[opa-nightly-tests] jelly OPA_Daily_Tests_1129Wed
hdftest hdftest at hdfgroup.org
Thu Nov 30 00:08:43 CST 2023
*** OPA Tests on 1129Wed ***
   Tests Summary
PASSED jelly: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly
PASSED moohan: standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
   Tests Time Summary
jelly: Ran 0(0/0/0) , Grand total test time =  90m 1s
platypus: Ran 0(0/0/0) , Grand total test time =  90m 1s
moohan: Ran 0(0/0/0) , Grand total test time =  90m 2s
koala: Ran 0(0/0/0) , Grand total test time =  90m 25s
platypus: Ran 1(1/0/0) tests, Grand total test time =  0m 42s
jelly: Ran 1(1/0/0) tests, Grand total test time =  1m 3s
moohan: Ran 1(1/0/0) tests, Grand total test time =  1m 21s
jelly: Ran 6(0/0/0) hosts, Grand total test time =  20m 43s
   Timekeeper log
Timekeeper started at Wed Nov 29 23:48:13 CST 2023
Timekeeper sleeping for 1200 seconds
Timekeeper woke up at Thu Nov 30 00:08:13 CST 2023, looking for processes to terminate...
terminating process PID.koala_koala (51278)
Remote shell command ended.  But some processes might still be
running in the remote machine.  Login there to verify.
Timekeeper ended at Thu Nov 30 00:08:13 CST 2023
   Tests Failures
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
 23:47:50 up 126 days,  3:50,  1 user,  load average: 0.08, 0.03, 0.22
Filesystem                  1K-blocks       Used  Available Use% Mounted on
devtmpfs                     65868920          0   65868920   0% /dev
tmpfs                         4194304      22424    4171880   1% /dev/shm
tmpfs                        65880516    1288996   64591520   2% /run
tmpfs                        65880516          0   65880516   0% /sys/fs/cgroup
/dev/mapper/centos00-root    16766976    9265704    7501272  56% /
/dev/md0                   3904859232 2564160544 1340698688  66% /scr
tmpfs                        65880516          0   65880516   0% /mnt/daos
/dev/md10                 11718682624 7972522088 3746160536  69% /mnt/wrk
/dev/mapper/centos00-opt    134152192  127161992    6990200  95% /opt
/dev/sda1                      520876     288780     232096  56% /boot
10.10.10.85:/data/ftp       480719104  439386496   16913408  97% /mnt/ftp
10.10.10.86:/mnt/hdf        961432576  880371712   32223232  97% /mnt/hdf
10.10.10.86:/mnt/scr1       961432576  883875840   28719104  97% /mnt/scr1
10.10.10.85:/data/web       480719104  439386496   16913408  97% /mnt/web
tmpfs                        13176104          0   13176104   0% /run/user/29138
10.10.10.86:/home           961432576  153523200  759070720  17% /home
tmpfs                        13176104          0   13176104   0% /run/user/27429
tmpfs                        13176104          0   13176104   0% /run/user/10022
tmpfs                        13176104          0   13176104   0% /run/user/22417
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly
Running source repository checkout with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_1129Wed
*** launching tests from jelly ***
TESTHOST is jelly
koala
platypus
moohan
ostrich
osx1011test
    Fork off timekeeper 20
Testing jelly
ssh -o ConnectTimeout=60 jelly -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jelly
 23:48:18 up 126 days,  3:50,  1 user,  load average: 0.05, 0.03, 0.21
tmpfs                        65880516    1289036   64591480   2% /run
/dev/mapper/centos00-root    16766976    9265768    7501208  56% /
Extract source and run autogen if .
