:30 CDT 2023
Total time = 1m 7s
*** finished tests in jelly ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
21:57:14 up 62 days, 13:35, 0 users, load average: 0.05, 0.11, 0.33
/dev/sda7 22292052 4428132 16713268 21% /
/dev/sda5 12192608 398772 11164492 4% /tmp
/dev/sda3 12192636 1201252 10362040 11% /var
/dev/sda1 101086 18614 77253 20% /boot
/dev/sdc1 41279536 26323756 12858900 68% /usr
/dev/sdb 152754284 79622168 65372656 55% /scr
tmpfs 6149552 0 6149552 0% /dev/shm
961432576 887270400 25324544 98% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Fri Sep 8 21:57:25 CDT 2023
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-409.el5 #1 SMP Tue Mar 15 18:13:50 EDT 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/koala_0908Fri_2157
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Fri Sep 8 21:57:58 CDT 2023
Total time = 0m 33s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
21:57:17 up 62 days, 13:35, 0 users, load average: 1.71, 2.55, 3.46
/dev/sda6 54205540 43007028 8438372 84% /
tmpfs 6099068 0 6099068 0% /dev/shm
/dev/sda1 194241 48310 135691 27% /boot
/dev/sda2 12850716 85132 12106128 1% /tmp
/dev/sda3 12850716 6152200 6039060 51% /var
/dev/sdd 152623212 123025208 21838544 85% /scr
961432576 887271424 25323520 98% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Fri Sep 8 21:57:28 CDT 2023
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-573.22.1.el6.x86_64 #1 SMP Wed Mar 23 03:35:39 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/platypus_0908Fri_2157
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Fri Sep 8 21:58:15 CDT 2023
Total time = 0m 47s
*** finished tests in platypus ***
Testing moohan
ssh -o ConnectTimeout=60 moohan -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname moohan
21:57:21 up 62 days, 18:25, 1 user, load average: 2.45, 4.26, 3.86
/dev/mapper/centos_moohan-root 52196352 10417912 41778440 20% /
devtmpfs 3923072 0 3923072 0% /dev
tmpfs 3939844 84 3939760 1% /dev/shm
tmpfs 3939844 402468 3537376 11% /run
tmpfs 3939844 0 3939844 0% /sys/fs/cgroup
/dev/md126p1 506752 312960 193792 62% /boot
/dev/mapper/centos_moohan-tmp 16371712 33416 16338296 1% /tmp
/dev/mapper/centos_moohan-var 16371712 4662140 11709572 29% /var
/dev/mapper/centos_moohan-scr 858065536 401491056 456574480 47% /scr
tmpfs 787972 16 787956 1% /run/user/42
jam:/home 961432576 152905728 759689216 17% /home
jam:/mnt/hdf 961432576 877199360 35395584 97% /mnt/hdf
jam:/mnt/scr1 961432576 887278592 25316352 98% /mnt/scr1
gumund:/data/web 480719104 447447552 8852352 99% /mnt/web
gumund:/data/ftp 480719104 447447552 8852352 99% /mnt/ftp
tmpfs 787972 0 787972 0% /run/user/27429
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
Fri Sep 8 21:57:31 CDT 2023
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests in moohan ***
Uname -a: Linux moohan.ad.hdfgroup.org 3.10.0-327.10.1.el7.x86_64 #1 SMP Tue Feb 16 17:03:50 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/moohan_0908Fri_2157
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests for moohan ***
Fri Sep 8 21:58:42 CDT 2023
Total time = 1m 11s
*** finished tests in moohan ***
Testing ostrich
ostrich is not reachable (Fri Sep 8 21:57:21 CDT 2023)
****SYSTEM ERROR: ostrich is not reachable (Fri Sep 8 21:57:21 CDT 2023)
****INCOMPLETE ostrich: snaptest did not complete****
Testing osx1011test
ssh -o ConnectTimeout=60 osx1011test -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname osx1011test
grep: /proc/cpuinfo: No such file or directory
snapshots-opa: No such file or directory.
/mnt/scr1/SnapTest/snapshots-opa/bin/runtest: Command not found.
****SYSTEM ERROR osx1011test: Abnormal exit from runtest ****
****SYSTEM ERROR osx1011test: runtest command failed ****
More information about the opa-nightly-tests