Wed Nov 29 23:48:28 CST 2023
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly tests in jelly ***
Uname -a: Linux jelly 3.10.0-1160.80.1.el7.x86_64 #1 SMP Tue Nov 8 15:48:59 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
Running snapshot with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/jelly_1129Wed_2348
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly tests for jelly ***
Wed Nov 29 23:49:31 CST 2023
Total time = 1m 3s
*** finished tests in jelly ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
 23:48:34 up 19 days, 13:30,  0 users,  load average: 43.83, 43.59, 43.95
/dev/sda7             22292052   4428152  16713248  21% /
/dev/sda5             12192608    403844  11159420   4% /tmp
/dev/sda3             12192636   1574964   9988328  14% /var
/dev/sda1               101086     18614     77253  20% /boot
/dev/sdc1             41279536  26323756  12858900  68% /usr
/dev/sdb             152754284  80019708  64975116  56% /scr
tmpfs                  6149552         0   6149552   0% /dev/shm
gumund:/data/ftp     480719104 439386496  16913408  97% /mnt/ftp
gumund:/data/web     480719104 439386496  16913408  97% /mnt/web
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Wed Nov 29 23:49:08 CST 2023
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-409.el5 #1 SMP Tue Mar 15 18:13:50 EDT 2016 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/koala_1129Wed_2349
	****INCOMPLETE koala: snaptest did not complete****
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
 23:48:30 up 144 days, 16:26,  0 users,  load average: 0.50, 0.43, 0.23
/dev/sda6             54205540  43007028   8438372  84% /
tmpfs                  6099068         0   6099068   0% /dev/shm
/dev/sda1               194241     48310    135691  27% /boot
/dev/sda2             12850716     70524  12120736   1% /tmp
/dev/sda3             12850716   4969584   7221676  41% /var
/dev/sdd             152623212 121629048  23234704  84% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Wed Nov 29 23:48:40 CST 2023
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-573.22.1.el6.x86_64 #1 SMP Wed Mar 23 03:35:39 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/platypus_1129Wed_2348
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Wed Nov 29 23:49:22 CST 2023
Total time = 0m 42s
*** finished tests in platypus ***
Testing moohan
ssh -o ConnectTimeout=60 moohan -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname moohan
 23:48:34 up 76 days,  5:55,  1 user,  load average: 0.39, 1.06, 2.05
/dev/mapper/centos_moohan-root  52196352  10417912  41778440  20% /
devtmpfs                         3923072         0   3923072   0% /dev
tmpfs                            3939844        84   3939760   1% /dev/shm
tmpfs                            3939844    418768   3521076  11% /run
tmpfs                            3939844         0   3939844   0% /sys/fs/cgroup
/dev/md126p1                      506752    312960    193792  62% /boot
/dev/mapper/centos_moohan-var   16371712   3918112  12453600  24% /var
/dev/mapper/centos_moohan-scr  858065536 399749640 458315896  47% /scr
/dev/mapper/centos_moohan-tmp   16371712     33400  16338312   1% /tmp
tmpfs                             787972        16    787956   1% /run/user/42
jam:/home                      961432576 153523200 759070720  17% /home
jam:/mnt/hdf                   961432576 880371712  32223232  97% /mnt/hdf
jam:/mnt/scr1                  961432576 883875840  28719104  97% /mnt/scr1
tmpfs                             787972         0    787972   0% /run/user/27429
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
Wed Nov 29 23:48:44 CST 2023
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests in moohan ***
Uname -a: Linux moohan.ad.hdfgroup.org 3.10.0-327.10.1.el7.x86_64 #1 SMP Tue Feb 16 17:03:50 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/moohan_1129Wed_2348
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests for moohan ***
Wed Nov 29 23:50:05 CST 2023
Total time = 1m 21s
*** finished tests in moohan ***
Testing ostrich
ostrich is not reachable (Wed Nov 29 23:48:33 CST 2023)
	****SYSTEM ERROR: ostrich is not reachable (Wed Nov 29 23:48:33 CST 2023)
	****INCOMPLETE ostrich: snaptest did not complete****
Testing osx1011test
ssh -o ConnectTimeout=60 osx1011test -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname osx1011test
grep: /proc/cpuinfo: No such file or directory
snapshots-opa: No such file or directory.
/mnt/scr1/SnapTest/snapshots-opa/bin/runtest: Command not found.
****SYSTEM ERROR osx1011test: Abnormal exit from runtest ****
	****SYSTEM ERROR osx1011test: runtest command failed ****
More information about the opa-nightly-tests mailing list
